Altair RISE
Nominate Yourself Now!
"[SOLVED] Error when trying to start RapidMiner Server after installation"
User: "koepfw"
New Altair Community Member
Updated by Jocelyn
Hallo,
I installed RapidMiner server on a CentOS server and I am getting the following error when I'm trying to start the service with standalon.sh:
01:49:51,399 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-15) MSC00001: Failed to start service jboss.serverManagement.controller.management.http: org.jboss.msc.service.StartException in service jboss.serverManagement.controller.management.http: java.io.IOException: Unable to load resource handler
       at org.jboss.as.server.mgmt.HttpManagementService.start(HttpManagementService.java:226) [jboss-as-server-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1811) [jboss-msc-1.0.4.GA.jar:1.0.4.GA]
       at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1746) [jboss-msc-1.0.4.GA.jar:1.0.4.GA]
       at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [rt.jar:1.7.0_65]
       at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) [rt.jar:1.7.0_65]
       at java.lang.Thread.run(Thread.java:745) [rt.jar:1.7.0_65]
Caused by: java.io.IOException: Unable to load resource handler
       at org.jboss.as.domain.http.server.ManagementHttpServer.create(ManagementHttpServer.java:212) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       at org.jboss.as.server.mgmt.HttpManagementService.start(HttpManagementService.java:190) [jboss-as-server-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       ... 5 more
Caused by: org.jboss.modules.ModuleNotFoundException: org.jboss.as.domain-http-error-context:main
       at org.jboss.modules.ModuleLoader.loadModule(ModuleLoader.java:224) [jboss-modules.jar:1.2.0.CR1]
       at org.jboss.as.domain.http.server.ResourceHandler.getClassLoader(ResourceHandler.java:327) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       at org.jboss.as.domain.http.server.ErrorHandler.<init>(ErrorHandler.java:54) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       at org.jboss.as.domain.http.server.ManagementHttpServer.create(ManagementHttpServer.java:210) [jboss-as-domain-http-interface-7.2.0.Alpha1-redhat-4.jar:7.2.0.Alpha1-redhat-4]
       ... 6 more
Any help would be greatly appreciated.
1 - 17 of 171
    Hi,
    this "error" occurs for some installations while it does not for others. In either case however there is no actual problem and it can be safely ignored. While it does look a bit scary, your server should work just fine, correct?
    Regards,
    Marco
    User: "koepfw"
    OP
    Unfortunately not.  When I run standalone.sh It terminates after about one and a half minutes with ...
    01:51:15,886 INFO  [javax.enterprise.resource.webcontainer.jsf.config] (ServerService Thread Pool -- 76) Initializing Mojarra 2.1.18-jbossorg-1 20130205-1414 for context '/RAWS'
    ./standalone.sh: line 217: 25619 Killed                  "/usr/lib/jvm/java/bin/java" -D"[Standalone]" -server -XX:+UseCompressedOops -Xms512m -Xmx1024m -XX:MaxPermSize=256m -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml "-Dorg.jboss.boot.log.file=/home/metisuser/rapidminer/standalone/log/server.log" "-Dlogging.configuration=file:/home/metisuser/rapidminer/standalone/configuration/logging.properties" -jar "/home/metisuser/rapidminer/jboss-modules.jar" -mp "/home/metisuser/rapidminer/modules" -jaxpmodule javax.xml.jaxp-provider org.jboss.as.standalone -Djboss.home.dir="/home/metisuser/rapidminer" -Djboss.server.base.dir="/home/metisuser/rapidminer/standalone"
    Hi,
    can you please go to your Server/standalong/log folder, delete the server.log, try to start the server again and then paste the entire new server.log here?
    Regards,
    Marco
    User: "koepfw"
    OP
    Vielen Dank fuer die prompten Antworten.
