🎉Community Raffle - Win $25
Join and Win
"[SOLVED] Error: Content is not allowed in prolog"
User: "michaelhecht"
New Altair Community Member
Updated by Jocelyn
Hello,
I just started to try to implement RapidMiner into my own application. To make it easier for me I use Jython instead of Java,
which makes the code quite small:
import com.rapidminer.RapidMiner as RapidMiner
import com.rapidminer.Process as Process
import com.rapidminer.RapidMiner.ExecutionMode as ExecutionMode
RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE);
RapidMiner.init()
process = Process('D:/RapidMinerRepository/PolynomOptimierung.rmp')
result = process.run()
print result
On running it i get a problem in the Process-line:
Dec 8, 2011 7:56:26 AM com.rapid_i.Launcher ensureRapidMinerHomeSet
[Fatal Error] :1:1: Content is not allowed in prolog.
Traceback (most recent call last):
 File "jyRapid.py", line 7, in <module>
at com.rapidminer.Process.readProcess(Process.java:1080)
at com.rapidminer.Process.readProcess(Process.java:1055)
at com.rapidminer.Process.<init>(Process.java:254)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.python.core.PyReflectedConstructor.constructProxy(PyReflectedConstructor.java:210)
com.rapidminer.tools.XMLException: com.rapidminer.tools.XMLException: Cannot parse document: Content is not allowed in prolog.
The workflow works well in the GUI and in the forum I didn't find any solution, so how to fix it?
1 - 10 of 101
    User: "Nils_Woehler"
    Hi,
    please open your .rpm file with a text editor and check if there is any other character before the "<?xml..." part.
    If so remove it and try to run your application again. If there is no other character it has to be an encoding problem.
    Try to save the .rpm file with another enconding.
    Regards,
    Nils
    OP
    Checkign the XML was the first thing I did and it was OK. Meanwhile I added some Java XML-parsing and this works fine,
    if I use "UTF-8" but fails with the same error by using "UTF-16":
    # import necessary libraries
    import time
    # start up rapidminer
    start = time.time()
    RapidMiner.init()
    print "init done (%.1f sec)...\n" % (time.time()-start)
    # check wether Java can parse the XML file
    from java.io import FileInputStream
    from javax.xml.transform.stream import StreamSource
    from javax.xml.transform.stream import StreamResult
    from javax.xml.parsers import DocumentBuilderFactory
    factory  = DocumentBuilderFactory.newInstance()
    builder  = factory.newDocumentBuilder()
    input    = FileInputStream('D:/RapidMinerRepository/myprocess.xml')
    document = builder.parse(input)
    print 'First node is:',document.getDocumentElement().getNodeName()
    print "Java is done ...\n"
    # load the XML workflow for parsing and processing
    process = Process('D:/RapidMinerRepository/myprocess.xml')
    print "process loaded ...\n"
    # process workflow
    print "run finished ...\n"
    # print result information
    print "Result is:\n",result,'\n'
    Process(...) fails with both "UTF-8" and "UTF-16". Which coding I can test instead?
    OP
    Meanwihle I testes also "ISO-8895-1" and "windows-1252".
    The Java XML parser took both, Process(...) took none.
    OP
    Just to mention it: I'm working on Windows 7 64-bit and the Jython/Java version is also 64-bit, RapidMiner is "5.1.014" 64-bit.
    OP
    Here is the Java version, to be sure that it is not a problem of Jython (in fact: it isn't !):
    package jrapidminer;
    import com.rapidminer.RapidMiner;
    import com.rapidminer.RapidMiner.ExecutionMode;
    import com.rapidminer.Process;
    public class jRapidMiner
        public static void main(String[] args)
            String rapidMinerHome = "C:/Program Files/Rapid-I/RapidMiner5/";
            System.setProperty("rapidminer.home", rapidMinerHome);
            RapidMiner.init();
            try
                String workflow = "D:/RapidMinerRepository/myprocess.xml";
                Process process = new Process(workflow);
                process.run();
            } catch (Exception e) {
    and here is the output after execution:
    run:
    Dec 8, 2011 2:23:32 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
    INFO: rapidminer.home is 'C:/Program Files/Rapid-I/RapidMiner5/'.
    Dec 8, 2011 2:23:32 PM com.rapidminer.tools.ParameterService init
    INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
    Dec 8, 2011 2:23:34 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
    WARNING: Password in XML file looks like unencrypted plain text.
