"[solved] How to move examplesets from Linux to Windows?"
Hi All,
I am planning a data conversion process that will run on Linux and convert 50 files into 50 examplesets.
I am an RM beginner. I suppose after generating my 50 examplesets it is possible to save my examplesets into my local repository (on Linux).
I prefer to use RM on Windows, however the data translation that I am using is much easier on Linux.
What is the recommended way to make those 50 examplesets available to me on Windows?
One approach would be to send the examplesets to a database output operator on Linux, then connect the same database from Windows.
For the file-based approaches that do not require a data server (e.g. data output to CSV), is there any of the file formats that is a particularly good choice in terms of fully preserving the exampleset format?
Thanks,
Owen
Thanks,
Owen
