Load vs Time plot
User: "Sudhir Hoskere"
Altair Community Member
Updated by Sudhir Hoskere
In seat belt anchorage test, if I want to see the drop in load when a structural failure is observed, what should be the approach? How should the load be applied: CLOAD or Imposed displacement?
1 - 1 of 11
    User: "PaulAltair"
    Altair Employee
    Updated by PaulAltair
    It is almost always better to impose displacement and measure the reaction force in RBODY or spring
    This way, the 'load' (displacement) is definite and well controlled/defined
    If you define a load vs time, typically this will be 'noisier', and when failure does occur, the model will become unstable as their is no longer a structure able to react the requested load
    Be careful with setting the model going too, use /FUNCT_SMOOTH for the IMPDISP card function as with a linear displacement vs time you are still accelerating to a constant velocity in the first cycle
