🎉Community Raffle - Win $25
Join and Win
[SOLVED] Transition Graph: Error creating renderer: java.lang.NullPointer...
chrismxnrUser: "chrismxnr"
New Altair Community Member
Updated by Jocelyn
Hello,
I want to use the Transition Graph Operator, but I'm not able to get it working. I have two string attributes containing my nodes (source and target) and an additional real-valued strength attribute.
After my first try I got the error message that an id-attribute is needed. I don't really get why an id is needed, but I just generated one. Now my process executes, but I can not view the graph, it shows: "Error creating renderer Graph View (see log)".
In the log there is "WARNING: Error creating renderer: java.lang.NullPointerException".
I'm not sure if it is a bug or I'm using it in a wrong manner, because I did not find examples using it. Can you help me?
Best regards,
Christian
1 - 5 of 51
    haddockUser: "haddock"
    Hi there,
    I think that operator is under review, see the recent posts here...
    http://rapid-i.com/rapidforum/index.php/topic,4381.msg15939.html#msg15939
    Hi,
    in fact this is an other operator and seems to be a bug. I have fixed it an it will be gone with the next RapidMiner update.
    Cheers,
    Nils
    Thank you very much for your fast fix :). I tried it with the current SVN version today and it runs fine. The only thing I still don't get is why an ID attribute is needed? Like I told I just generated one and now it runs fine with that, but I'm not sure if I use it correctly.
    Best regards,
    Christian
    Hi,
    the ID is used to filter attributes in the Graph view. You can select a source filter and all transitions from that source will be shown.
    The the correct way to use it is to set the role of the source attribute to ID I think.
    Here is an example process which works fine for me.
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.1.014">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.1.014" expanded="true" name="Process">
        <process expanded="true" height="386" width="949">
          <operator activated="true" class="generate_nominal_data" compatibility="5.1.014" expanded="true" height="60" name="Generate Nominal Data" width="90" x="56" y="161"/>
          <operator activated="true" class="rename" compatibility="5.1.014" expanded="true" height="76" name="Rename" width="90" x="179" y="165">
            <parameter key="old_name" value="att1"/>
            <parameter key="new_name" value="source"/>
            <list key="rename_additional_attributes"/>
          </operator>
          <operator activated="true" class="rename" compatibility="5.1.014" expanded="true" height="76" name="Rename (2)" width="90" x="320" y="161">
            <parameter key="old_name" value="att2"/>
            <parameter key="new_name" value="target"/>
          </operator>
          <operator activated="true" class="select_attributes" compatibility="5.1.014" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="165">
            <parameter key="attribute_filter_type" value="subset"/>
            <parameter key="attributes" value="|target|source"/>
            <parameter key="include_special_attributes" value="true"/>
          </operator>
          <operator activated="true" class="set_role" compatibility="5.1.014" expanded="true" height="76" name="Set Role" width="90" x="581" y="300">
            <parameter key="name" value="source"/>
            <parameter key="target_role" value="id"/>
            <list key="set_additional_roles"/>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="5.1.014" expanded="true" height="76" name="Generate Attributes" width="90" x="648" y="165">
            <list key="function_descriptions">
              <parameter key="strength" value="rand()*5"/>
            </list>
          </operator>
          <operator activated="true" class="transition_graph" compatibility="5.1.014" expanded="true" height="76" name="Transition Graph" width="90" x="782" y="120">
            <parameter key="source_attribute" value="source"/>
            <parameter key="target_attribute" value="target"/>
            <parameter key="strength_attribute" value="strength"/>
          </operator>
          <connect from_op="Generate Nominal Data" from_port="output" to_op="Rename" to_port="example set input"/>
          <connect from_op="Rename" from_port="example set output" to_op="Rename (2)" to_port="example set input"/>
          <connect from_op="Rename (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
          <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
          <connect from_op="Set Role" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_op="Transition Graph" to_port="example set"/>
          <connect from_op="Transition Graph" from_port="example set" to_port="result 1"/>
          <connect from_op="Transition Graph" from_port="transition graph" to_port="result 2"/>
          <portSpacing port="sink_result 3" spacing="0"/>
        </process>
      </operator>
    </process>
    Regards,
    Nils
    Ok I see. I just want to propose to change this behaviour, that the attribute which is already configured as "source attribute" is used in the "Source Filter" insted of using the id-attribute, which is confusing in my opinion.
    Anyway, my main problem is fixed now and I thank you very much for your fast reaction :).
    Best regards,
    Christian
