🎉Community Raffle - Win $25
Join and Win
"Rapid miner with java"
User: "learner"
New Altair Community Member
Updated by Jocelyn
I have the following process built in rapidminer using applymodel:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.3.000">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true" height="424" width="758">
      <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve TrainingData" width="90" x="112" y="75">
        <parameter key="repository_entry" value="//Local Repository/data/TrainingData"/>
      </operator>
      <operator activated="true" class="retrieve" compatibility="5.3.000" expanded="true" height="60" name="Retrieve UserInput" width="90" x="112" y="210">
        <parameter key="repository_entry" value="//Local Repository/data/UserInput"/>
      </operator>
      <operator activated="true" class="default_model" compatibility="5.3.000" expanded="true" height="76" name="Default Model" width="90" x="313" y="75">
        <parameter key="method" value="median"/>
        <parameter key="constant" value="0.0"/>
        <parameter key="attribute_name" value=""/>
      </operator>
      <operator activated="true" class="apply_model" compatibility="5.3.000" expanded="true" height="76" name="Apply Model" width="90" x="313" y="210">
        <parameter key="create_view" value="false"/>
      </operator>
      <connect from_op="Retrieve TrainingData" from_port="output" to_op="Default Model" to_port="training set"/>
      <connect from_op="Retrieve UserInput" from_port="output" to_op="Apply Model" to_port="unlabelled data"/>
      <connect from_op="Default Model" from_port="model" to_op="Apply Model" to_port="model"/>
      <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
    </process>
  </operator>
</process>
I want to use this process in java.Below is the code :
RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE);
RapidMiner.init();
try {
File processFile = new File("\\Local Repository\processes\TrainingDataProcess.rmp");
Process process = new Process(processFile);
IOContainer ioResult = process.run();
if (ioResult.getElementAt(0) instanceof ExampleSet) {
ExampleSet resultSet = (ExampleSet)ioResult.getElementAt(0);
System.out.println("Success readresultSet: "+resultSet);
} catch (Exception e) {
RapidMiner.quit(RapidMiner.ExitMode.ERROR);
when I run the program, get back the header information but not the actual result set. am I missing something. Thank you for the help in advance
1 - 6 of 61
    User: "aborg"
    Maybe this thread will help?
    User: "learner"
    OP
    Thank you for the help. But Still doesnt work. when I run the process in Rapidminer, I get back 4 records. But when I run in java see only header information also says ' java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
    ' if I tried doing ExampleSet es = (ExampleSet) ioResult.getElementAt(1);
    Any help is appreciated.
    User: "aborg"
    Do you have two outputs? The getElementAt using 0-based indexing. To go through the table you should use the iterator of the exampleset.
    User: "learner"
    OP
    Cpuld u please give an example, of how to get ExampleSet from the process and iterate through it.
    User: "aborg"
    I thought you already had the ExampleSet. (You mentioned only the header was printed.)
    So if you have it, this message gives an example how to iterate through it.
    User: "Marco_Boeck"
    Hi,
    you can only retrieve the number of result IOObjects your process delivers. In the process you posted there is only one connection to a process result port (bubble on the right side of the canvas). Therefore your IOContainer only contains one item.
    Regards,
    Marco
