🎉Community Raffle - Win $25
Join and Win
"distance measures between-clusters"
User: "MarcosRL"
New Altair Community Member
Updated by Jocelyn
Hello friends of the community:
One question:
I need to calculate the distance between the clusters centroids to determine the distance from one cluster to another, is there this operator in rapid miner?
regards
1 - 2 of 21
    User: "marcin_blachnik"
    Hi
    You can use Extract Cluster Prototypes to get the centroids as an ExampleSet and then use one of the operators from Similarity Computation in Modeling folder. If you need a value of the distance you can use for example the Data to Similarity operator.
    Best
    Marcin
    User: "MarcosRL"
    OP
    Hello marcin.blachnik, Thanks for your answer
    I did find an example in the forum, the problem is that I can not interpret the results. I have four (4) documents to clustering with k-means and use k = 2 and get the following result:
    In output (Cross Distances ExampleSet)
    row  - request - document - distances
    1 1.0 1.0 0.012
    2 2.0 1.0 0.012
    3 3.0 1.0 0.012
    4 4.0 1.0 0.012
    5 2.0 2.0 0.016
    6 3.0 2.0 0.016
    7 4.0 2.0 0.016
    8 1.0 2.0 0.016
    How I can get the value of the centroids and the difference between them?
    What are the request and because I have four values ​​if I have only two clusters?
    attached the xml  process
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.2.008">
     <context>
       <input/>
       <output/>
       <macros/>
     </context>
     <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process">
       <parameter key="send_mail" value="always"/>
       <parameter key="notification_email" value="marcoslozina@gmail.com"/>
       <process expanded="true" height="404" width="681">
         <operator activated="true" class="text:process_document_from_file" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="75">
           <list key="text_directories">
             <parameter key="doc1" value="C:\Users\marcos\doc1"/>
             <parameter key="doc2" value="C:\Users\marcos\doc2"/>
             <parameter key="doc3" value="C:\Users\marcos\doc3"/>
             <parameter key="doc4" value="C:\Users\marcos\doc4"/>
           </list>
           <parameter key="prune_above_rank" value="0.05"/>
           <process expanded="true" height="415" width="758">
             <operator activated="true" class="text:transform_cases" compatibility="5.3.000" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="30"/>
             <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize" width="90" x="45" y="120"/>
             <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.000" expanded="true" height="76" name="Filter stopwords_pronombres_preposiciones" width="90" x="45" y="210">
               <parameter key="file" value="C:\Users\marcos\Desktop\stopwords\stopwords_pronombres_preposiciones.txt"/>
             </operator>
             <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.000" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="179" y="30"/>
             <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.3.000" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="179" y="120">
               <parameter key="max_length" value="4"/>
             </operator>
             <operator activated="true" class="text:filter_tokens_by_content" compatibility="5.3.000" expanded="true" height="60" name="Filter Tokens (by Content)" width="90" x="179" y="210">
               <parameter key="condition" value="matches"/>
               <parameter key="regular_expression" value="word1|word2|"/>
             </operator>
             <connect from_port="document" to_op="Transform Cases" to_port="document"/>
             <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
             <connect from_op="Tokenize" from_port="document" to_op="Filter stopwords_pronombres_preposiciones" to_port="document"/>
             <connect from_op="Filter stopwords_pronombres_preposiciones" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
             <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
             <connect from_op="Generate n-Grams (Terms)" from_port="document" to_op="Filter Tokens (by Content)" to_port="document"/>
             <connect from_op="Filter Tokens (by Content)" from_port="document" to_port="document 1"/>
             <portSpacing port="source_document" spacing="0"/>
             <portSpacing port="sink_document 1" spacing="0"/>
             <portSpacing port="sink_document 2" spacing="0"/>
           </process>
         </operator>
         <operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="179" y="165">
           <parameter key="max_runs" value="100"/>
           <parameter key="determine_good_start_values" value="true"/>
           <parameter key="measure_types" value="NumericalMeasures"/>
           <parameter key="numerical_measure" value="CosineSimilarity"/>
         </operator>
         <operator activated="true" class="extract_prototypes" compatibility="5.2.008" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="342" y="47"/>
         <operator activated="true" class="cross_distances" compatibility="5.2.008" expanded="true" height="94" name="Cross Distances" width="90" x="380" y="165">
           <parameter key="only_top_k" value="true"/>
           <parameter key="k" value="8"/>
           <parameter key="compute_similarities" value="true"/>
         </operator>
         <connect from_op="Process Documents from Files" from_port="example set" to_op="Clustering" to_port="example set"/>
         <connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/>
         <connect from_op="Clustering" from_port="clustered set" to_op="Cross Distances" to_port="request set"/>
         <connect from_op="Extract Cluster Prototypes" from_port="example set" to_op="Cross Distances" to_port="reference set"/>
         <connect from_op="Cross Distances" from_port="result set" to_port="result 1"/>
         <connect from_op="Cross Distances" from_port="request set" to_port="result 2"/>
         <connect from_op="Cross Distances" from_port="reference set" to_port="result 3"/>
         <portSpacing port="sink_result 3" spacing="0"/>
         <portSpacing port="sink_result 4" spacing="0"/>
       </process>
     </operator>
    </process>
    would need to get some distance indicator to know that clusters are closer
    thank you very much
    regards
