element size
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
sir we specify element size while doing 2D mesh . what does that  element size represent(for e.g element size=5) what does 5 represent are there any units for that
1 - 11 of 111
    User: "gopal_rathore"
    Altair Community Member
    Updated by gopal_rathore
    Hi,
    It refers to the element length  which software tries to maintain for element sand hence the unit is of length which can be mm, m, inches etc.
    User: "Nachiket Kadu_22143"
    Updated by Nachiket Kadu_22143
    Hi
    Whenever you mesh you convert your infinite body into finite number of elements, so its always upto the end users to decide what number of elements they need to handle. Depending upon the number of elements you need to decide your element size. The unit for element size in Hypermesh is decided by the users, if you are using tonne-N-mm-Sec system then the element size will be in mm.
    Thanks
    Altair Employee
    OP
    first i have worked with model with inches.meshing is done at that point.then i scaled the model to m . will the element now be in inches???
    Hi Jahnavi
    As far as i know only geometry can be scaled in Hypermesh. So how did you scaled HM or Fem file?
    Thanks
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    You can scale both Geometrical and FE enity. PFA screenshot of scale panel.
    Hi Rahul Sir
    This is ok! But can it be scaled during importing fem or HM?
    Thanks
    While importing  we can scale CAD but not FE.
    Altair Employee
    OP
    Hi,
      I did scaling as rahul sir said then i changed all the properties to m .May then 5 inches of element reduced to equivalent metres
    After scaling, you can check the dimension to verify.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    In fact, you can do 'scaling' with FE too, the same method as CAD.
    Altair Employee
    OP
    in some companies they will ask we want average element size to to maintain the average element size ?
    ( ex: avg element size is 3 , but once i finish meshing the avr elelment size of elements 3 is lesser y )
