🎉Community Raffle - Win $25
Join and Win
[SOLVED] Re: Installing Series Extension on RA
User: "Matthias"
New Altair Community Member
Updated by Jocelyn
Hi,
first, RA -> very nice software.
I installed the series extension on RA, like descripted at these post: http://rapid-i.com/rapidforum/index.php/topic,3127.0.html
After restarting the RA Server I could see the series extension 5.3.00 under "Extensions", but I couldn't see any series operators at "Avaiable Operators"?? When I start a prozess which includes a series operator there will be a failure, because of the missing operator.
The series extension 5.2.0 doesn't work too.
If I copied, for example, the reporting or text mining extension into the plugin directory, restart the RA server everything works fine. I could see these operators at the "Avaiable Operators" flag and processes, including a reporting or text mining operator, working fine.
Great mistery
Greatings Matthias
1 - 4 of 41
    User: "Nils_Woehler"
    Hi Matthias,
    could you please post the boot.log of your RapidAnalytics server?
    Best,
    Nils
    User: "Matthias"
    OP
    Hi,
    The first part of the boot.log:
    Calling C:\RapidMinerAnalytics\bin\run.conf.bat
     JBoss Bootstrap Environment
     JBOSS_HOME: C:\RapidMinerAnalytics
     JAVA: C:\Progra~2\Java\jre7\bin\java
     JAVA_OPTS: -Dprogram.name=run.bat -Xms128M -Xmx1024M -XX:MaxPermSize=256M -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Dorg.jboss.resolver.warning=true
     CLASSPATH: C:\RapidMinerAnalytics\bin\run.jar
    22:41:18,873 INFO  [AbstractJBossASServerBase] Server Configuration:
    JBOSS_HOME URL: file:/C:/RapidMinerAnalytics/
    Bootstrap: $JBOSS_HOME\server/default/conf/bootstrap.xml
    Common Base: $JBOSS_HOME\common/
    Common Library: $JBOSS_HOME\common/lib/
    Server Name: default
    Server Base: $JBOSS_HOME\server/
    Server Library: $JBOSS_HOME\server/default/lib/
    Server Config: $JBOSS_HOME\server/default/conf/
    Server Home: $JBOSS_HOME\server/default/
    Server Data: $JBOSS_HOME\server/default/data/
    Server Log: $JBOSS_HOME\server/default/log/
    Server Temp: $JBOSS_HOME\server/default/tmp/
    22:41:18,875 INFO  [AbstractServer] Starting: JBossAS [6.0.0.Final "Neo"]
    22:41:20,045 INFO  [ServerInfo] Java version: 1.7.0_17,Oracle Corporation
    22:41:20,045 INFO  [ServerInfo] Java Runtime: Java(TM) SE Runtime Environment (build 1.7.0_17-b02)
    22:41:20,047 INFO  [ServerInfo] Java VM: Java HotSpot(TM) Client VM 23.7-b01,Oracle Corporation
    22:41:20,047 INFO  [ServerInfo] OS-System: Windows Server 2008 R2 6.1,x86
    22:41:20,047 INFO  [ServerInfo] VM arguments: -Dprogram.name=run.bat -Xms128M -Xmx1024M -XX:MaxPermSize=256M -Dsun.rmi.dgc.client.gcInterval=3600000 -Dsun.rmi.dgc.server.gcInterval=3600000 -Dorg.jboss.resolver.warning=true -Djava.endorsed.dirs=C:\RapidMinerAnalytics\lib\endorsed
    22:41:20,065 INFO  [JMXKernel] Legacy JMX core initialized
    22:41:26,144 INFO  [AbstractServerConfig] JBoss Web Services - Stack CXF Server 3.4.1.GA
    22:41:26,158 WARN  [AbstractKernelController] Broken callback: ClassSingleCallbackItem@8e45b{name=interface org.jboss.wsf.spi.metadata.DescriptorProcessor whenRequired=ControllerState@1289503{Installed} dependentState=ControllerState@1289503{Installed} attributeName=setProcessor owner=AbstractKernelControllerContext@127043{ metadata=AbstractBeanMetaData@d03c4d{name=JMSDescriptorDeployer bean=org.jboss.webservices.integration.deployers.JMSDescriptorDeployer properties= classLoader=BeanMetaDataDeployer$DeploymentClassLoaderMetaData@ebb27a{classloader=null} constructor=null autowireCandidate=true installCallbacks=[method=setProcessor, method=setParser]}name=JMSDescriptorDeployer target=org.jboss.webservices.integration.deployers.JMSDescriptorDeployer@1c81ca3 state=Installed depends=AbstractDependencyInfo@127202b{}} signature=org.jboss.wsf.spi.metadata.DescriptorProcessor}: java.lang.ClassCastException: org.jboss.wsf.framework.deployment.jms.WebservicesDescriptorProcessorImpl cannot be cast to org.jboss.wsf.spi.metadata.jms.JMSDescriptorProcessor