    Here's the server.log file:
    21:58:57,598 INFO  [org.jboss.modules] (main) JBoss Modules version 1.2.0.CR1
    21:58:59,817 INFO  [org.jboss.msc] (main) JBoss MSC version 1.0.4.GA
    21:59:00,111 INFO  [org.jboss.as] (MSC service thread 1-6) JBAS015899: JBoss AS 7.2.0.Alpha1-redhat-4 "Janus" starting
    21:59:00,147 DEBUG [org.jboss.as.config] (MSC service thread 1-6) Configured system properties:
    [Standalone] =
    awt.toolkit = sun.awt.X11.XToolkit
    file.encoding = UTF-8
    file.encoding.pkg = sun.io
    file.separator = /
    java.awt.graphicsenv = sun.awt.X11GraphicsEnvironment
    java.awt.headless = true
    java.awt.printerjob = sun.print.PSPrinterJob
    java.class.path = /home/metisuser/rapidminer/jboss-modules.jar
    java.class.version = 51.0
    java.endorsed.dirs = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/endorsed
    java.ext.dirs = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/ext:/usr/java/packages/lib/ext
    java.home = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre
    java.io.tmpdir = /tmp
    java.library.path = /usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
    java.net.preferIPv4Stack = true
    java.runtime.name = OpenJDK Runtime Environment
    java.runtime.version = 1.7.0_65-mockbuild_2014_07_16_06_06-b00
    java.specification.name = Java Platform API Specification
    java.specification.vendor = Oracle Corporation
    java.specification.version = 1.7
    java.util.logging.manager = org.jboss.logmanager.LogManager
    java.vendor = Oracle Corporation
    java.vendor.url = http://java.oracle.com/
    java.vendor.url.bug = http://bugreport.sun.com/bugreport/
    java.version = 1.7.0_65
    java.vm.info = mixed mode
    java.vm.name = OpenJDK 64-Bit Server VM
    java.vm.specification.name = Java Virtual Machine Specification
    java.vm.specification.vendor = Oracle Corporation
    java.vm.specification.version = 1.7
    java.vm.vendor = Oracle Corporation
    java.vm.version = 24.65-b04
    javax.management.builder.initial = org.jboss.as.jmx.PluggableMBeanServerBuilder
    javax.xml.datatype.DatatypeFactory = __redirected.__DatatypeFactory
    javax.xml.parsers.DocumentBuilderFactory = __redirected.__DocumentBuilderFactory
    javax.xml.parsers.SAXParserFactory = __redirected.__SAXParserFactory
    javax.xml.stream.XMLEventFactory = __redirected.__XMLEventFactory
    javax.xml.stream.XMLInputFactory = __redirected.__XMLInputFactory
    javax.xml.stream.XMLOutputFactory = __redirected.__XMLOutputFactory
    javax.xml.transform.TransformerFactory = __redirected.__TransformerFactory
    javax.xml.validation.SchemaFactory:http://www.w3.org/2001/XMLSchema = __redirected.__SchemaFactory
    javax.xml.xpath.XPathFactory:http://java.sun.com/jaxp/xpath/dom = __redirected.__XPathFactory
    jboss.home.dir = /home/metisuser/rapidminer
    jboss.host.name = metis
    jboss.modules.dir = /home/metisuser/rapidminer/modules
    jboss.modules.system.pkgs = org.jboss.byteman
    jboss.node.name = metis
    jboss.qualified.host.name = metis.richeyint.com
    jboss.server.base.dir = /home/metisuser/rapidminer/standalone
    jboss.server.config.dir = /home/metisuser/rapidminer/standalone/configuration
    jboss.server.data.dir = /home/metisuser/rapidminer/standalone/data
    jboss.server.default.config = standalone.xml
    jboss.server.deploy.dir = /home/metisuser/rapidminer/standalone/data/content
    jboss.server.log.dir = /home/metisuser/rapidminer/standalone/log
    jboss.server.name = metis
    jboss.server.persist.config = true
    jboss.server.temp.dir = /home/metisuser/rapidminer/standalone/tmp
    line.separator =
    logging.configuration = file:/home/metisuser/rapidminer/standalone/configuration/logging.properties
    module.path = /home/metisuser/rapidminer/modules
    org.jboss.boot.log.file = /home/metisuser/rapidminer/standalone/log/server.log
    org.jboss.resolver.warning = true
    org.xml.sax.driver = __redirected.__XMLReaderFactory
    os.arch = amd64
    os.name = Linux
    os.version = 2.6.32-042stab092.2
    path.separator = :
    sun.arch.data.model = 64
    sun.boot.class.path = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/resources.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/rt.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/sunrsasign.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/jsse.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/jce.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/charsets.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/rhino.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/jfr.jar:/usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/classes
    sun.boot.library.path = /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/lib/amd64
    sun.cpu.endian = little
    sun.cpu.isalist =
    sun.io.unicode.encoding = UnicodeLittle
    sun.java.command = /home/metisuser/rapidminer/jboss-modules.jar -mp /home/metisuser/rapidminer/modules -jaxpmodule javax.xml.jaxp-provider org.jboss.as.standalone -Djboss.home.dir=/home/metisuser/rapidminer -Djboss.server.base.dir=/home/metisuser/rapidminer/standalone
    sun.java.launcher = SUN_STANDARD
    sun.jnu.encoding = UTF-8