    Dec 8, 2011 2:23:36 PM com.rapidminer.tools.plugin.Plugin registerOperators
    INFO: No operator descriptor specified for plugin Community. Trying plugin initializtation class com.rapidminer.community.CommunityPluginInit.
    WARNING: No operator descriptor defined for: Community
    Dec 8, 2011 2:23:36 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
    WARNING: Missing database driver class name for 'ODBC Bridge (e.g. Access)'
    Dec 8, 2011 2:23:36 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
    INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
    INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed.
    BUILD SUCCESSFUL (total time: 4 seconds)
    Finally the XML:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.1.014">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.1.014" expanded="true" name="Root">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <parameter key="parallelize_main_process" value="false"/>
        <process expanded="true" height="634" width="907">
          <operator activated="true" class="generate_data" compatibility="5.1.014" expanded="true" height="60" name="ExampleSetGenerator" width="90" x="45" y="165">
            <parameter key="target_function" value="complicated function"/>
            <parameter key="number_examples" value="1000"/>
            <parameter key="number_of_attributes" value="3"/>
            <parameter key="attributes_lower_bound" value="-10.0"/>
            <parameter key="attributes_upper_bound" value="10.0"/>
            <parameter key="use_local_random_seed" value="true"/>
            <parameter key="local_random_seed" value="-1"/>
            <parameter key="datamanagement" value="double_array"/>
          </operator>
          <operator activated="true" class="optimize_by_generation_aga" compatibility="5.1.014" expanded="true" height="94" name="AGA" width="90" x="179" y="30">
            <parameter key="max_number_of_new_attributes" value="1"/>
            <parameter key="limit_max_total_number_of_attributes" value="false"/>
            <parameter key="max_total_number_of_attributes" value="-1"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="show_stop_dialog" value="false"/>
            <parameter key="maximal_fitness" value="Infinity"/>
            <parameter key="population_size" value="5"/>
            <parameter key="maximum_number_of_generations" value="50"/>
            <parameter key="use_plus" value="false"/>
            <parameter key="use_diff" value="false"/>
            <parameter key="use_mult" value="true"/>
            <parameter key="use_div" value="false"/>
            <parameter key="reciprocal_value" value="false"/>
            <parameter key="use_early_stopping" value="false"/>
            <parameter key="generations_without_improval" value="-1"/>
            <parameter key="tournament_size" value="0.25"/>
            <parameter key="start_temperature" value="1.0"/>
            <parameter key="dynamic_selection_pressure" value="true"/>
            <parameter key="keep_best_individual" value="false"/>
            <parameter key="p_initialize" value="0.5"/>
            <parameter key="p_crossover" value="0.5"/>
            <parameter key="crossover_type" value="uniform"/>
            <parameter key="p_generate" value="0.1"/>
            <parameter key="use_heuristic_mutation_probability" value="true"/>
            <parameter key="p_mutation" value="0.1"/>
            <parameter key="use_square_roots" value="false"/>
            <parameter key="use_power_functions" value="false"/>
            <parameter key="use_sin" value="false"/>
            <parameter key="use_cos" value="false"/>
            <parameter key="use_tan" value="false"/>
            <parameter key="use_atan" value="false"/>
            <parameter key="use_exp" value="false"/>
            <parameter key="use_log" value="false"/>
            <parameter key="use_absolute_values" value="false"/>
            <parameter key="use_min" value="false"/>
            <parameter key="use_max" value="false"/>
            <parameter key="use_sgn" value="false"/>
            <parameter key="use_floor_ceil_functions" value="false"/>
            <parameter key="restrictive_selection" value="true"/>
            <parameter key="remove_useless" value="true"/>
            <parameter key="remove_equivalent" value="true"/>
            <parameter key="equivalence_samples" value="5"/>
            <parameter key="equivalence_epsilon" value="0.05"/>
            <parameter key="equivalence_use_statistics" value="true"/>
            <parameter key="search_fourier_peaks" value="0"/>
            <parameter key="attributes_per_peak" value="1"/>
            <parameter key="epsilon" value="0.1"/>
            <parameter key="adaption_type" value="gaussian"/>
            <parameter key="parallelize_evaluation_process" value="true"/>
            <process expanded="true" height="616" width="820">
              <operator activated="true" class="x_validation" compatibility="5.1.002" expanded="true" height="130" name="XValidation" width="90" x="45" y="30">
                <parameter key="create_complete_model" value="false"/>
                <parameter key="average_performances_only" value="true"/>
                <parameter key="leave_one_out" value="false"/>
                <parameter key="number_of_validations" value="10"/>
                <parameter key="sampling_type" value="shuffled sampling"/>
                <parameter key="parallelize_training" value="false"/>
                <parameter key="parallelize_testing" value="false"/>
                <process expanded="true" height="634" width="394">
