🎉Community Raffle - Win $25
Join and Win
[SOLVED]EntrySet is not supported by Example
User: "wujiang"
New Altair Community Member
Updated by Jocelyn
Hi there
I have a project for add a operator to RM, Recently, I use the iterator for deal with 'example'. like:
public Reader(Example example) {
this.example = example.entrySet().iterator();
but once I execute my operator, a report of bug will be shown:
SEVERE: Process failed: operator cannot be executed (EntrySet is not supported by Example.). Check the log messages...
java.lang.UnsupportedOperationException: EntrySet is not supported by Example.
but, example is a type of Map<String, Object> ?
Could you help me?
Thanks a lot.
Jiang
1 - 2 of 21
    User: "Marco_Boeck"
    Hi,
    as you can see in the Example.java class, not every operation from the parent class is supported. You can iterate over all values from an example via
    for (Attribute att : example.getAttributes()) {
        System.out.println(example.getValue(att));
    Regards,
    Marco
    User: "wujiang"
    OP
    OK, Got it, Thank you very much! ;D
