Altair RISE
Nominate Yourself Now!
Home
Discussions
Community Q&A
reporting extension - annoying bug
sgenzer
Hi...there is a bug in the reporting extension that has been annoying me for a long time. When you use Generate Report and set the paper size and orientation to anything besides the default (A4 portrait) and run the process, the parameters reset back to A4 portrait every time. Can you please see if you can fix this?
Thanks.
Scott
AI Studio
Extensions
Bug Report
Accepted answers
All comments
JEdward
One thing you might want to do is switch to only using the Generate Report as HTML rather than as PDF.
You can add CSS styles into the process and set the page & formatting as you like with much more freedom. Once created just open in your web browser & print to PDF.
sgenzer
hmm...that's an interesting workaround. OK thanks. Can we please put this on the bug list too?
Scott
Quick Links
All Categories
Recent Discussions
Activity
Unanswered
日本語 (Japanese)
한국어(Korean)
Groups
