<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <parameter key="send_mail" value="always"/> <parameter key="notification_email" value="marcoslozina@gmail.com"/> <process expanded="true" height="404" width="681"> <operator activated="true" class="text:process_document_from_file" compatibility="5.3.000" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="75"> <list key="text_directories"> <parameter key="doc1" value="C:\Users\marcos\doc1"/> <parameter key="doc2" value="C:\Users\marcos\doc2"/> <parameter key="doc3" value="C:\Users\marcos\doc3"/> <parameter key="doc4" value="C:\Users\marcos\doc4"/> </list> <parameter key="prune_above_rank" value="0.05"/> <process expanded="true" height="415" width="758"> <operator activated="true" class="text:transform_cases" compatibility="5.3.000" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="30"/> <operator activated="true" class="text:tokenize" compatibility="5.3.000" expanded="true" height="60" name="Tokenize" width="90" x="45" y="120"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.3.000" expanded="true" height="76" name="Filter stopwords_pronombres_preposiciones" width="90" x="45" y="210"> <parameter key="file" value="C:\Users\marcos\Desktop\stopwords\stopwords_pronombres_preposiciones.txt"/> </operator> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.3.000" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="179" y="30"/> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.3.000" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="179" y="120"> <parameter key="max_length" value="4"/> </operator> <operator activated="true" class="text:filter_tokens_by_content" compatibility="5.3.000" expanded="true" height="60" name="Filter Tokens (by Content)" width="90" x="179" y="210"> <parameter key="condition" value="matches"/> <parameter key="regular_expression" value="word1|word2|"/> </operator> <connect from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter stopwords_pronombres_preposiciones" to_port="document"/> <connect from_op="Filter stopwords_pronombres_preposiciones" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_op="Filter Tokens (by Content)" to_port="document"/> <connect from_op="Filter Tokens (by Content)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="179" y="165"> <parameter key="max_runs" value="100"/> <parameter key="determine_good_start_values" value="true"/> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CosineSimilarity"/> </operator> <operator activated="true" class="extract_prototypes" compatibility="5.2.008" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="342" y="47"/> <operator activated="true" class="cross_distances" compatibility="5.2.008" expanded="true" height="94" name="Cross Distances" width="90" x="380" y="165"> <parameter key="measure_types" value="NumericalMeasures"/> <parameter key="numerical_measure" value="CosineSimilarity"/> <parameter key="only_top_k" value="true"/> <parameter key="k" value="8"/> <parameter key="compute_similarities" value="true"/> </operator> <connect from_op="Process Documents from Files" from_port="example set" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Cross Distances" to_port="request set"/> <connect from_op="Extract Cluster Prototypes" from_port="example set" to_op="Cross Distances" to_port="reference set"/> <connect from_op="Cross Distances" from_port="result set" to_port="result 1"/> <connect from_op="Cross Distances" from_port="request set" to_port="result 2"/> <connect from_op="Cross Distances" from_port="reference set" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
