🎉Community Raffle - Win $25
Join and Win
"java.lang.NullPointerExceptiond:when using Voting inside X-Validation"
Legacy UserUser: "Legacy User"
New Altair Community Member
Updated by Jocelyn
Helllo,
I a trying to use a voting operator inside X-Validation but it fails. In the log I can find a  java.lang.NullPointerException. The same happens when I use stacking as well, but only sometimes and I am not able to reproduce it now.
I am using RM 5.3.01, so the latest update.
Best,
Elena
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.015">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.3.015" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve mapping_locationTypeID_tags_noOutliers_ResultSet" width="90" x="45" y="120">
        <parameter key="repository_entry" value="../../data/mapping_locationTypeID_tags_noOutliers_ResultSet"/>
      </operator>
      <operator activated="true" class="retrieve" compatibility="5.3.015" expanded="true" height="60" name="Retrieve ResultSet_Combined_DFKI_and_IMMI (2)" width="90" x="45" y="30">
        <parameter key="repository_entry" value="../../results/Combined_ResultSets/ResultSet_Combined_DFKI_and_IMMI"/>
      </operator>
      <operator activated="true" class="join" compatibility="5.3.015" expanded="true" height="76" name="Join" width="90" x="179" y="75">
        <parameter key="use_id_attribute_as_key" value="false"/>
        <list key="key_attributes">
          <parameter key="FileName" value="filename"/>
        </list>
      </operator>
      <operator activated="true" class="set_role" compatibility="5.3.015" expanded="true" height="76" name="Set Role" width="90" x="313" y="75">
        <parameter key="attribute_name" value="locationtype"/>
        <parameter key="target_role" value="label"/>
        <list key="set_additional_roles"/>
      </operator>
      <operator activated="true" class="normalize" compatibility="5.3.015" expanded="true" height="94" name="Normalize" width="90" x="447" y="75"/>
      <operator activated="true" class="x_validation" compatibility="5.3.015" expanded="true" height="130" name="Validation" width="90" x="447" y="255">
          <operator activated="true" class="vote" compatibility="5.3.015" expanded="true" height="60" name="Vote" width="90" x="112" y="75">
              <operator activated="true" class="weka:W-RandomForest" compatibility="5.3.001" expanded="true" height="76" name="W-RandomForest" width="90" x="328" y="30"/>
              <operator activated="true" class="polynomial_by_binomial_classification" compatibility="5.3.015" expanded="true" height="76" name="Polynominal by Binominal Classification" width="90" x="328" y="48">
                <parameter key="classification_strategies" value="1 against 1"/>
                  <operator activated="true" class="support_vector_machine_linear" compatibility="5.3.015" expanded="true" name="SVM (Linear)"/>
                  <connect from_port="training set" to_op="SVM (Linear)" to_port="training set"/>
                  <connect from_op="SVM (Linear)" from_port="model" to_port="model"/>
                  <portSpacing port="source_training set" spacing="0"/>
                  <portSpacing port="sink_model" spacing="0"/>
                </process>
              </operator>
              <operator activated="true" class="polynomial_by_binomial_classification" compatibility="5.3.015" expanded="true" height="76" name="Polynominal by Binominal Classification (2)" width="90" x="328" y="66">
                  <operator activated="true" class="support_vector_machine_linear" compatibility="5.3.015" expanded="true" name="SVM (2)"/>
                  <connect from_port="training set" to_op="SVM (2)" to_port="training set"/>
                  <connect from_op="SVM (2)" from_port="model" to_port="model"/>
                </process>
              </operator>
              <operator activated="true" class="naive_bayes_kernel" compatibility="5.3.015" expanded="true" height="76" name="Naive Bayes (Kernel)" width="90" x="328" y="84"/>
              <connect from_port="training set 1" to_op="W-RandomForest" to_port="training set"/>
              <connect from_port="training set 2" to_op="Polynominal by Binominal Classification" to_port="training set"/>
              <connect from_port="training set 3" to_op="Polynominal by Binominal Classification (2)" to_port="training set"/>
