[SOLVED] Calling a jar file from the execute script operator.
Hello Everybody! ;D
I'd like to use a jar file from with the Script Operator (I intend to build a full extension at a later date, but for now just want to access one piece of functionality using the script operator)
Would I just need to include it in the lib folder of RapidMiner or use some other way?
Thanks,
JE
Thanks,
JE
yes, it should be sufficient to drop it into that folder. However you probably need to start RapidMiner via one of the RapidMinerGUI scripts rather than the .exe file then.
Regards,
Marco
