🎉Community Raffle - Win $25
Join and Win
[SOLVED] Access to IOObject
User: "memvis70"
New Altair Community Member
Updated by Jocelyn
Hello,
I want to access to the entries of a ConfusionMatrix, so I can visualize the Matrix in my application,
I was trying to get access through the IOObject of the resulting IOContainer, but I didn't find a method.
Can I get access through the IOObject or is there another way to do that?
Thanks a lot for any response in advance!
Regards
1 - 6 of 61
    User: "Marco_Boeck"
    Hi,
    the following code snippet might help. You can have a look inside the ConfusionMatrixViewer class and check the ConfusionMatrixViewerTable.
    MultiClassificationPerformance performance = (MultiClassificationPerformance) ioObject;
    ConfusionMatrixViewer viewer = new ConfusionMatrixViewer(performance.getName(), performance.getTitle(), performance.getClassNames(), performance.getCounter());
    Obligatory legal advice:
    Please note that if you are using RapidMiner 5 in your application, it must be released under the AGPL v3. If that is not an option, please contact us for an OEM license.
    The usage of RapidMiner Studio 6 inside your own application always requires an OEM license.
    Regards,
    Marco
    User: "memvis70"
    OP
    Hi,
    First of all thank you for your response.
    However I get the following exception:
    java.lang.ClassCastException: com.rapidminer.operator.performance.PerformanceVector cannot be cast to com.rapidminer.operator.performance.MultiClassificationPerformance
    How can I handle this problem?
    Best Regards
    User: "memvis70"
    OP
    Is there a way to handle it or any other hint?
    Thanks for any response in advance.
    User: "Marco_Boeck"
    Hi,
    can you please post your process xml?
    Regards,
    Marco
    User: "memvis70"
    OP
    Hi Marco,
    the process looks like this:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.3.015">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve A" width="90" x="112" y="75">
            <parameter key="repository_entry" value="//Local Repository/A"/>
          </operator>
          <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve B" width="90" x="112" y="210">
            <parameter key="repository_entry" value="//Local Repository/B"/>
          </operator>
          <operator activated="true" class="join" compatibility="5.3.015" expanded="true" height="76" name="Join" width="90" x="313" y="120">
            <parameter key="remove_double_attributes" value="true"/>
            <parameter key="join_type" value="inner"/>
            <parameter key="use_id_attribute_as_key" value="true"/>
            <list key="key_attributes"/>
            <parameter key="keep_both_join_attributes" value="false"/>
          </operator>
          <operator activated="true" class="x_validation" compatibility="5.3.015" expanded="true" height="112" name="Validation" width="90" x="514" y="30">
            <parameter key="create_complete_model" value="false"/>
            <parameter key="average_performances_only" value="true"/>
            <parameter key="leave_one_out" value="false"/>
            <parameter key="number_of_validations" value="10"/>
            <parameter key="sampling_type" value="stratified sampling"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
              <operator activated="true" class="decision_tree" compatibility="5.3.015" expanded="true" height="76" name="Decision Tree" width="90" x="179" y="165">
                <parameter key="criterion" value="accuracy"/>
                <parameter key="minimal_size_for_split" value="4"/>
                <parameter key="minimal_leaf_size" value="2"/>
                <parameter key="minimal_gain" value="0.1"/>
                <parameter key="maximal_depth" value="20"/>
                <parameter key="confidence" value="0.25"/>
                <parameter key="number_of_prepruning_alternatives" value="3"/>
                <parameter key="no_pre_pruning" value="false"/>
                <parameter key="no_pruning" value="false"/>
              </operator>
              <connect from_port="training" to_op="Decision Tree" to_port="training set"/>
              <connect from_op="Decision Tree" from_port="model" to_port="model"/>
              <portSpacing port="source_training" spacing="0"/>
              <portSpacing port="sink_model" spacing="0"/>
              <portSpacing port="sink_through 1" spacing="0"/>
            </process>
              <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model" width="90" x="112" y="75">
                <parameter key="create_view" value="false"/>
              </operator>
              <operator activated="true" class="performance" compatibility="5.3.015" expanded="true" height="76" name="Performance" width="90" x="112" y="300">
                <parameter key="use_example_weights" value="true"/>
              </operator>
              <connect from_port="model" to_op="Apply Model" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
              <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
              <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
              <portSpacing port="source_model" spacing="0"/>
              <portSpacing port="source_test set" spacing="0"/>
              <portSpacing port="source_through 1" spacing="0"/>
              <portSpacing port="sink_averagable 1" spacing="0"/>
              <portSpacing port="sink_averagable 2" spacing="0"/>
            </process>
          </operator>
          <connect from_op="Retrieve A" from_port="output" to_op="Join" to_port="left"/>
          <connect from_op="Retrieve B" from_port="output" to_op="Join" to_port="right"/>
          <connect from_op="Join" from_port="join" to_op="Validation" to_port="training"/>
          <connect from_op="Validation" from_port="model" to_port="result 1"/>
          <connect from_op="Validation" from_port="training" to_port="result 2"/>
          <connect from_op="Validation" from_port="averagable 1" to_port="result 3"/>
          <portSpacing port="sink_result 3" spacing="0"/>
          <portSpacing port="sink_result 4" spacing="0"/>
        </process>
      </operator>
    </process>
    User: "Marco_Boeck"
    Hi,
    you can get the PerformanceVector by doing this:
    PerformanceVector performance = (PerformanceVector) ioObject;
    You can also have a look at the PerformanceVectorRenderer class in the createReportable() method which calls the performanceVector.getCriterion() methods.
    Regards,
    Marco