    sun.management.compiler = HotSpot 64-Bit Tiered Compilers
    sun.os.patch.level = unknown
    sun.rmi.dgc.client.gcInterval = 3600000
    sun.rmi.dgc.server.gcInterval = 3600000
    user.country = US
    user.dir = /home/metisuser/rapidminer/bin
    user.home = /root
    user.language = en
    user.name = root
    user.timezone = America/Chicago
    21:59:00,150 DEBUG [org.jboss.as.config] (MSC service thread 1-6) VM Arguments: -D[Standalone] -XX:+UseCompressedOops -Xms512m -Xmx1024m -XX:MaxPermSize=256m -XX:+UseG1GC -XX:MaxGCPauseMillis=50 -Djava.net.preferIPv4Stack=true -Dorg.jboss.resolver.warning=true -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Djboss.modules.system.pkgs=org.jboss.byteman -Djava.awt.headless=true -Djboss.server.default.config=standalone.xml -Dorg.jboss.boot.log.file=/home/metisuser/rapidminer/standalone/log/server.log -Dlogging.configuration=file:/home/metisuser/rapidminer/standalone/configuration/logging.properties
    21:59:04,799 INFO  [org.jboss.as.server.deployment.scanner] (DeploymentScanner-threads - 1) JBAS015003: Found ROOT.war in deployment directory. To trigger deployment create a file called ROOT.war.dodeploy
    21:59:04,831 INFO  [org.xnio] (MSC service thread 1-27) XNIO Version 3.0.7.GA
    21:59:04,835 INFO  [org.jboss.as.server] (Controller Boot Thread) JBAS015888: Creating http management service using socket-binding (management-http)
    21:59:04,840 INFO  [org.xnio.nio] (MSC service thread 1-27) XNIO NIO Implementation Version 3.0.7.GA
    21:59:04,881 INFO  [org.jboss.remoting] (MSC service thread 1-27) JBoss Remoting version 3.2.14.GA
    21:59:04,978 INFO  [org.jboss.as.configadmin] (ServerService Thread Pool -- 27) JBAS016200: Activating ConfigAdmin Subsystem
    21:59:04,981 INFO  [org.jboss.as.naming] (ServerService Thread Pool -- 39) JBAS011800: Activating Naming Subsystem
    21:59:04,985 INFO  [org.jboss.as.webservices] (ServerService Thread Pool -- 50) JBAS015537: Activating WebServices Extension
    21:59:04,985 INFO  [org.jboss.as.security] (ServerService Thread Pool -- 45) JBAS013171: Activating Security Subsystem
    21:59:04,982 INFO  [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 32) JBAS010280: Activating Infinispan subsystem.
    21:59:05,009 INFO  [org.jboss.as.security] (MSC service thread 1-2) JBAS013170: Current PicketBox version=4.0.15.Final
    21:59:05,017 INFO  [org.jboss.as.jsf] (ServerService Thread Pool -- 49) JBAS012605: Activated the following JSF Implementations: [main, 1.2]
    21:59:05,043 INFO  [org.jboss.as.connector.logging] (MSC service thread 1-6) JBAS010408: Starting JCA Subsystem (JBoss IronJacamar 1.0.15.Final)
    21:59:05,054 INFO  [org.jboss.as.osgi] (ServerService Thread Pool -- 40) JBAS011906: Activating OSGi Subsystem
    21:59:05,717 INFO  [org.jboss.as.naming] (MSC service thread 1-1) JBAS011802: Starting Naming Service
    21:59:05,781 INFO  [org.jboss.as.mail.extension] (MSC service thread 1-16) JBAS015400: Bound mail session [java:/Mail]
    21:59:05,959 INFO  [org.jboss.as.connector.subsystems.datasources] (ServerService Thread Pool -- 28) JBAS010404: Deploying non-JDBC-compliant driver class com.mysql.jdbc.Driver (version 5.1)
    21:59:07,402 INFO  [org.apache.coyote.http11] (MSC service thread 1-27) JBWEB003001: Coyote HTTP/1.1 initializing on : http-/0.0.0.0:7000
    21:59:07,500 INFO  [org.apache.coyote.http11] (MSC service thread 1-27) JBWEB003000: Coyote HTTP/1.1 starting on: http-/0.0.0.0:7000
    21:59:07,782 INFO  [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-10) JBAS010400: Bound data source [java:/jdbc/RapidAnalyticsDS]
    21:59:08,014 INFO  [org.jboss.ws.common.management] (MSC service thread 1-13) JBWS022052: Starting JBoss Web Services - Stack CXF Server 4.1.3.Final
    21:59:08,210 INFO  [org.jboss.as.server.deployment.scanner] (MSC service thread 1-26) JBAS015012: Started FileSystemDeploymentService for directory /home/metisuser/rapidminer/standalone/deployments
    21:59:08,223 INFO  [org.jboss.as.server.deployment] (MSC service thread 1-5) JBAS015876: Starting deployment of "rapidminer-server-ear-2.1.0-ear.ear" (runtime-name: "rapidminer-server-ear-2.1.0-ear.ear")
    21:59:08,223 INFO  [org.jboss.as.server.deployment] (MSC service thread 1-4) JBAS015876: Starting deployment of "ROOT.war" (runtime-name: "ROOT.war")
    21:59:08,247 INFO  [org.jboss.as.remoting] (MSC service thread 1-14) JBAS017100: Listening on 0.0.0.0:4447
    21:59:08,247 INFO  [org.jboss.as.remoting] (MSC service thread 1-30) JBAS017100: Listening on 209.188.88.190:9999
    21:59:08,252 WARN  [org.jboss.as.domain.http.api] (MSC service thread 1-22) JBAS015102: Unable to load console module for slot main, disabling console
    21:59:08,255 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-22) MSC00001: Failed to start service jboss.serverManagement.controller.management.http: org.jboss.msc.service.StartException in service jboss.serverManagement.controller.management.http: java.io.IOException: Unable to load resource handler
    ... 5 more
    ... 6 more
    There is more but if I add it, it'll go over the maximum allowed length (20000 characters).  I'd be happy to email it to you though.