    22:41:26,268 WARN  [AbstractKernelController] Broken callback: ClassSingleCallbackItem@5ed711{name=interface org.jboss.wsf.spi.metadata.DescriptorProcessor whenRequired=ControllerState@1289503{Installed} dependentState=ControllerState@1289503{Installed} attributeName=setProcessor owner=AbstractKernelControllerContext@60753{ metadata=AbstractBeanMetaData@1bf9c8{name=WSDescriptorDeployer bean=org.jboss.webservices.integration.deployers.WSDescriptorDeployer properties= classLoader=BeanMetaDataDeployer$DeploymentClassLoaderMetaData@5fc710{classloader=null} constructor=null autowireCandidate=true installCallbacks=[method=setProcessor, method=setParser]}name=WSDescriptorDeployer target=org.jboss.webservices.integration.deployers.WSDescriptorDeployer@1299cbf state=Installed depends=AbstractDependencyInfo@abe28e{}} signature=org.jboss.wsf.spi.metadata.DescriptorProcessor}: java.lang.ClassCastException: org.jboss.wsf.stack.cxf.deployment.jms.JMSDescriptorProcessorImpl cannot be cast to org.jboss.wsf.spi.metadata.webservices.WebservicesDescriptorProcessor
    22:41:26,477 ERROR [STDERR] SLF4J: Class path contains multiple SLF4J bindings.
    22:41:26,486 ERROR [STDERR] SLF4J: Found binding in [vfs:/C:/RapidMinerAnalytics/common/lib/slf4j-jboss-logmanager.jar/org/slf4j/impl/StaticLoggerBinder.class]
    22:41:26,486 ERROR [STDERR] SLF4J: Found binding in [vfs:/C:/RapidMinerAnalytics/server/default/lib/slf4j-simple-1.6.4.jar/org/slf4j/impl/StaticLoggerBinder.class]
    22:41:26,488 ERROR [STDERR] SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
    22:41:26,518 ERROR [STDERR] 26 [JBossWS-CXF-DefaultBus-Init] INFO org.jboss.wsf.stack.cxf.client.configuration.JBossWSBusApplicationContext - Refreshing org.jboss.wsf.stack.cxf.client.configuration.JBossWSBusApplicationContext@1dc1b3: startup date [Thu Mar 21 22:41:26 CET 2013]; root of context hierarchy
    22:41:26,642 INFO  [JSFImplManagementDeployer] Initialized 4 JSF configurations: [Mojarra-2.1.7, Mojarra-1.2, MyFaces-2.0, Mojarra-2.0]
    22:41:26,683 ERROR [STDERR] 191 [JBossWS-CXF-DefaultBus-Init] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@f0776c: defining beans []; root of factory hierarchy
    22:41:26,683 ERROR [STDERR] 191 [JBossWS-CXF-DefaultBus-Init] INFO org.jboss.wsf.stack.cxf.client.configuration.JBossWSBusApplicationContext - Refreshing org.jboss.wsf.stack.cxf.client.configuration.JBossWSBusApplicationContext@1dc1b3: startup date [Thu Mar 21 22:41:26 CET 2013]; root of context hierarchy
    22:41:26,683 ERROR [STDERR] 191 [JBossWS-CXF-DefaultBus-Init] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Destroying singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@f0776c: defining beans []; root of factory hierarchy
    22:41:26,729 ERROR [STDERR] 236 [JBossWS-CXF-DefaultBus-Init] INFO org.apache.cxf.bus.spring.ControlledValidationXmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/jbossws-cxf.xml]
    22:41:26,906 ERROR [STDERR] 414 [JBossWS-CXF-DefaultBus-Init] INFO org.apache.cxf.bus.spring.ControlledValidationXmlBeanDefinitionReader - Loading XML bean definitions from URL [vfs:/C:/RapidMinerAnalytics/server/default/deployers/jbossws.deployer/jbossws-cxf-client.jar/META-INF/cxf/cxf-extension-jbossws.xml]
    22:41:27,196 ERROR [STDERR] 704 [JBossWS-CXF-DefaultBus-Init] INFO org.apache.cxf.bus.spring.ControlledValidationXmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf-extension-httpserver.xml]
