🎉Community Raffle - Win $25
Join and Win
Model selection using cross validation
User: "Smith"
New Altair Community Member
Updated by Jocelyn
Hallo,
I am trying to do a simple model selection using cross validation in Rapidminer.
The goal is to evaluate various classification methods using the same folds of cross validation for each method and select the one with the best averaged performance over the folds. This should be done within one process automatically.
Below is the process I've created to accomplish this goal.
The potential problem I see with this approach is the fact that the X-Validation operator is placed within the Loop operator. I am not sure if every classification method will be evaluated on the same folds of X-Validation.. Is this guaranteed when the local random seed parameter of X-Validation is set to true?
Is there maybe an easier way to finding the best classifier for the given classification task automatically?
Many thanks in advance.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.013">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.3.013" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="5.3.013" expanded="true" height="60" name="Golf" width="90" x="112" y="75">
        <parameter key="repository_entry" value="//Samples/data/Golf"/>
      </operator>
      <operator activated="true" class="loop" compatibility="5.3.013" expanded="true" height="76" name="Loop" width="90" x="313" y="75">
        <parameter key="set_iteration_macro" value="true"/>
        <parameter key="iterations" value="3"/>
          <operator activated="true" class="x_validation" compatibility="5.3.013" expanded="true" height="112" name="Validation" width="90" x="179" y="30">
            <parameter key="number_of_validations" value="4"/>
            <parameter key="use_local_random_seed" value="true"/>
              <operator activated="true" class="select_subprocess" compatibility="5.3.013" expanded="true" height="76" name="Select Subprocess (2)" width="90" x="159" y="30">
                <parameter key="select_which" value="%{iteration}"/>
                  <operator activated="true" class="k_nn" compatibility="5.3.013" expanded="true" height="76" name="k-NN (2)" width="90" x="44" y="30"/>
                  <connect from_port="input 1" to_op="k-NN (2)" to_port="training set"/>
                  <connect from_op="k-NN (2)" from_port="model" to_port="output 1"/>
                  <portSpacing port="source_input 2" spacing="0"/>
                  <portSpacing port="sink_output 1" spacing="0"/>
                  <portSpacing port="sink_output 2" spacing="0"/>
                </process>
                  <operator activated="true" class="naive_bayes" compatibility="5.3.013" expanded="true" height="76" name="Naive Bayes (2)" width="90" x="46" y="30"/>
                  <connect from_port="input 1" to_op="Naive Bayes (2)" to_port="training set"/>
                  <connect from_op="Naive Bayes (2)" from_port="model" to_port="output 1"/>
                </process>
                  <operator activated="true" class="decision_tree" compatibility="5.3.013" expanded="true" height="76" name="Decision Tree (2)" width="90" x="48" y="30"/>
                  <connect from_port="input 1" to_op="Decision Tree (2)" to_port="training set"/>
                  <connect from_op="Decision Tree (2)" from_port="model" to_port="output 1"/>
                </process>
              </operator>
              <connect from_port="training" to_op="Select Subprocess (2)" to_port="input 1"/>
              <connect from_op="Select Subprocess (2)" from_port="output 1" to_port="model"/>
              <portSpacing port="source_training" spacing="0"/>
              <portSpacing port="sink_model" spacing="0"/>
              <portSpacing port="sink_through 1" spacing="0"/>
            </process>
              <operator activated="true" class="apply_model" compatibility="5.3.013" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
              </operator>
              <operator activated="true" class="performance_classification" compatibility="5.3.013" expanded="true" height="76" name="Performance" width="90" x="259" y="30">
                <list key="class_weights"/>
              </operator>
              <connect from_port="model" to_op="Apply Model" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
              <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
              <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
              <portSpacing port="source_model" spacing="0"/>
              <portSpacing port="source_test set" spacing="0"/>
              <portSpacing port="source_through 1" spacing="0"/>
              <portSpacing port="sink_averagable 1" spacing="0"/>
              <portSpacing port="sink_averagable 2" spacing="0"/>
            </process>
          </operator>
          <connect from_port="input 1" to_op="Validation" to_port="training"/>
          <connect from_op="Validation" from_port="averagable 1" to_port="output 1"/>
        </process>
      </operator>
      <connect from_op="Golf" from_port="output" to_op="Loop" to_port="input 1"/>
      <connect from_op="Loop" from_port="output 1" to_port="result 1"/>
    </process>
  </operator>
</process>
[ /code]
1 - 2 of 21
    User: "fras"
    You are on the right way. Dont forget to optimize parameters of the decisions tree or replace
    it by a more friendly learner.
    User: "Smith"
    OP
    Hi,
    thank you for your input.
    If I understood you corretly, you do think that the parameter local random seed of the X-Validation operator ensures the same division of the dataset for applying and comparing each learning method?
    Regarding the Optimize Parameters operator: indeed it would be nice to select not just the optimal method for the given problem, but also its optimal parameters within one process. Can you be more concrete and suggest an approach or even better post a process for doing this? I read about nested cross validation approaches that deal with this issue, but it seems like there is no standard way of doing this... Doing it sequentially (first select the best learner with default parameters and then find potentially better parameter values) is surely not an optimal way.