                  <operator activated="true" class="linear_regression" compatibility="5.1.014" expanded="true" height="94" name="LinearRegression" width="90" x="152" y="30">
                    <parameter key="feature_selection" value="M5 prime"/>
                    <parameter key="alpha" value="0.05"/>
                    <parameter key="max_iterations" value="10"/>
                    <parameter key="forward_alpha" value="0.05"/>
                    <parameter key="backward_alpha" value="0.05"/>
                    <parameter key="eliminate_colinear_features" value="true"/>
                    <parameter key="min_tolerance" value="0.05"/>
                    <parameter key="use_bias" value="true"/>
                    <parameter key="ridge" value="1.0E-8"/>
                  </operator>
                  <connect from_port="training" to_op="LinearRegression" to_port="training set"/>
                  <connect from_op="LinearRegression" from_port="model" to_port="model"/>
                  <connect from_op="LinearRegression" from_port="exampleSet" to_port="through 1"/>
                  <connect from_op="LinearRegression" from_port="weights" to_port="through 2"/>
                  <portSpacing port="source_training" spacing="0"/>
                  <portSpacing port="sink_model" spacing="0"/>
                  <portSpacing port="sink_through 1" spacing="0"/>
                  <portSpacing port="sink_through 2" spacing="0"/>
                  <portSpacing port="sink_through 3" spacing="0"/>
                </process>
                  <operator activated="true" class="apply_model" compatibility="5.1.014" expanded="true" height="76" name="ModelApplier" width="90" x="45" y="30">
                    <parameter key="create_view" value="false"/>
                  </operator>
                  <operator activated="true" class="performance" compatibility="5.1.014" expanded="true" height="76" name="Performance" width="90" x="219" y="30">
                    <parameter key="use_example_weights" value="true"/>
                  </operator>
                  <connect from_port="model" to_op="ModelApplier" to_port="model"/>
                  <connect from_port="test set" to_op="ModelApplier" to_port="unlabelled data"/>
                  <connect from_port="through 2" to_port="averagable 2"/>
                  <connect from_op="ModelApplier" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
                  <connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
                  <portSpacing port="source_model" spacing="0"/>
                  <portSpacing port="source_test set" spacing="0"/>
                  <portSpacing port="source_through 1" spacing="0"/>
                  <portSpacing port="source_through 2" spacing="54"/>
                  <portSpacing port="source_through 3" spacing="0"/>
                  <portSpacing port="sink_averagable 1" spacing="0"/>
                  <portSpacing port="sink_averagable 2" spacing="90"/>
                  <portSpacing port="sink_averagable 3" spacing="0"/>
                </process>
              </operator>
              <connect from_port="example set source" to_op="XValidation" to_port="training"/>
              <connect from_op="XValidation" from_port="averagable 1" to_port="performance sink"/>
              <portSpacing port="source_example set source" spacing="0"/>
              <portSpacing port="sink_performance sink" spacing="0"/>
            </process>
          </operator>
          <operator activated="true" class="rename_by_constructions" compatibility="5.1.014" expanded="true" height="76" name="Construction2Names" width="90" x="313" y="165"/>
          <operator activated="true" class="linear_regression" compatibility="5.1.014" expanded="true" height="94" name="LinearRegression (2)" width="90" x="447" y="255">
          </operator>
          <operator activated="true" class="apply_model" compatibility="5.1.014" expanded="true" height="76" name="ModelApplier (2)" width="90" x="648" y="345">
          </operator>
          <operator activated="true" class="write_model" compatibility="5.1.014" expanded="true" height="60" name="Write Model" width="90" x="742" y="428">
            <parameter key="model_file" value="D:\RapidMinerRepository\polymodel"/>
            <parameter key="overwrite_existing_file" value="true"/>
            <parameter key="output_type" value="XML Zipped"/>
          </operator>
          <connect from_op="ExampleSetGenerator" from_port="output" to_op="AGA" to_port="example set in"/>
          <connect from_op="AGA" from_port="example set out" to_op="Construction2Names" to_port="example set input"/>
          <connect from_op="AGA" from_port="attribute weights out" to_port="result 3"/>
          <connect from_op="AGA" from_port="performance out" to_port="result 4"/>
          <connect from_op="Construction2Names" from_port="example set output" to_op="LinearRegression (2)" to_port="training set"/>
          <connect from_op="LinearRegression (2)" from_port="model" to_op="ModelApplier (2)" to_port="model"/>
          <connect from_op="LinearRegression (2)" from_port="exampleSet" to_op="ModelApplier (2)" to_port="unlabelled data"/>
          <connect from_op="LinearRegression (2)" from_port="weights" to_port="result 2"/>
          <connect from_op="ModelApplier (2)" from_port="labelled data" to_port="result 1"/>
          <connect from_op="ModelApplier (2)" from_port="model" to_op="Write Model" to_port="input"/>
          <portSpacing port="sink_result 3" spacing="0"/>
          <portSpacing port="sink_result 4" spacing="0"/>
          <portSpacing port="sink_result 5" spacing="0"/>
        </process>
      </operator>
    </process>
    OP
    Meanwhile I tested the posted Java code on Windows XP with RapidMiner 5.0 with a different workflow.
