connecting python with rapidminer
na
hello
i am trying to connect my work in python programming language with rapidMiner
how can i do it ?
please any way to make it true
thank you
Developer
MariusHelf
you have at least two choices:
- install RapidAnalytics, export your RapidMiner processes as webservice, and call the webservice from your python programm.
- call RapidMiner via the command line from your python script
- maybe there is even a python 2 java bridge? Then you could include the rapidminer.jar into your python code.
Please remember that the RapidMiner/RapidAnalytics Community Edition is released under the AGPL, which requires that your problem must also be released under the very same license in all 3 cases mentioned above. If that is no option for you, you have to purchase an Enterprise Edition.
Best regards,
Marius
na
i appreciate that , thank you so much
wessel
You can use Jython in combination with Java fairly easy.
http://www.jython.org/jythonbook/en/1.0/JythonAndJavaIntegration.html
So if you use:
jython -J-cp JAR1:JAR2
when calling your Java script, then you can import RM classes into your python code.
Best regards,
Wessel
na
i am so thankful