    22:41:27,196 ERROR [STDERR] 704 [JBossWS-CXF-DefaultBus-Init] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Overriding bean definition for bean 'org.apache.cxf.transport.http.policy.HTTPClientAssertionBuilder': replacing [Generic bean: class [org.apache.cxf.transport.http.policy.HTTPClientAssertionBuilder]; scope=; abstract=false; lazyInit=true; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [vfs:/C:/RapidMinerAnalytics/common/lib/cxf-rt-transports-http.jar/META-INF/cxf/cxf-extension-http.fixml]] with [Generic bean: class [org.apache.cxf.transport.http.policy.HTTPClientAssertionBuilder]; scope=; abstract=false; lazyInit=true; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [vfs:/C:/RapidMinerAnalytics/common/lib/cxf-rt-transports-http.jar/META-INF/cxf/cxf-extension-http.fixml]]
    22:41:27,196 ERROR [STDERR] 704 [JBossWS-CXF-DefaultBus-Init] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Overriding bean definition for bean 'org.apache.cxf.transport.http.policy.HTTPServerAssertionBuilder': replacing [Generic bean: class [org.apache.cxf.transport.http.policy.HTTPServerAssertionBuilder]; scope=; abstract=false; lazyInit=true; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [vfs:/C:/RapidMinerAnalytics/common/lib/cxf-rt-transports-http.jar/META-INF/cxf/cxf-extension-http.fixml]] with [Generic bean: class [org.apache.cxf.transport.http.policy.HTTPServerAssertionBuilder]; scope=; abstract=false; lazyInit=true; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [vfs:/C:/RapidMinerAnalytics/common/lib/cxf-rt-transports-http.jar/META-INF/cxf/cxf-extension-http.fixml]]
    22:41:27,196 ERROR [STDERR] 704 [JBossWS-CXF-DefaultBus-Init] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Overriding bean definition for bean 'org.apache.cxf.transport.http.policy.NoOpPolicyInterceptorProvider': replacing [Generic bean: class [org.apache.cxf.transport.http.policy.NoOpPolicyInterceptorProvider]; scope=; abstract=false; lazyInit=true; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [vfs:/C:/RapidMinerAnalytics/common/lib/cxf-rt-transports-http.jar/META-INF/cxf/cxf-extension-http.fixml]] with [Generic bean: class [org.apache.cxf.transport.http.policy.NoOpPolicyInterceptorProvider]; scope=; abstract=false; lazyInit=true; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [vfs:/C:/RapidMinerAnalytics/common/lib/cxf-rt-transports-http.jar/META-INF/cxf/cxf-extension-http.fixml]]
    22:41:27,196 ERROR [STDERR] 704 [JBossWS-CXF-DefaultBus-Init] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Overriding bean definition for bean 'org.apache.cxf.transport.http.ClientOnlyHTTPTransportFactory': replacing [Generic bean: class [org.apache.cxf.transport.http.ClientOnlyHTTPTransportFactory]; scope=; abstract=false; lazyInit=true; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [vfs:/C:/RapidMinerAnalytics/common/lib/cxf-rt-transports-http.jar/META-INF/cxf/cxf-extension-http.fixml]] with [Generic bean: class [org.apache.cxf.transport.http.ClientOnlyHTTPTransportFactory]; scope=; abstract=false; lazyInit=true; autowireMode=0; dependencyCheck=0; autowireCandidate=true; primary=false; factoryBeanName=null; factoryMethodName=null; initMethodName=null; destroyMethodName=null; defined in URL [vfs:/C:/RapidMinerAnalytics/common/lib/cxf-rt-transports-http.jar/META-INF/cxf/cxf-extension-http.fixml]]
