🎉Community Raffle - Win $25
Join and Win
Password encryption
User: "marcin_blachnik"
New Altair Community Member
Updated by Jocelyn
Hi
When I use stand-alone RapidMiner the password to the  database is  encrypted in the  xml process file, but when I switch to my own code,which use RapidMiner as a library and call
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
then the password is decrypted, and the  log file contains com.rapidminer.parameter.ParameterTypePassword decryptPassword
How can I change it? or force password encryption when RapidMiner is used as a library
Best
Marcin
1 - 3 of 31
    User: "Marco_Boeck"
    Hi,
    once you load the process XML, all ParameterTypePasswords in the process will be decrypted. There is no way around that - except obviously to use a predefined DB connection which keeps credentials out of the process XML and inside Studio itself.
    Regards,
    Marco
    OP
    Hi
    Thanks for the answer but it is not that case.
    I have a problem that in the process xml file which is stored on hard disk the password must be decrypted, so in other words RapidMiner reads password as a pure text. The file must contain something like:
    <operator class="read_database">
                  <parameter key="password" value="xyz"/>
    </operator>
    but it happens only when I run RapidMiner from within my application which uses RapidMiner as a library.
    When I created the process using GUI the password was encrypted, but since I wanted to use it in embedded instance of RapidMiner within my application I have to rewrite the password decrypted. So now I'd like to know how to enable password encryption.
    When I run RapidMiner in my embedded application in the log file it says:
    so it treats passwords as pure text, and I would like to turn it into
    com.rapidminer.parameter.ParameterTypePassword encryptPassword
    So I'd be very gratefull if anyone could help me how to turn back into encrypted passwords.
    User: "Marco_Boeck"
    Hi,
    there have been quite some changes between version 5.3 and 6.5, so I'm afraid I cannot help you with the old version. What is the result in Studio 6.5?
    Regards,
    Marco