    The error message is the same. So either I always install my software with the wrong configuration or
    there is a basic error in the Java code ?!
    Here is the XML:
    <process version="5.0">
      <context>
        <input>
          <location/>
        </input>
        <output>
          <location/>
          <location/>
        </output>
        <macros/>
      </context>
      <operator activated="true" class="process" expanded="true" name="Process">
        <parameter key="logverbosity" value="3"/>
        <parameter key="send_mail" value="1"/>
        <process expanded="true" height="100" width="413">
          <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="67" y="62">
            <parameter key="target_function" value="random"/>
            <parameter key="number_examples" value="100"/>
            <parameter key="number_of_attributes" value="5"/>
            <parameter key="local_random_seed" value="1992"/>
            <parameter key="datamanagement" value="0"/>
          </operator>
          <operator activated="true" class="write_csv" expanded="true" height="60" name="Write CSV" width="90" x="313" y="30">
            <parameter key="csv_file" value="D:\TEMP\rapidminer.csv"/>
            <parameter key="column_separator" value=";"/>
            <parameter key="write_attribute_names" value="true"/>
            <parameter key="quote_nominal_values" value="true"/>
          </operator>
          <connect from_op="Generate Data" from_port="output" to_op="Write CSV" to_port="input"/>
          <connect from_op="Write CSV" from_port="through" to_port="result 1"/>
        </process>
      </operator>
    </process>
    Netbeans output:
    run:
    2011-12-08 18:46:23 CONFIG: Initializing I18N (RapidMiner.splashMessage())
    2011-12-08 18:46:23 CONFIG: Ensuring RapidMiner Home is set (RapidMiner.splashMessage())
    2011-12-08 18:46:23 INFO: rapidminer.home is 'C:/Programme/Rapid-I/RapidMiner5/'. (Launcher.ensureRapidMinerHomeSet())
    2011-12-08 18:46:23 CONFIG: Reading Configuration Files (RapidMiner.splashMessage())
    2011-12-08 18:46:23 CONFIG: Reading configuration resource com/rapidminer/resources/rapidminerrc. (ParameterService.loadRCFile())
    2011-12-08 18:46:23 CONFIG: Trying rcfile 'C:\Dokumente und Einstellungen\Michael\.RapidMiner5\5_0_1_rapidminerrc'...skipped (ParameterService.loadRCFile())
    2011-12-08 18:46:23 CONFIG: Read rcfile 'C:\Dokumente und Einstellungen\Michael\.RapidMiner5\5_0_1_rapidminerrc.Windows XP'. (ParameterService.loadRCFile())
    2011-12-08 18:46:23 CONFIG: Trying rcfile 'C:\Dokumente und Einstellungen\Michael\Eigene Dateien\NetBeansProjects\jRapidMiner\rapidminerrc'...skipped (ParameterService.loadRCFile())
    2011-12-08 18:46:23 CONFIG: Trying rcfile 'C:\Dokumente und Einstellungen\Michael\Eigene Dateien\NetBeansProjects\jRapidMiner\rapidminerrc.Windows XP'...skipped (ParameterService.loadRCFile())
    2011-12-08 18:46:23 CONFIG: Property rapidminer.rcfile not specified...skipped (ParameterService.loadRCFile())
    2011-12-08 18:46:23 CONFIG: Registering Plugins (RapidMiner.splashMessage())
    2011-12-08 18:46:23 CONFIG: Read extension state. (ManagedExtension.readConfiguration())
    2011-12-08 18:46:23 CONFIG: Scanning plugins in C:\Programme\Rapid-I\RapidMiner5\lib\plugins. (Plugin.initAll())
    2011-12-08 18:46:23 CONFIG: Loading renderers from 'Text Processing'. (RendererService.init())
    2011-12-08 18:46:26 CONFIG: Reading parse rules from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_text-5.0.4.jar!/com/rapidminer/resources/parserulesTextProcessing.xml (XMLImporter.importParseRules())
    2011-12-08 18:46:26 CONFIG: Loading renderers from 'Weka'. (RendererService.init())
    2011-12-08 18:46:26 CONFIG: Reading parse rules from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_weka-5.0.0.jar!/com/rapidminer/resources/parserulesWekaExtension.xml (XMLImporter.importParseRules())