    Hi,
    feel free to use something like http://pastebin.com/. The intersting part is missing in your log ;)
    Regards,
    Marco
    User: "koepfw"
    OP
    Was just thinking of that before I saw your reply:  http://pastebin.com/my5cCLy5
    Hi,
    the good news is, there is no error whatsoever in your log. The bad news is it seems to be stuck on
    21:59:39,129 INFO  [javax.enterprise.resource.webcontainer.jsf.config] (ServerService Thread Pool -- 67) Initializing Mojarra 2.1.18-jbossorg-1 20130205-1414 for context '/RA'
    How long did you wait after starting the server before copying the log?
    I have seen this before but we were never able to reproduce this. What version of CentOS are you using exactly?
    Regards,
    Marco
    User: "koepfw"
    OP
    I am on "CentOS release 6.5 (Final)".  Here's the console output when I run standalone.sh: http://pastebin.com/njHcbTHk
    User: "koepfw"
    OP
    And I should add it has cPanel on that box and I am running Tomcat (or rather easy-Tomcat7) as well as MySQL on it.
    Hi,
    how much free memory was available at the time? I did search around a bit and this seems to sometimes happen in case there is not enough memory available.
    Was it a fresh install or did you update the .ear in an existing installation?
    Regards,
    Marco
    User: "koepfw"
    OP
    This is what I get when I run "cat /proc/meminfo"
    root@metis [1065 03:06:48 /home/metisuser/rapidminer/bin]# cat /proc/meminfo
    MemTotal:        1572864 kB
    MemFree:          953088 kB
    Cached:            4484 kB
    Buffers:              0 kB
    Active:          134800 kB
    Inactive:        440124 kB
    Active(anon):    134496 kB
    Inactive(anon):  435944 kB
    Active(file):        304 kB
    Inactive(file):    4180 kB
    Unevictable:          0 kB
    Mlocked:              0 kB
    SwapTotal:        131072 kB
    SwapFree:            168 kB
    Dirty:                92 kB
    Writeback:            0 kB
    AnonPages:        570440 kB
    Shmem:              6756 kB
    Slab:              44772 kB
    SReclaimable:      15968 kB
    SUnreclaim:        28804 kB
    User: "koepfw"
    OP
    See also...
    root@metis [1066 03:07:18 /home/metisuser/rapidminer/bin]# free -m
                total      used      free    shared    buffers    cached
    Mem:          1536        467      1068          6          0        45
    -/+ buffers/cache:        422      1113
    Swap:          128        77        50
    Thanks!
    User: "koepfw"
    OP
    As well as ...
    top - 03:11:31 up 40 days, 11:50,  1 user,  load average: 0.23, 0.54, 0.69
    Tasks:  73 total,  1 running,  72 sleeping,  0 stopped,  0 zombie
    Cpu(s):  0.0%us,  0.0%sy,  0.0%ni,100.0%id,  0.0%wa,  0.0%hi,  0.0%si,  0.0%st
    Mem:  1572864k total,  886284k used,  686580k free,        0k buffers
    Swap:  131072k total,    79456k used,    51616k free,  219696k cached
    Hi,
    I can't say it with certainty, but your low memory might be the source for the problem. I'd recommend to have at least 2 GB of free memory available when starting RM Server with a Starter license (more for bigger licenses). While it may run on some machines with less than 1 GB of free memory, it may not on others.
    Regards,
    Marco
    User: "koepfw"
    OP
    Thanks for all your help.  You guys rock.  I guess I just will provision some hardware on EC2 and get it running there.  I might post on the board for some hints for that.
    User: "koepfw"
    OP
    Upgraded the server to 4GB of memory and that solved my problem.  Thanks for all your help and I guess you could mark this thread as [SOLVED].
    User: "Marco_Boeck"
    Altair Employee
    Hi,
    thanks for letting us know :)
    Regards,
    Marco
