🎉Community Raffle - Win $25
Join and Win
"R extension"
User: "NJS"
New Altair Community Member
Updated by Jocelyn
Hello,
I got problem installing R extension in RM.
I use R 2.14 64bits and RM 5.1 64bits.
Window7
Variables set:
JAVA_HOME: C:\Program Files\Java\jre6\bin
R_HOME: C:\Program Files\R\R-2.14.0
When starting RM, I got the R extension instructions but it never worked (failed to load R library.
Somebody could help?
Thanks a lot,
Nathalie
1 - 4 of 41
    User: "MariusHelf"
    Hi Nathalie,
    do you see any error messages? Please check also the log view in RapidMiner. If you find any error messages, please post them here.
    Kind regards,
    Marius
    User: "haddock"
    Hi there Natalie,
    I see you have 64 bit Java, if your R installation is not also 64 bit then you will get a system load error. I'm writing a Cuda plugin which needs to be 64 bit, and if my Java isn't also 64 bit I get this sort of error.
    Just a thought.
    User: "NJS"
    OP
    Thanks for your answer. I got R 64bits as well as RM 64bits.
    Running the RM console, I got the arror message below. Pretty long message but maybe it could help to get the problem solved...
    Thanks a lot for your help,
    Nathalie
    C:\Users\Nathalie\AppData\Local\Temp\RtmpWydhV8\downloaded_packages
    [1] "C:/Users/Nathalie/Documents/R/win-library/2.14"
    [2] "C:/Program Files/R/R-2.14.0/library"
    RAPIDMINER_HOME is not set. Trying the directory 'C:\Program Files\Rapid-I\Rapid
    Miner5\scripts\..'...
    Using local jre: C:\Program Files\Rapid-I\RapidMiner5\scripts\..\jre\bin\java.ex
    e...
    Starting RapidMiner from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..' using
    classes from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..\lib\rapidminer.ja
    r'...
    7 dÚc. 2011 03:55:03 com.rapid_i.Launcher ensureRapidMinerHomeSet
    INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'.
    7 dÚc. 2011 03:55:03 com.rapid_i.Launcher main
    INFO: Launching RapidMiner, platform WIN64
    7 dÚc. 2011 03:55:05 com.rapid_i.Launcher ensureRapidMinerHomeSet
    7 dÚc. 2011 03:55:05 com.rapidminer.tools.ParameterService init
    INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
    7 dÚc. 2011 03:55:05 com.rapidminer.PluginInitR initPlugin
    INFO: Trying to load R Library...
    7 dÚc. 2011 03:55:05 org.rosuda.JRI.Rengine <clinit>
    INFO: Creating Connection to R...
    7 dÚc. 2011 03:55:05 org.rosuda.JRI.Rengine loadLibrary
    INFO: Trying to loaded R library from C:\Users\Nathalie\Documents\R\win-library\
    2.14\rJava\jri\x64\jri.dll
    INFO: Engine ID: class org.rosuda.JRI.Rengine ClassLoader:PluginClassLoader ([fi
    le:/C:/Users/Nathalie/.RapidMiner5/managed/rmx_r-5.1.4.jar])
    7 dÚc. 2011 03:55:05 com.rapidminer.tools.I18N getMessage
    WARNING: Missing I18N key: r.could_not_load_native_lib
    7 dÚc. 2011 03:55:05 com.rapidminer.PluginInitR loadNativeLibrary
    SEVERE: r.could_not_load_native_lib
    java.lang.UnsatisfiedLinkError: C:\Users\Nathalie\Documents\R\win-library\2.14\r
    Java\jri\x64\jri.dll: Can't find dependent libraries
            at java.lang.ClassLoader$NativeLibrary.load(Native Method)
            at java.lang.ClassLoader.loadLibrary0(Unknown Source)
            at java.lang.ClassLoader.loadLibrary(Unknown Source)
            at java.lang.Runtime.load0(Unknown Source)
            at java.lang.System.load(Unknown Source)
            at org.rosuda.JRI.Rengine.loadLibrary(Rengine.java:109)
            at org.rosuda.JRI.Rengine.loadLibrary(Rengine.java:122)
            at com.rapidminer.PluginInitR.loadNativeLibrary(PluginInitR.java:163)
            at com.rapidminer.PluginInitR.initPlugin(PluginInitR.java:88)
            at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
            at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
            at java.lang.reflect.Method.invoke(Unknown Source)
            at com.rapidminer.tools.plugin.Plugin.callInitMethod(Plugin.java:798)
            at com.rapidminer.tools.plugin.Plugin.callPluginInitMethods(Plugin.java:
    776)
            at com.rapidminer.tools.plugin.Plugin.initPlugins(Plugin.java:762)
            at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:877)
            at com.rapidminer.RapidMiner.init(RapidMiner.java:456)
            at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:221)
            at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:505)
            at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:488)
            at com.rapid_i.Launcher.main(Launcher.java:334)
    7 dÚc. 2011 03:55:05 org.rosuda.JRI.Rengine isJriLoaded
    WARNING: Access on Rengine but initialization failed! ID:1884473012
    WARNING: Loading library on the fly...
