🎉Community Raffle - Win $25
Join and Win
"Installing Rapid Analytics on Ubuntu 104.4"
User: "alanb"
New Altair Community Member
Updated by Jocelyn
Hi
I would like to install Rapid Analytics on Ubuntu 10.04.4 (this is the only config I have access to) can someone point me to some documentation on how to do this or what are the prerequisites. Do I need to have rapid miner installed before I can install Rapid Analytics ? Any help or documentation is much appreciated.
Thanks
-A
1 - 3 of 31
    User: "Marco_Boeck"
    Hi,
    you can download the latest version and install RapidAnalytics via the provided installer by just following the instructions.
    Regards,
    Marco
    User: "alanb"
    OP
    Thanks for your swift response I have had lots of problems so im starting the installation process again from scratch.
    A few questions
    Is the rapid miner application a pre requisite to installing rapid analytics?
    If so can you installing rapid miner from the command line as I am using a headless server?
    Thanks
    Alan
    User: "Marco_Boeck"
    Hi,
    RapidAnalytics uses its own RapidMiner version, so you do not need to have it installed before you install RapidAnalytics. You can install RapidAnalytics on a headless server via command line, however it requires you to go through the GUI-based installation process (w/o actually installing it) once to generate the config script needed on the server for headless installation (check the generate config script checkbox in the last installer step and uncheck the install RA checkbox). When you then start the installer via command line on the server, just pass "help" as a parameter for help.
    Regards,
    Marco
