🎉Community Raffle - Win $25
Join and Win
[SOLVED] Trying to run RapidMiner (Unuk rev 708) in Eclipse
User: "daniel_thibault"
New Altair Community Member
Updated by Jocelyn
Following the instructions in "How to Extend RapidMiner 5", I've grabbed the RapidMiner_Extension_Template and RapidMiner_Extension_Tutorial and then RapidMiner_Unuk (rev 708), all within Eclipse (Juno SR1).  It took a lot of jar-adding to get the RapidMiner_Unuk project to compile, but it finally does.  Now, when I try to run RapidMinerGUI as a Java application, I get this exception:
Exception in thread "main" java.lang.ExceptionInInitializerError
Caused by: java.lang.NullPointerException
at java.io.Reader.<init>(Unknown Source)
at java.io.InputStreamReader.<init>(Unknown Source)
at java.util.Scanner.<init>(Unknown Source)
at com.rapidminer.RapidMiner.<clinit>(RapidMiner.java:311)
This happens in the RapidMiner class's initializer, when it hits this line:
Scanner scanLanguageDefs = new Scanner(RapidMiner.class.getResourceAsStream("/com/rapidminer/resources/i18n/language_definitions.txt"));
Apparently it can't find "/com/rapidminer/resources/i18n/language_definitions.txt", although I can't see why, since the file is indeed present in the "resources/" subdirectory of the Eclipse project directory (RapidMiner_Unuk).  If I wrap the offending lines in a try-catch block (which is acceptable, it just means the language defaults to English), initialization goes on a bit longer, then it chokes on another resource-fetch, in the LogService initializer:
private static final Logger GLOBAL_LOGGER = Logger.getLogger("com.rapidminer", "com.rapidminer.resources.i18n.LogMessages");
at com.rapidminer.gui.safemode.SafeMode.launchStarts(SafeMode.java:57)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:527)
Caused by: java.util.MissingResourceException: Can't find com.rapidminer.resources.i18n.LogMessages bundle
at java.util.logging.Logger.setupResourceInfo(Unknown Source)
at java.util.logging.Logger.getLogger(Unknown Source)
at com.rapidminer.tools.LogService.<clinit>(LogService.java:138)
... 2 more
Again, the resource "resources/com/rapidminer/resources/i18n/LogMessages.properties" is present.
By comparison, a similar Eclipse project I set up using the RapidMiner 5.2.008 distribution's src directory runs just fine although it does not have a resources/ directory.  One key difference is that I did add the RapidMiner 5.2.008 distribution's lib/rapidminer.jar to the project's Java build path.  If I try the same trick with RapidMiner_Unuk, it sorta works: I get to the welcome window but the icons are replaced by "gui.action.welcome.*" strings (clearly it can't find its resources).  The log is as follows:
nov. 07, 2012 5:05:31 PM com.rapidminer.gui.safemode.SafeMode launchStarts
INFO: com.rapidminer.gui.safemode.SafeMode.lock_left_behind
nov. 07, 2012 5:05:31 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Nov 07, 2012 5:05:31 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Nov 07, 2012 5:05:31 PM com.rapidminer.tools.I18N getMessage
WARNING: Missing I18N key: gui.dialog.confirm.safemode.enter_safe_mode.title
Nov 07, 2012 5:05:32 PM com.rapidminer.tools.I18N getMessage
WARNING: Missing I18N key: gui.dialog.confirm.safemode.enter_safe_mode.message
Nov 07, 2012 5:05:47 PM com.rapidminer.gui.safemode.SafeMode applySafeMode
INFO: com.rapidminer.gui.safemode.SafeMode.entering_safe_mode
Nov 07, 2012 5:05:47 PM com.rapidminer.RapidMiner performFirstInitialization
INFO: Performing upgrade  from version 5.2.008 to version 5.3.000
Nov 07, 2012 5:05:47 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: Property rapidminer.home is not set. Guessing.
INFO: Trying parent directory of 'C:\Program Files\Rapid-I\RapidMiner5\lib\launcher.jar'...gotcha!
INFO: Trying parent directory of 'C:\Program Files\Rapid-I\RapidMiner5\lib\rapidminer.jar'...gotcha!
Nov 07, 2012 5:05:56 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
Nov 07, 2012 5:06:07 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
Nov 07, 2012 5:06:07 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed.
[Fatal Error] :1:1: Premature end of file.
Nov 07, 2012 5:06:09 PM com.rapidminer.tools.I18N getMessage
WARNING: Missing I18N key: gui.action.run_remote_now.label
WARNING: Missing I18N key: gui.action.tour.label
WARNING: Missing I18N key: gui.action.clear_db_cache.label
Nov 07, 2012 5:06:10 PM com.rapidminer.tools.I18N getMessage
WARNING: Missing I18N key: gui.action.welcome.new.icon
WARNING: Missing I18N key: gui.action.welcome.new.label
WARNING: Missing I18N key: gui.action.welcome.new.tip
WARNING: Missing I18N key: gui.action.welcome.open_recent.icon
WARNING: Missing I18N key: gui.action.welcome.open_recent.label
WARNING: Missing I18N key: gui.action.welcome.open_recent.tip
WARNING: Missing I18N key: gui.action.welcome.open.icon
WARNING: Missing I18N key: gui.action.welcome.open.label
WARNING: Missing I18N key: gui.action.welcome.open.tip
WARNING: Missing I18N key: gui.action.welcome.wizard.icon
WARNING: Missing I18N key: gui.action.welcome.wizard.label
WARNING: Missing I18N key: gui.action.welcome.wizard.tip
WARNING: Missing I18N key: gui.action.welcome.tutorial.icon
WARNING: Missing I18N key: gui.action.welcome.tutorial.label
WARNING: Missing I18N key: gui.action.welcome.tutorial.tip
WARNING: Missing I18N key: gui.action.welcome.tour.icon
WARNING: Missing I18N key: gui.action.welcome.tour.label
WARNING: Missing I18N key: gui.action.welcome.tour.tip
Nov 07, 2012 5:06:11 PM com.rapidminer.tools.I18N getMessage
WARNING: Missing I18N key: gui.action.export_pdf.label
Nov 07, 2012 5:06:13 PM com.rapidminer.tools.I18N getMessage
Nov 07, 2012 5:06:14 PM com.rapidminer.tools.I18N getMessage
WARNING: Missing I18N key: gui.repository.not_accessible.message
WARNING: Missing I18N key: gui.action.link.label
WARNING: Missing I18N key: gui.dockkey.macro_viewer.name
WARNING: Missing I18N key: gui.dockkey.macro_viewer.tip
Nov 07, 2012 5:06:16 PM com.rapidminer.tools.I18N getMessage
WARNING: Missing I18N key: gui.progress.loading_documentation.label
No file exists
My mistake is probably a simple one, but which is it?
