Password encryption
marcin_blachnik
Hi
When I use stand-alone RapidMiner the password to the database is encrypted in the xml process file, but when I switch to my own code,which use RapidMiner as a library and call
RapidMiner.setExecutionMode(RapidMiner.ExecutionMode.COMMAND_LINE);
RapidMiner.init();
then the password is decrypted, and the log file contains com.rapidminer.parameter.ParameterTypePassword decryptPassword
How can I change it? or force password encryption when RapidMiner is used as a library
Best
Marcin
Developer
Marco_Boeck
once you load the process XML, all ParameterTypePasswords in the process will be decrypted. There is no way around that - except obviously to use a predefined DB connection which keeps credentials out of the process XML and inside Studio itself.
Marco
marcin_blachnik
Hi
Thanks for the answer but it is not that case.
I have a problem that in the process xml file which is stored on hard disk the password must be decrypted, so in other words RapidMiner reads password as a pure text. The file must contain something like:
<operator class="read_database">
<parameter key="password" value="xyz"/>
but it happens only when I run RapidMiner from within my application which uses RapidMiner as a library.
When I created the process using GUI the password was encrypted, but since I wanted to use it in embedded instance of RapidMiner within my application I have to rewrite the password decrypted. So now I'd like to know how to enable password encryption.
When I run RapidMiner in my embedded application in the log file it says:
so it treats passwords as pure text, and I would like to turn it into
com.rapidminer.parameter.ParameterTypePassword encryptPassword
So I'd be very gratefull if anyone could help me how to turn back into encrypted passwords.
Marco_Boeck
there have been quite some changes between version 5.3 and 6.5, so I'm afraid I cannot help you with the old version. What is the result in Studio 6.5?
Marco