    WARNING: Error during loading library on the fly!
            at org.rosuda.JRI.Rengine.isJriLoaded(Rengine.java:134)
            at com.rapidminer.PluginInitR.initPlugin(PluginInitR.java:89)
    776)
    SEVERE: Failed to load R library!
    7 dÚc. 2011 03:55:09 com.rapidminer.parameter.ParameterTypePassword decryptPassw
    ord
    WARNING: Password in XML file looks like unencrypted plain text.
    [Fatal Error] :1:1: Content is not allowed in prolog.
    7 dÚc. 2011 03:55:18 com.rapidminer.operator.r.ROperatorFactory readROperatorFra
    gments
    WARNING: Could not read R fragments from 'file:/C:/Program%20Files/Rapid-I/Rapid
    Miner5/', error: Content is not allowed in prolog.
    org.xml.sax.SAXParseException: Content is not allowed in prolog.
            at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(Unknown So
    urce)
            at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(Unk
    nown Source)
            at javax.xml.parsers.DocumentBuilder.parse(Unknown Source)
            at com.rapidminer.io.process.XMLTools.parse(XMLTools.java:175)
            at com.rapidminer.operator.r.ROperatorFactory.readROperatorFragments(ROp
    eratorFactory.java:166)
            at com.rapidminer.operator.r.ROperatorFactory.<init>(ROperatorFactory.ja
    va:129)
            at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
            at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
            at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Sou
    rce)
            at java.lang.reflect.Constructor.newInstance(Unknown Source)
            at java.lang.Class.newInstance0(Unknown Source)
            at java.lang.Class.newInstance(Unknown Source)
            at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.j
    ava:294)
    ava:232)
            at com.rapidminer.tools.OperatorService.registerOperators(OperatorServic
    e.java:206)
            at com.rapidminer.tools.plugin.Plugin.registerOperators(Plugin.java:471)
            at com.rapidminer.tools.plugin.Plugin.registerAllPluginOperators(Plugin.
    java:725)
            at com.rapidminer.tools.OperatorService.init(OperatorService.java:167)
            at com.rapidminer.RapidMiner.init(RapidMiner.java:465)
    7 dÚc. 2011 03:55:18 com.rapidminer.operator.r.ROperatorFactory <init>
    WARNING: Could not read documentation of user defined R operators from .
    java.io.IOException: Malformed XML operator help bundle: org.xml.sax.SAXParseExc
            at com.rapidminer.tools.documentation.XMLOperatorDocBundle.<init>(XMLOpe
    ratorDocBundle.java:119)
    va:150)
    rce)
    ava:294)
    ava:232)
    e.java:206)
    java:725)
    Caused by: org.xml.sax.SAXParseException: Content is not allowed in prolog.
    urce)
    nown Source)
    ratorDocBundle.java:117)
            ... 22 more
    7 dÚc. 2011 03:55:18 com.rapidminer.tools.jdbc.JDBCProperties <init>
    WARNING: Missing database driver class name for 'ODBC Bridge (e.g. Access)'
    7 dÚc. 2011 03:55:18 com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
    INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is
    not installed.
    INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver
    is not installed.
    7 dÚc. 2011 03:55:24 com.rapidminer.tools.I18N getMessage
    WARNING: Missing I18N key: gui.action.workspace_Nath.label
    7 dÚc. 2011 03:55:24 org.rosuda.JRI.Rengine isJriLoaded
    7 dÚc. 2011 03:55:24 org.rosuda.JRI.Rengine loadLibrary
            at com.rapidminer.PluginInitR.initGui(PluginInitR.java:100)
    776)
            at com.rapidminer.tools.plugin.Plugin.initPluginGuis(Plugin.java:754)
            at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:248)
    User: "haddock"
    Hi there,
    Looking at the error message, it looks like a path problem. Have you checked this out?
    http://rapid-i.com/rapidforum/index.php/topic,2612.msg10451.html#msg10451