    2011-12-08 18:46:26 CONFIG: Loading renderers from 'Web Mining'. (RendererService.init())
    2011-12-08 18:46:26 CONFIG: Reading parse rules from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_web-5.0.2.jar!/com/rapidminer/resources/parserulesWeb.xml (XMLImporter.importParseRules())
    2011-12-08 18:46:26 CONFIG: Loading renderers from 'Series'. (RendererService.init())
    2011-12-08 18:46:26 CONFIG: Reading parse rules from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_series-5.0.1.jar!/com/rapidminer/resources/parserulesValueSeries.xml (XMLImporter.importParseRules())
    2011-12-08 18:46:26 CONFIG: Loading renderers from 'Reporting'. (RendererService.init())
    2011-12-08 18:46:26 CONFIG: Reading parse rules from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_reporting-5.0.2.jar!/com/rapidminer/resources/parserulesReporting.xml (XMLImporter.importParseRules())
    2011-12-08 18:46:26 CONFIG: Initializing Setup (RapidMiner.splashMessage())
    2011-12-08 18:46:26 CONFIG: Default encoding is windows-1252. (RapidMiner.init())
    2011-12-08 18:46:26 CONFIG: Initializing Operators (RapidMiner.splashMessage())
    2011-12-08 18:46:26 CONFIG: Loading operators from 'OperatorsCore.xml'. (OperatorService.registerOperators())
    2011-12-08 18:46:26 CONFIG: Loading operator documentation from jar:file:/C:/Programme/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/i18n/OperatorsCoreDocumentation.xml. (OperatorDocBundle$XMLControl.newBundle())
    2011-12-08 18:46:29 CONFIG: Loading operators from 'C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_text-5.0.4.jar'. (OperatorService.registerOperators())
    2011-12-08 18:46:29 CONFIG: Loading operator documentation from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_text-5.0.4.jar!/com/rapidminer/resources/i18n/OperatorsDocTextProcessing.xml. (OperatorDocBundle$XMLControl.newBundle())
    2011-12-08 18:46:29 CONFIG: Loading operators from 'C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_weka-5.0.0.jar'. (OperatorService.registerOperators())
    2011-12-08 18:46:29 CONFIG: Loading operator documentation from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_weka-5.0.0.jar!/com/rapidminer/resources/i18n/OperatorsDocWekaExtension.xml. (OperatorDocBundle$XMLControl.newBundle())
    2011-12-08 18:46:29 CONFIG: Creating operators from factory com.rapidminer.tools.WekaOperatorFactory (OperatorService.parseOperators())
    2011-12-08 18:46:33 CONFIG: Loading operators from 'C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_web-5.0.2.jar'. (OperatorService.registerOperators())
    2011-12-08 18:46:33 CONFIG: Loading operator documentation from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_web-5.0.2.jar!/com/rapidminer/resources/i18n/OperatorsDocWeb.xml. (OperatorDocBundle$XMLControl.newBundle())
    2011-12-08 18:46:33 CONFIG: Loading operators from 'C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_series-5.0.1.jar'. (OperatorService.registerOperators())
    2011-12-08 18:46:33 CONFIG: Loading operator documentation from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_series-5.0.1.jar!/com/rapidminer/resources/i18n/OperatorsDocValueSeries.xml. (OperatorDocBundle$XMLControl.newBundle())
    2011-12-08 18:46:34 CONFIG: Loading operators from 'C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_reporting-5.0.2.jar'. (OperatorService.registerOperators())
    2011-12-08 18:46:34 CONFIG: Loading operator documentation from jar:file:C:\Programme\Rapid-I\RapidMiner5\lib\plugins\managed\rmx_reporting-5.0.2.jar!/com/rapidminer/resources/i18n/OperatorsDocReporting.xml. (OperatorDocBundle$XMLControl.newBundle())
    2011-12-08 18:46:34 CONFIG: Number of registered operator classes: 542; number of registered operator descriptions: 678; number of replacements: 531 (OperatorService.init())
    2011-12-08 18:46:34 CONFIG: Loading operator usage statistics. (UsageStatistics.load())
