Problem distributing a NetBeans application that integrates with RapidMiner
Hi everyone!
I am trying to integrate rapidminer with java. I use NetBeans.
I load the rapidminer.jar and I can initialize RapidMiner properly by using Rapidminer.init(). Then, I successfuly load and run a process and get the results back.
However, this only runs successfuly in NetBeans. When I do a cleanbuild of the app, the end result is a single .jar for my application, along with a lib folder that contains the rapidminer.jar. When I open the application's jar RapidMiner won't initialize. Therefore, I can run my program only through NetBeans and I can't distribute it.
Any ideas why this might be? I tried setting the home directory and the rc file with the following code (because the wiki recommended something like that), because I thought that maybe the rapidminer.jar tries to look for some folders and libraries relative to the .jar's path. However, this didn't fix the problem. RapidMiner will still not initialize.
<code>
ParameterService.init();
System.setProperty("rapidminer.home", "C:\\Program Files\\Rapid-I\\RapidMiner5");
System.setProperty(RapidMiner.PROPERTY_RAPIDMINER_RC_FILE,
"C:\\Program Files\\Rapid-I\\RapidMiner5\\resources\\com\\rapidminer\\resources\\rapidminerrc");
</code>
Thank you in advance for any help/assistance. I tried going through the forum and I also looked at the rapidminer wiki, but I couldn't solve this problem 2 days now. I wonder whether it has something to do with NetBeans and not RapidMiner.
Ideally, I'd like to be able to distribute my app without having to install RapidMiner on a new computer. I thought that I could simply include the .jar and set the home and the rc file.
<code>
</code>
1 - 5 of
51
Hi,
with the latest development version there is a rm.log file in the .RapidMiner5 folder, however as we are currently migrating to Git I don't think the latest development version is available for everyone right now. So you will have to resort to starting the .jar via commandline and see what errors you get there.
Regards,
Marco
Regards,
Marco
Marco, thank you for the advice. Here is the output. It seems the main error is "Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: com/rapid_i/Launcher"
***********************************8
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
c:\dist>java -jar LostDaysPrediction.jar
╔ΎΫΊ 03, 2013 1:02:31 ╠╠ com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Jun 03, 2013 1:02:38 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
_i/Launcher
at com.rapidminer.tools.ParameterService.ensureRapidMinerHomeSet(Paramet
erService.java:505)
at com.rapidminer.RapidMiner.init(RapidMiner.java:532)
at lostdaysprediction.MainForm.jButton2ActionPerformed(MainForm.java:394
at lostdaysprediction.MainForm.access$100(MainForm.java:35)
at lostdaysprediction.MainForm$10.actionPerformed(MainForm.java:205)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Sour
ce)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Sour
ce)
ce)
at java.awt.EventQueue$4.run(Unknown Source)
ce)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: com.rapid_i.Launcher
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
... 41 more
_i/Launcher
erService.java:505)
ce)
ce)
ce)
ce)
... 41 more
Hi,
seems you are not having all the .jar files RapidMiner needs in your own .jar, in this particular case the launcher.jar is missing. You will notice when looking at a RapidMiner installation that the lib folder of it contains quite a few .jar files, depending on what you do with RapidMiner they are all needed for RM to function correctly.
Regards,
Marco
Regards,
Marco
the description "RapidMiner does not initialize" is not very descriptive
What is the error you are getting?
Also please note that when integrating RapidMiner, your application has to be licensed under the AGPL (or you need to buy an OEM license if you do not want your sourcecode to be open source).
Regards,
Marco