    22:41:27,435 ERROR [STDERR] 943 [JBossWS-CXF-DefaultBus-Init] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1c4b046: defining beans [cxf,org.apache.cxf.bus.spring.BusApplicationListener,org.apache.cxf.bus.spring.BusWiringBeanFactoryPostProcessor,org.apache.cxf.bus.spring.Jsr250BeanPostProcessor,org.apache.cxf.bus.spring.BusExtensionPostProcessor,org.apache.cxf.resource.ResourceManager,org.apache.cxf.configuration.Configurer,org.apache.cxf.binding.BindingFactoryManager,org.apache.cxf.transport.DestinationFactoryManager,org.apache.cxf.transport.ConduitInitiatorManager,org.apache.cxf.wsdl.WSDLManager,org.apache.cxf.phase.PhaseManager,org.apache.cxf.workqueue.WorkQueueManager,org.apache.cxf.buslifecycle.BusLifeCycleManager,org.apache.cxf.endpoint.ServerRegistry,org.apache.cxf.endpoint.ServerLifeCycleManager,org.apache.cxf.endpoint.ClientLifeCycleManager,org.apache.cxf.transports.http.QueryHandlerRegistry,org.apache.cxf.endpoint.EndpointResolverRegistry,org.apache.cxf.headers.HeaderManager,org.apache.cxf.catalog.OASISCatalogManager,org.apache.cxf.service.factory.FactoryBeanListenerManager,org.apache.cxf.endpoint.ServiceContractResolverRegistry,org.apache.cxf.binding.http.HttpBindingFactory,org.apache.cxf.binding.object.ObjectBindingFactory,org.apache.cxf.binding.soap.SoapBindingFactory,org.apache.cxf.binding.soap.SoapTransportFactory,org.apache.cxf.binding.soap.customEditorConfigurer,org.apache.cxf.binding.xml.XMLBindingFactory,org.apache.cxf.jaxws.context.WebServiceContextResourceResolver,org.apache.cxf.jaxws.context.WebServiceContextImpl,org.apache.cxf.management.InstrumentationManager,org.apache.cxf.transport.http.policy.HTTPClientAssertionBuilder,org.apache.cxf.transport.http.policy.HTTPServerAssertionBuilder,org.apache.cxf.transport.http.policy.NoOpPolicyInterceptorProvider,org.apache.cxf.transport.http.ClientOnlyHTTPTransportFactory,org.apache.cxf.transport.jms.JMSTransportFactory,org.apache.cxf.transport.local.LocalTransportFactory,org.apache.cxf.ws.addressing.policy.AddressingAssertionBuilder,org.apache.cxf.ws.addressing.policy.AddressingPolicyInterceptorProvider,org.apache.cxf.ws.addressing.policy.UsingAddressingAssertionBuilder,org.apache.cxf.ws.policy.AssertionBuilderRegistry,org.apache.cxf.ws.policy.PolicyInterceptorProviderRegistry,org.apache.cxf.ws.policy.attachment.external.DomainExpressionBuilderRegistry,org.apache.cxf.ws.policy.attachment.external.EndpointReferenceDomainExpressionBuilder,org.apache.cxf.ws.policy.PolicyBuilder,org.apache.cxf.ws.policy.PolicyEngine,org.apache.cxf.ws.policy.attachment.wsdl11.Wsdl11AttachmentPolicyProvider,org.apache.cxf.ws.policy.attachment.ServiceModelPolicyProvider,org.apache.cxf.ws.policy.mtom.MTOMAssertionBuilder,org.apache.cxf.ws.policy.mtom.MTOMPolicyInterceptorProvider,org.apache.cxf.ws.rm.RMManager,org.apache.cxf.ws.rm.policy.RMPolicyInterceptorProvider,org.apache.cxf.ws.rm.policy.RMAssertionBuilder,org.apache.cxf.ws.security.policy.WSSecurityPolicyLoader,org.jboss.wsf.stack.cxf.addons.transports.httpserver.HttpServerTransportFactory]; root of factory hierarchy
    22:41:47,894 ERROR [STDERR] 21402 [Thread-2] INFO org.quartz.simpl.SimpleThreadPool - Job execution threads will use class loader of thread: Thread-2
    22:41:47,929 ERROR [STDERR] 21437 [Thread-2] INFO org.quartz.core.SchedulerSignalerImpl - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
    22:41:47,929 ERROR [STDERR] 21437 [Thread-2] INFO org.quartz.core.QuartzScheduler - Quartz Scheduler v.1.8.3 created.
    22:41:47,929 ERROR [STDERR] 21437 [Thread-2] INFO org.quartz.simpl.RAMJobStore - RAMJobStore initialized.
    22:41:47,938 ERROR [STDERR] 21446 [Thread-2] INFO org.quartz.core.QuartzScheduler - Scheduler meta-data: Quartz Scheduler (v1.8.3) 'JBossQuartzScheduler' with instanceId 'NON_CLUSTERED'
    22:41:47,938 ERROR [STDERR]   Scheduler class: 'org.quartz.core.QuartzScheduler' - running locally.
    22:41:47,938 ERROR [STDERR]   NOT STARTED.
    22:41:47,938 ERROR [STDERR]   Currently in standby mode.
    22:41:47,938 ERROR [STDERR]   Number of jobs executed: 0
    22:41:47,938 ERROR [STDERR]   Using thread pool 'org.quartz.simpl.SimpleThreadPool' - with 10 threads.
