🎉Community Raffle - Win $25
Join and Win
Error Apply Model [SOLVED]
User: "Danyo83"
New Altair Community Member
Updated by Jocelyn
Hi,
I have a classification problem wiht 2 classes. Unfortunately one cannot access the prediction label when using a Feature Selection process. So I saved the attributes weights and started a new process with the loaded weights. I applied the Model to the "unseen" testset and compared its performance with the performance of the FS Process which used the same weights. The performance of the applied Model is differs a lot to the testset performance of the FS process. Can you fix this bug and mabye offer a possibility to access the prediction label via the simple FS process.
Furthermore I have to report that when saving the Model in an XMl file or similar, and recalling it, the performance also differs a lot to the FS process Performance. Can you fix it?
Thanks in advance Daniel
