🎉Community Raffle - Win $25
Join and Win
Paren extension not loading
User: "bharath"
New Altair Community Member
Updated by Jocelyn
Hi All
I updated RapidMiner to 5.2.008 and installed PaRen extension (5.1.1) through update manager. Though it shows in my list of extensions (help>manage extensions) i neither see a 'automatic system construction' option under tools menu nor do i see the Landmarking operator. I tried uninstall/install several times. I also tried downloading the file from marketplace and pasting it in rapidminer extensions folder where i have other extensions.
Please help.
Thanks !!!
1 - 10 of 101
    User: "Nils_Woehler"
    Hi,
    I've just tested it myself and for me it is working.
    What other extension do you have installed? What system are you working on?
    Can you please start RapidMiner from Console and post the log here?
    Best,
    Nils
    User: "RWingerter"
    Hi,
    I do have 'Automatic System Construction' in the tools menu, but when I run it I get an error "java.lang.NULLPointerException".
    Here is the log from the console:
    ´Mar 16, 2013 10:44:03 PM com.rapidminer.gui.tools.ResourceAction addToActionMap
    WARNING: Cannot add action save_building_block to input map: no accelerator defi
    ned.
    WARNING: Cannot add action toggle_all_breakpoints to input map: no accelerator d
    efined.
    efined.
    Mar 16, 2013 10:45:31 PM com.rapidminer.tools.I18N getMessage
    WARNING: Missing I18N key: gui.dialog.step.regression.title
    WARNING: Missing I18N key: gui.dialog.step.evaluate.title
    WARNING: Missing I18N key: gui.dialog.classifier_recommender_wizard.icon
    Mar 16, 2013 10:45:48 PM com.rapidminer.tools.I18N getMessage
    Mar 16, 2013 10:45:48 PM com.rapidminer.operator.tools.ExampleSetToStream <init>
    WARNING: Using deprecated example set stream version 1
    java.lang.NullPointerException
           at de.dfki.madm.mlwizard.functionality.Regressioner.predict(Regressioner
    .java:58)
    .java:83)
           at de.dfki.madm.mlwizard.gui.RegressionWizardStep$2.doInBackground(Regre
    ssionWizardStep.java:190)
    ssionWizardStep.java:185)
           at javax.swing.SwingWorker$1.call(Unknown Source)
           at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
           at java.util.concurrent.FutureTask.run(Unknown Source)
           at javax.swing.SwingWorker.run(Unknown Source)
           at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
           at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
           at java.lang.Thread.run(Unknown Source)
    FWIW, I cannot see the Landmark operator.
    Roland
    Hi Roland,
    this extension is not maintained by Rapid-I. Can you please contact the author of the Paren Extension?
    http://marketplace.rapid-i.com/UpdateServer/faces/product_details.xhtml?productId=rmx_paren
    Best,
    Nils
    User: "RWingerter"
    Thank you for the pointer. Done.
    Roland
    User: "RWingerter"
    There was a problem in the Windows version which has been fixed by the author. The new version of ML Wizard (5.3.1) which is available in the RapidMiner MarketPlace works fine. Thank your for this excellent tool!
    Retegniw
    User: "rkbukows"
    My automatic system construction 5.3.1. works fine, but I do not see the landmarking operator.
    Radek
    User: "RWingerter"
    I don't see it either. Looks like it isn't surfaced any more. I will e-Mail the author of ML Wizard an inquire about it.
    Roland
    User: "earmijo"
    I downloaded it yesterday and it works perfectly.... in Mac/Linux. It still doesn't work for me in Windows. I still get the "Java Null pointer... blah blah" error.
    User: "RWingerter"
    Strange. Are you sure you have ML Wizard version 5.3.1 (check the version number in Help > Manage Extensions)? I have Windows 7, 64 bit and the new version of ML Wizard works fine for me, whereas the previous one didn't.
    Roland
    User: "faridehbagherza"
    Hi
    I  installed MLwizard extension (5.3.1) through update manager. It doesn`t appear in my list of extensions (help>manage extensions) . I neither see a 'automatic system construction' option under tools menu nor do i see the Landmarking operator. But in the Update and Extension Market place , it is written UP TO DATE.
    Any help please!!!!!