    22:41:47,938 ERROR [STDERR]   Using job-store 'org.quartz.simpl.RAMJobStore' - which does not support persistence. and is not clustered.
    22:41:47,938 ERROR [STDERR] 21446 [Thread-2] INFO org.quartz.impl.StdSchedulerFactory - Quartz scheduler 'JBossQuartzScheduler' initialized from an externally opened InputStream.
    22:41:47,938 ERROR [STDERR] 21446 [Thread-2] INFO org.quartz.impl.StdSchedulerFactory - Quartz scheduler version: 1.8.3
    22:41:47,938 ERROR [STDERR] 21446 [Thread-2] INFO org.quartz.core.QuartzScheduler - Scheduler JBossQuartzScheduler_$_NON_CLUSTERED started.
    22:41:49,098 INFO  [ConnectionFactoryBindingService] Bound ConnectionManager 'jboss.jca:service=DataSourceBinding,name=DefaultDS' to JNDI name 'java:DefaultDS'
    22:41:49,098 INFO  [PersistenceUnitDeployment] Starting persistence unit persistence.unit:unitName=jboss-ejb3-timerservice-mk2.jar#timerdb
    22:41:49,324 ERROR [STDERR] 22832 [Thread-2] INFO org.hibernate.annotations.common.Version - Hibernate Commons Annotations 3.2.0.Final
    22:41:49,340 ERROR [STDERR] 22848 [Thread-2] INFO org.hibernate.cfg.Environment - Hibernate 3.6.0.Final
    22:41:49,340 ERROR [STDERR] 22848 [Thread-2] INFO org.hibernate.cfg.Environment - hibernate.properties not found
    22:41:49,350 ERROR [STDERR] 22858 [Thread-2] INFO org.hibernate.cfg.Environment - Bytecode provider name : javassist
    22:41:49,358 ERROR [STDERR] 22866 [Thread-2] INFO org.hibernate.cfg.Environment - using JDK 1.4 java.sql.Timestamp handling
    22:41:49,470 ERROR [STDERR] 22978 [Thread-2] INFO org.hibernate.ejb.Version - Hibernate EntityManager 3.6.0.Final
    22:41:49,502 ERROR [STDERR] 23010 [Thread-2] INFO org.hibernate.ejb.Ejb3Configuration - Processing PersistenceUnitInfo [
    22:41:49,502 ERROR [STDERR] name: timerdb
    22:41:49,502 ERROR [STDERR] ...]
    Greatings
    Matthias
    Hi,
    please if the extension can be found with Java 6. Java7 is not fully supported by JBoss6.
    Furthermore the log seems to be fine. But I think some parts are missing. I was looking for this part:
    17:06:58,422 WARNING [rapidminer] Missing database driver class name for ODBC Bridge (e.g. Access)
    17:06:58,423 INFO  [rapidminer] JDBC driver net.sourceforge.jtds.jdbc.Driver not found. Probably the driver is not installed.
    17:06:58,424 INFO  [rapidminer] JDBC driver com.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
    17:06:58,424 INFO  [rapidminer] JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
    17:06:58,931 INFO  [ReportingInitializationServlet] Successfully replaced remote AdHoc-query operator with the local version
    17:06:58,931 INFO  [RapidMinerEJBImpl] Loaded plugins: []
    17:06:58,931 INFO  [RapidMinerEJBImpl] Initialised RapidMiner. Loaded 445 operators.
    17:06:58,932 INFO  [RapidMinerEJBImpl] Keeping file reading operators. Keep in mind: All users can access everything user 'nwoehler' can access. To disable these operators, set property com.rapidanalytics.disable_file_operators to true.
    17:06:58,967 INFO  [RapidMinerEJBImpl] Publishing 5 jdbc connection entires.
    17:06:58,968 INFO  [RapidMinerEJBImpl] Added enterprise repository factory to RepositoryManager.
    17:06:58,991 INFO  [RapidAnalyticsSetup] Singleton instance of de.rapidanalytics.RapidAnalyticsSetup created.
    17:06:59,002 INFO  [RepositoryEJBImpl] Initializing repository
    17:06:59,016 INFO  [RepositoryEJBImpl] Repository exists. Nothing to do.
    17:06:59,199 INFO  [ProcessJobEJBImpl] Initializing process dispatcher.
    Best,
    Nils
    User: "Matthias"
    OP
    Hi,
    after updating RA to 1.3.007 all extensions could be load ???
    Thanks for your support.
    Greatings
    Matthias