              <connect from_port="training set 4" to_op="Naive Bayes (Kernel)" to_port="training set"/>
              <connect from_op="W-RandomForest" from_port="model" to_port="base model 1"/>
              <connect from_op="Polynominal by Binominal Classification" from_port="model" to_port="base model 2"/>
              <connect from_op="Polynominal by Binominal Classification (2)" from_port="model" to_port="base model 3"/>
              <connect from_op="Naive Bayes (Kernel)" from_port="model" to_port="base model 4"/>
              <portSpacing port="source_training set 1" spacing="0"/>
              <portSpacing port="source_training set 2" spacing="0"/>
              <portSpacing port="source_training set 3" spacing="0"/>
              <portSpacing port="source_training set 4" spacing="0"/>
              <portSpacing port="source_training set 5" spacing="0"/>
              <portSpacing port="sink_base model 1" spacing="0"/>
              <portSpacing port="sink_base model 2" spacing="0"/>
              <portSpacing port="sink_base model 3" spacing="0"/>
              <portSpacing port="sink_base model 4" spacing="0"/>
              <portSpacing port="sink_base model 5" spacing="0"/>
            </process>
          </operator>
          <connect from_port="training" to_op="Vote" to_port="training set"/>
          <connect from_op="Vote" from_port="model" to_port="model"/>
          <portSpacing port="source_training" spacing="0"/>
          <portSpacing port="sink_through 1" spacing="0"/>
        </process>
          <operator activated="true" class="apply_model" compatibility="5.3.015" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30">
          </operator>
          <operator activated="true" class="performance_classification" compatibility="5.3.015" expanded="true" height="76" name="Performance" width="90" x="196" y="97">
            <list key="class_weights"/>
          </operator>
          <connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
          <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
          <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
          <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
          <portSpacing port="source_model" spacing="0"/>
          <portSpacing port="source_test set" spacing="0"/>
          <portSpacing port="source_through 1" spacing="0"/>
          <portSpacing port="sink_averagable 1" spacing="0"/>
          <portSpacing port="sink_averagable 2" spacing="0"/>
          <portSpacing port="sink_averagable 3" spacing="0"/>
        </process>
      </operator>
      <connect from_op="Retrieve mapping_locationTypeID_tags_noOutliers_ResultSet" from_port="output" to_op="Join" to_port="right"/>
      <connect from_op="Retrieve ResultSet_Combined_DFKI_and_IMMI (2)" from_port="output" to_op="Join" to_port="left"/>
      <connect from_op="Join" from_port="join" to_op="Set Role" to_port="example set input"/>
      <connect from_op="Set Role" from_port="example set output" to_op="Normalize" to_port="example set input"/>
      <connect from_op="Normalize" from_port="example set output" to_op="Validation" to_port="training"/>
      <connect from_op="Validation" from_port="model" to_port="result 1"/>
      <connect from_op="Validation" from_port="training" to_port="result 2"/>
      <connect from_op="Validation" from_port="averagable 1" to_port="result 3"/>
      <connect from_op="Validation" from_port="averagable 2" to_port="result 4"/>
      <portSpacing port="sink_result 3" spacing="0"/>
      <portSpacing port="sink_result 4" spacing="0"/>
      <portSpacing port="sink_result 5" spacing="0"/>
    </process>
  </operator>
</process>
1 - 9 of 91
    frasUser: "fras"
    Hi Elena,
    inside the X-Validation I found a dummy Random Forrest operator.
    Please remove and try to reproduce. If you can not this was the problem.
    -Frank
    Hi Frank,
    it is not dummy. It is an operator coming from the Weka extension.
    frasUser: "fras"
    If it happens again please provide the complete Exception message.
    Hi the error message appearing when the process fails says:
    "The setup does not seem to contain any obvious errors, but you should check the log messages or activate the debug mode in the settings dialog in order to get more information about this problem."
