Altair RISE
Nominate Yourself Now!
Problem in using the API
User: "ravishankar"
New Altair Community Member
Updated by Jocelyn
Hi All,
I have successfully set up RA & RM at my end on a Windows machine with Jre6.
As explained in the Link http://rapid-i.com/content/view/25/48/ for checking in the src code, I completed that.
I can successfully run RapidMinerGUI from Eclipse.
I want to use the APIs to process a document with the wordnet libraries, So I have two questions, they are:
Is there built JAR and java API documentation available for the plugins in the RM?
Or am I supposed to check out the code and build at my end?
While building the source code at my end by checking out each project separately, I am getting multiple errors. What is the base java & system requirements for compiling it? I am using Jre 6 and compiler level 1.6.
1 - 1 of 11
