[SOLVED] Caching getParameterTypes?
I've noticed that the getParameterTypes method of my home-brew operator gets called quite often. It gets called during RapidMiner's startup, when it loads the plugins (fair enough), but also twice every time my operator is selected in the Operators palette of the GUI:
Any thoughts/warnings/caveats concerning the possibility of rewriting my getParameterTypes so that it caches the List<ParameterType> it builds the first time, in order to return the cached List when it gets called again? The cached values would be specific to each instance of the operator, right?
Nov 26, 2012 2:06:16 PM com.rapidminer.tools.WrapperLoggingHandler log
INFO: LTFDataReader: CachedLTFExampleSource.getParameterTypes begins.
Nov 26, 2012 2:06:29 PM com.rapidminer.tools.WrapperLoggingHandler log
INFO: LTFDataReader: CachedLTFExampleSource constructor done.
Nov 26, 2012 2:06:30 PM com.rapidminer.tools.WrapperLoggingHandler log
Nov 26, 2012 2:06:39 PM com.rapidminer.tools.WrapperLoggingHandler log
1 - 1 of
11
yes, getParameterTypes is called quite often. Because of this it should not take too long to finish.
If you want to cache your parameterTypes you could try to do something like this: And yes the cached values are specific for each instance of the operator.
Best,
Nils