    2011-12-08 18:46:34 CONFIG: Initializing XML Transformation Rules (RapidMiner.splashMessage())
    2011-12-08 18:46:34 CONFIG: Reading parse rules from jar:file:/C:/Programme/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/parserules.xml (XMLImporter.importParseRules())
    2011-12-08 18:46:34 CONFIG: Initializing Data Repository (RapidMiner.splashMessage())
    2011-12-08 18:46:34 CONFIG: Loading repositories from C:\Dokumente und Einstellungen\Michael\.RapidMiner5\repositories.xml (RepositoryManager.load())
    2011-12-08 18:46:34 CONFIG: Adding repository NewLocalRepository (RepositoryManager.addRepository())
    2011-12-08 18:46:34 CONFIG: Adding repository D-Temp-RapidMinerRepository (RepositoryManager.addRepository())
    2011-12-08 18:46:34 CONFIG: Loading JDBC Drivers (RapidMiner.splashMessage())
    2011-12-08 18:46:34 CONFIG: Loading JDBC driver information from 'resource jdbc_properties.xml'. (DatabaseService.loadJDBCProperties())
    2011-12-08 18:46:34 CONFIG: Loaded JDBC driver com.mysql.jdbc.Driver (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 CONFIG: Loaded JDBC driver org.postgresql.Driver (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 CONFIG: Loaded JDBC driver net.sourceforge.jtds.jdbc.Driver (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 CONFIG: Loaded JDBC driver org.hsqldb.jdbcDriver (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 WARNING: Missing database driver class name for 'ODBC Bridge (e.g. Access)' (JDBCProperties.<init>())
    2011-12-08 18:46:34 CONFIG: Loaded JDBC driver com.ingres.jdbc.IngresDriver (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 CONFIG: Loaded JDBC driver ca.ingres.jdbc.IngresDriver (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 INFO: JDBC driver COM.ibm.db2.jdbc.app.DB2Driver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 INFO: JDBC driver com.ibm.as400.access.AS400JDBCDriver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 INFO: JDBC driver com.ibm.db2.jcc.DB2Driver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 INFO: JDBC driver com.microsoft.jdbc.sqlserver.SQLServerDriver not found. Probably the driver is not installed. (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 CONFIG: Loaded JDBC driver jdbc.gupta.sqlbase.SqlbaseDriver (JDBCProperties.registerDrivers())
    2011-12-08 18:46:34 CONFIG: Initializing XML Serialization (RapidMiner.splashMessage())
    2011-12-08 18:46:34 CONFIG: Defining XML Serialization Alias Pairs (RapidMiner.splashMessage())
    2011-12-08 18:46:34 CONFIG: Initializing Renderers (RapidMiner.splashMessage())
    2011-12-08 18:46:34 CONFIG: Loading renderers from 'file:/C:/Programme/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/ioobjects.xml'. (RendererService.init())
    2011-12-08 18:46:34 CONFIG: Loading renderers from 'ioobjects.xml'. (RendererService.init())
    BUILD SUCCESSFUL (total time: 12 seconds)
    OP
    Now I got a little closer to the problem!
    I generated manually a new file with the only content:
    The result:
    It seems that the error message is not appropriate to the error!
    OP
    ARRRGGGHHHH  ;D :( :-\
    Sometimes I really wonder if someone really reads the posts or not!
    Here is the quite simple solution of the quite stupid error:
    original code
    Process process = new Process(workflowPath);
    corrected code
    Process process = new Process(new File(workflowPath));
    Tomorrow I will send working code for the Jython version (for those who are interested).
    Extended: See http://rapid-i.com/rapidforum/index.php/topic,4408.0.html
    Best regards, Michael
    Uh, that really was quit simple. Maybe too simple i haven't seen it either  :o
    But i'm glad you solved it!
    Cheers,
    Nils
    User: "kludikovsky"
    Accepted Answer
    This saved my day.
    The files was sored as UTF-8. SImply converted to ANSI solved the issue.
    Thnx,
