"Scripts errors after sql table has been deleted"
RLynx
RLynx New Altair Community Member
edited November 2024 in Community Q&A
Hello,
After most recent upgrade I noticed this unpleasant behavior:
Correct and successfully working processes (which write data to a database)
are successful on the first attempt, but start throwing errors after I delete corresponding tables from database
and run these processes a second time.
Therefore, in order to run a process successfully again I have to reload a process file.
Thank you,
RLynx
Answers
  • Nils_Woehler
    Nils_Woehler New Altair Community Member
    Hi,
    what scripts do you mean? Did you use the 'Write Script' Operator to write your own script that writes to the database?
    Or did you set up a process with operators like 'Write Database'? If so please post your process like it is described here: http://rapid-i.com/rapidforum/index.php/topic,4654.0.html
    Best,
    Nils
  • RLynx
    I have corrected my question above - by "script" I meant "process".
    I use Write Database operators.
    Unfortunately, I can't post original process. I will try to recreate a simple example of the process with the same problem. Will keep you posted.
    Thank you!!
    RLynx
Welcome!
Welcome!
