🎉Community Raffle - Win $25
Join and Win
"[SOLVED]Using k-means clustering on web log data"
starUser: "star"
New Altair Community Member
Updated by Jocelyn
I have a data set from a access web log file which I'm interested in finding similar clusters. (I'm an absolute beginner of data mining). So far I have referred many research papers on the same problem domain.
An Efficient Approach for Clustering Web Access Patterns from Web Logs
http://www.sersc.org/journals/IJAST/vol5/1.pdf
Classifying the user intent of web queries using k-means clustering
http://faculty.ist.psu.edu/jjansen/academic/jansen_user_intent_kmeans.pdf
I want to use k-means clustering to cluster web pages. Although these papers discuss about the algorithm, they do not specify the way of providing input data set. k-means calculate similarity between data points using Euclidean distance. So how to normalize my dataset to be mined using k-means since urls can not directly used for k-means. Any help/good reference on this?
Example Dataset(p1..pn are different web pages)
p1,p2,p3,p4
p1,p2
p1,p5,p6,p7
p1,p2,p3,p5
1 - 2 of 21
    ighybooUser: "ighyboo"
    Hi Star,
    I'm not an expert but the way I would approach the problem is to create a table with p1...pn as columns and individual users as rows.
    The values filling the table would be the count of how many times a page has been visited by the user. UserID p1 p2 p3 .. User1 1 1 1 1 User2 1 1 0 0 User3 1 0 0 0
    Just an idea.. :)
    starUser: "star"
    OP
    Hi ighyboo,
    Thanks for the reply, this is what exactly ended up in doing.
