🎉Community Raffle - Win $25
Join and Win
Error reading a classifier saved in default (xml compressed) or binary formats
szabelUser: "szabel"
New Altair Community Member
Updated by Jocelyn
Version: Rapid Miner 4.4 (Yes I know that its an old version)
Error:
com.rapidminer.operator.UserError: Could not read file '<omitted>/RapidMinerData/Test/cl
assifier.mod': Cannot read from XML stream, wrong format:  : only whitespace content allowed before start tag and not
? (position: START_DOCUMENT seen ?... @1:1) .
        at com.rapidminer.operator.io.ModelLoader.apply(ModelLoader.java:97)
        at com.rapidminer.operator.Operator.apply(Operator.java:666)
        at com.rapidminer.operator.OperatorChain.apply(OperatorChain.java:416)
        at com.rapidminer.Process.run(Process.java:695)
        at com.rapidminer.Process.run(Process.java:665)
        at com.rapidminer.Process.run(Process.java:655)
        at machine_learning_service.RapidMinerTester.test(RapidMinerTester.java:139)
        at machine_learning_service.Candidate.act(Candidate.java:352)
        at machine_learning_service.RapidMinerService.main(RapidMinerService.java:307)
Caused by: java.io.StreamCorruptedException: invalid stream header: 3F080000
        at java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:781)
        at java.io.ObjectInputStream.<init>(ObjectInputStream.java:278)
        at com.rapidminer.operator.io.ModelLoader.apply(ModelLoader.java:76)
        ... 9 more
This happens when I change the process config xml
<operator name="Root" class="Process" expanded="yes">
    <parameter key="logverbosity" value="off"/>
    <operator name="Input" class="ExampleSource">
        <parameter key="attributes" value="<omitted>/RapidMinerData/Train/AttributeDescriptors/test.aml"/>
    </operator>
    <operator name="NaiveBayes" class="NaiveBayes">
    </operator>
    <operator name="ModelWriter" class="ModelWriter">
        <parameter key="model_file" value="<omitted>/RapidMinerData/Train/classifier_return.mod"/>
      <parameter key="output_type"    value="XML"/>
    </operator>
</operator>
and am reading in using
<operator name = "Root" class="Process" expanded="yes">
        <parameter key="attributes" value="<omitted>/RapidMinerData/Test/AttributeDescriptors/test.aml"/>
    </operator>
    <operator name="ModelLoader" class="ModelLoader">
        <parameter key="model_file" value="<omitted>/RapidMinerData/Test/classifier.mod"/>
    </operator>
    <operator name="Applier" class="ModelApplier">
        <list key="application_parameters">
        </list>
    </operator>
    <operator name="BinominalClassificationPerformance" class="BinominalClassificationPerformance">
        <parameter key="false_negative" value="true"/>
        <parameter key="false_positive" value="true"/>
        <parameter key="sensitivity" value="true"/>
        <parameter key="specificity" value="true"/>
        <parameter key="true_negative" value="true"/>
        <parameter key="true_positive" value="true"/>
    </operator>
    <operator name="ProcessLog" class="ProcessLog">
        <parameter key="filename" value="<omitted>/RapidMinerData/Test/statistics.per"/>
        <list key="log">
          <parameter key="false_positive"      value="operator.BinominalClassificationPerformance.value.false_positive"/>
          <parameter key="false_negative" value="operator.BinominalClassificationPerformance.value.false_negative"/>
          <parameter key="true_positive" value="operator.BinominalClassificationPerformance.value.true_positive"/>
          <parameter key="true_negative" value="operator.BinominalClassificationPerformance.value.true_negative"/>
          <!--<parameter key="AUC" value="operator.BinominalClassificationPerformance.value.AUC"/>-->
          <parameter key="sensitivity" value="operator.BinominalClassificationPerformance.value.sensitivity"/>
          <parameter key="specificity" value="operator.BinominalClassificationPerformance.value.specificity"/>
        </list>
        <parameter key="persistent" value="true"/>
    </operator>
</operator>
Any help will be greatly appreciated
1 - 4 of 41
    homburgUser: "homburg"
    Hello szabel,
    is
     '<omitted>/RapidMinerData/Test/classifier.mod'
    really your file system input path? This might be problematic due to the "<" ">" characters in the xml file. Please try a full qualified path insted.
    Cheers,
    Helge
    OP
    No,  <omitted> is not actually there. I had to obfuscate some of the example... There is an actual valid path there and valid permissions; the only change is that I am taking the default (Zipped XML) and not specifying plain vanilla XML.
    Thank you,
    Stephen
    Looks like your model file is broken. Have you tried to recreate it?
    Another option might be that there has been a bug in the model writer those days. I'd highly recommend to upgrade to a more recent version. RapidMiner 5.3 is open source and freely available without any restrictions: http://sourceforge.net/projects/rapidminer/
    Cheers,
    Helge
    OP
    Yeah, I can try that... I was hoping that since it works when specifying XML that I was just missing a parameter that I was not seeing in the documentation.
