Altair RISE
Nominate Yourself Now!
Possible error in RapidMiner_Unuk rev 733
User: "daniel_thibault"
New Altair Community Member
Updated by Jocelyn
Just downloaded rev 733 and was in the process of updating my rev 708 when I ran across this odd difference:
The files in \resources\com\rapidminer\resources\buildingblocks have had their extensions change from .buildingblock to .buildingbloc. Even curiouser, buildingblocks.txt still lists them as *.buildingblock.
Here are some other truncated file names:
\src\com\rapid_i\deployment\update\client\listmodels\TopDownloadsPackageListModel.jav
\src\com\rapidminer\gui\new_plotter\configuration\AxisParallelLinesConfiguration.jav
\src\com\rapidminer\gui\new_plotter\configuration\AxisParallelLinesConfigurationListener.jav
\src\com\rapidminer\gui\new_plotter\configuration\EquidistantFixedBinCountBinning.jav
\src\com\rapidminer\gui\new_plotter\configuration\event\AxisParallelLinesConfigurationChangeEvent.jav
\src\com\rapidminer\gui\new_plotter\engine\jfreechart\actions\ManageParallelLinesAction.jav
\src\com\rapidminer\gui\new_plotter\engine\jfreechart\actions\AddParallelLineAction.jav
\src\com\rapidminer\gui\new_plotter\engine\jfreechart\actions\ClearParallelLinesAction.jav
instead of *.java
There are more.  Was my tarball corrupted weirdly by the svn server, or is this a real problem?
1 - 8 of 81
    OP
    A different problem crops up with rev 733 once imported into Eclipse.  One error, oodles of warnings.  The error is:
    The type DriverAdapter must implement the inherited abstract method Driver.getParentLogger() DriverAdapter.java /RapidMiner_Unuk/src/com/rapidminer/tools/jdbc line 40 Java Problem
    The missing method is in fact in the source code, but commented out.  Should it be uncommented?
    User: "aborg"
    I think your problem is related to using Java 7, which might cause problems, as the bundled JRE for RapidMiner (5.2) is a Java 6 VM. The referenced method is @since 1.7, so that is the reason it does not compile. (I think the next version will be based on Java 7.)
    User: "Skirzynski"
    I have checked out the latest SVN repository entry from Sourceforge, as well as the downloadable zip file and can not confirm any of your errors. Maybe there were some glitches in the Sourceforge Matrix...
    User: "Nils_Woehler"
    Hi,
    yes this method has to be implemented since Java 7. Currently we are working with Java 6.
    But the next release should depend on Java 7.
    Best,
    Nils
    OP
    I've added a "//@since 1.7" line to the DriverAdapter method in order to explain the "error" when I run into it. I've since configured Eclipse to use a Java 1.6 target.
    OP
    I've downloaded the rev 734 tarball and the problem recurred.  I think it is because of McAfee Web Gateway.  Our firewall uses MAWG, and when I download the tarball MAWG downloads it to its own private storage, scans it, and then allows me to download it.  I've always thought it gave a link to its original download, but maybe it unpacks the tarball, scans it, and then packs (incorrectly) a new copy for delivery to me.  Hard to be sure, but it's a good hypothesis.
    OP
    Could I get the SHA-1 or MD5 signatures of the rev 734 tarball so I can tell whether or not MAWG tampered with it?
    OP
    Maybe it's not MAWG after all. The tarball is fine when I open it using Ubuntu's Archive Manager.  But WinZip (14.5.9095) shortens extensions as I've mentioned earlier.  Weird.
