Missing Operator Parameters
New Altair Community Member
Updated by Jocelyn
Hi,
I am facing a problem with declaring the parameters in the operators. I tried adding the parameters as per instructed by the guide but when I select the operator in Rapidminer,
only 4 out of the 6 parameters declared appears. The first two parameters has been ignored and not reflected in Rapidminer GUI. However, when I change the order when adding the parameters,
the boolean parameters appear but still only a max of 4 out 6 parameters are displayed.
Can anyone help me with this problem?
Thanks!
The codes to declare and add the parameters are shown below:
Thanks!
@Override
public List<ParameterType> getParameterTypes() {
List<ParameterType> types = super.getParameterTypes();
ParameterType type0 = new ParameterTypeBoolean(PARAMETER_AMPLIFY_POSITIVE, amplify_desc, true,false);
ParameterType type1= new ParameterTypeBoolean(PARAMETER_REDUCE_NEGATIVE, reduceNeg_desc, true,false);
ParameterType type2 = new ParameterTypeChar(PARAMETER_POSITIVE_LABEL, posLbl_desc,'P',false);
ParameterType type3 = new ParameterTypeDouble(PARAMETER_POSITIVE_GAUSSIAN_REMOVE_THRESHOLD, posGausRemovThres_desc, 0,1,0.95,false);
ParameterType type4 = new ParameterTypeDouble(PARAMETER_NEGATIVE_GAUSSIAN_REMOVE_THRESHOLD, negGausRemovThres, 0, 1, 0.95,false);
ParameterType type5 = new ParameterTypeDouble(PARAMETER_MTD_MEMBERSHIP_REMOVE_THRESHOLD, mtdAmpThres_desc,0, 1, 0.9,false);
types.add(type0);
types.add(type1);
types.add(type2);
types.add(type3);
types.add(type4);
types.add(type5);
return types;
1 - 3 of
31
MariusHelf
Did you accidentally set the same values for the PARAMTER_XXX constants?
Hi Marius,
Thanks for the reply!
The values for all the parameter constants are different , as shown in the codes below:
I still can't figure out what's wrong with it...
// Constants
// public
public static final String PARAMETER_POSITIVE_LABEL = "Input positive class label";
public static final String PARAMETER_POSITIVE_GAUSSIAN_REMOVE_THRESHOLD = "Input gaussian remove threshold for positive class";
public static final String PARAMETER_NEGATIVE_GAUSSIAN_REMOVE_THRESHOLD = "Input gaussian remove threshold for negative class";
public static final String PARAMETER_MTD_MEMBERSHIP_REMOVE_THRESHOLD = "Input threshold to keep newly synthetic generated data for the positive class";
public static final String PARAMETER_AMPLIFY_POSITIVE = "Input gaussian remove threshold for positive class";
public static final String PARAMETER_REDUCE_NEGATIVE = "Input gaussian remove threshold for negative class";
// Parameters description
public static final String posLbl_desc = "The positive class will be amplified, while the remaining class will be reduced";
public static final String posGausRemovThres_desc = "Outlier points in the positive class that is outside the threshold will be removed";
public static final String negGausRemovThres = "Outlier points in teh negative class that is outside the threshold will be removed";
public static final String mtdAmpThres_desc = "Newly generated points with threshold will be added into the amplified dataset";
public static final String amplify_desc = "Check to amplify the positive data set with MTD";
public static final String reduceNeg_desc = "Check to reduce the negative data set using SVM";
Well, that's odd. Just to exclude the basic cases:
Did you recompile and reinstall your extension after making the changes to the parameters?
Did you specify any parameter dependencies?
Do you inherit from another operator class, from where naming conflicts could arise?
Btw, one remark on the parameter names: by convention they should be all lower-case and contain underscores instead of spaces. But that does not influence the functionality.
