"Read Excel and Data Import Error Unable to Recognize OLE Stream"
Hi,
i have problems reading Excel files. I've tested simple single procedure with Read Excel operator working with file forced to be saved in Excel 97/2003 and it works ok.
But I should have to loop to read many of them (some hundrends) and they are named .xls (but i think they are in Excel 2007/2010 new format) and i don't have any other way to save them.
When i try to test reading one of them i got Data Import Error that says "Error occurred importing ...filename... jxl.read.biff.BiffException: Unable to recognize OLE Stream".
Is there any step to solve the problem without converting all the hundreds of input files i have?
Thanks a lot
Thanks a lot
1 - 4 of
41
Would it be an option to rename all files and then run the RapidMiner process? Of course that would not have to happen by hand, but you can also use RapidMiner or some command line magic to batch-rename all files.
Best regards,
Marius