    Here is the RM log:
    Dec 2, 2013 3:58:01 PM SEVERE: Process failed: operator cannot be executed. Check the log messages...
    Dec 2, 2013 3:58:01 PM SEVERE: Here:          Process[1] (Process)
              subprocess 'Main Process'
                +- Retrieve mapping_locationTypeID_tags_noOutliers_ResultSet[1] (Retrieve)
                +- Retrieve ResultSet_Combined_DFKI_and_IMMI (2)[1] (Retrieve)
                +- Join[1] (Join)
                +- Set Role[1] (Set Role)
                +- Normalize[1] (Normalize)
                +- Validation[1] (X-Validation)
              subprocess 'Training'
                    |  +- Vote[2] (Vote)
              subprocess 'Base Learner'
                    |        +- W-RandomForest[2] (W-RandomForest)
                    |        +- Polynominal by Binominal Classification[2] (Polynominal by Binominal Classification)
              subprocess 'Learning Process'
                    |        |    +- SVM (Linear)[6] (Support Vector Machine (Linear))
                    |        +- Polynominal by Binominal Classification (2)[2] (Polynominal by Binominal Classification)
                    |        |    +- SVM (2)[6] (Support Vector Machine (Linear))
          ==>      |        +- Naive Bayes (Kernel)[2] (Naive Bayes (Kernel))
              subprocess 'Testing'
                      +- Apply Model (2)[1] (Apply Model)
                      +- Performance[1] (Performance (Classification))
    Dec 2, 2013 3:58:01 PM SEVERE: java.lang.NullPointerException
    User: "Marco_Boeck"
    Hi,
    can you please post the contents of the rm.log file inside the USER_HOME/.RapidMiner(5) folder?
    Regards,
    Marco
    This is where the error begins:
    at com.rapidminer.operator.learner.meta.Binary2MultiClassModel.startNonECOCProcess(Binary2MultiClassModel.java:164)
    at com.rapidminer.operator.learner.meta.Binary2MultiClassModel.performPrediction(Binary2MultiClassModel.java:278)
    at com.rapidminer.operator.learner.PredictionModel.apply(PredictionModel.java:76)
    at com.rapidminer.operator.learner.meta.AbstractStacking.learn(AbstractStacking.java:108)
    at com.rapidminer.operator.learner.meta.AbstractStacking.doWork(AbstractStacking.java:90)
    at com.rapidminer.operator.Operator.execute(Operator.java:866)
    at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
    at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:711)
    at com.rapidminer.operator.validation.ValidationChain.executeLearner(ValidationChain.java:214)
    at com.rapidminer.operator.validation.ValidationChain.learn(ValidationChain.java:305)
    at com.rapidminer.operator.validation.XValidation.performIteration(XValidation.java:159)
    at com.rapidminer.operator.validation.XValidation.estimatePerformance(XValidation.java:151)
    at com.rapidminer.operator.validation.ValidationChain.doWork(ValidationChain.java:273)
    at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:375)
    at com.rapidminer.Process.run(Process.java:949)
    at com.rapidminer.Process.run(Process.java:873)
    at com.rapidminer.Process.run(Process.java:832)
    at com.rapidminer.Process.run(Process.java:827)
    at com.rapidminer.Process.run(Process.java:817)
    at com.rapidminer.gui.ProcessThread.run(ProcessThread.java:63)
    Dec 02, 2013 11:14:39 PM com.rapidminer.gui.ProcessThread run
                +- Join[1] (Join)
                    |  +- Vote[2] (Vote)
    Hello guys,
    I keep on having this problem annd I have identified that it is caused by the  Polynominal by Binominal Classification operator.
    As a workaround, does it help to add a Materialize Data operator as the very first operator on both sides of the X-Validation?
    Best regards,
    Marius
    Hi Maruis!
    Yeap it worked!
    Thanks a lot,
    Elena
