1 - 11 of
111
Hi
Whenever you mesh you convert your infinite body into finite number of elements, so its always upto the end users to decide what number of elements they need to handle. Depending upon the number of elements you need to decide your element size. The unit for element size in Hypermesh is decided by the users, if you are using tonne-N-mm-Sec system then the element size will be in mm.
Thanks
Hi,
It refers to the element length which software tries to maintain for element sand hence the unit is of length which can be mm, m, inches etc.
