"[SOLVED] Overriding macro values"
I'm trying to parameterize my process by using macros. However, I can't seem to change the values.
I've created services with parameters, I've used RM to schedule a process on RA and supplied the macro names and values on the context tab, but the defaults are always used.
Looking at the log it appears that the macros are being supplied twice, default first.
INFO: Process context is: Macros: [k_param : 5, maxdoc : 200, _ra_user : admin, _ra_jobID : 320, k_param : 20, maxdox : 5000]; Input: []; Output: []
How can I make this work?
1 - 2 of
21
Thanks for the response.
I ended up playing with "Generate Data by Users Specification" and putting macros in the attribute values. I was able to prove to myself that everything was working as expected. I then determined that my cron script which was calling the RM process via curl was where the problem was at. I needed to enclose the url in quotes otherwise the "&" symbol was being interpreted by the shell.
If this does not work, please make sure that you are using the latest version of the RapidMiner Studio or Server (either 5.3.15/1.3.15 or 6.0/2.0). If you continue to have problems, please let us know.
Best regards,
Marius
