🎉Community Raffle - Win $25
Join and Win
connecting python with rapidminer
User: "na"
New Altair Community Member
Updated by Jocelyn
hello
i am trying to connect my work in python programming language with rapidMiner
how can i do it ?
please any way to make it true
thank you
1 - 4 of 41
    User: "MariusHelf"
    Hi,
    you have at least two choices:
    - install RapidAnalytics, export your RapidMiner processes as webservice, and call the webservice from your python programm.
    - call RapidMiner via the command line from your python script
    - maybe there is even a python 2 java bridge? Then you could include the rapidminer.jar into your python code.
    Please remember that the RapidMiner/RapidAnalytics Community Edition is released under the AGPL, which requires that your problem must also be released under the very same license in all 3 cases mentioned above. If that is no option for you, you have to purchase an Enterprise Edition.
    Best regards,
    Marius
    User: "na"
    OP
    i appreciate that , thank you so much
    User: "wessel"
    You can use Jython in combination with Java fairly easy.
    http://www.jython.org/jythonbook/en/1.0/JythonAndJavaIntegration.html
    So if you use:
    jython -J-cp JAR1:JAR2
    when calling your Java script, then you can import RM classes into your python code.
    Best regards,
    Wessel
    User: "na"
    OP
    i am so thankful
