Hi all again,
I have created a RapidMiner project which i use ''Read Document'' operator and some others.I have built java code in order to run the this project.As result i take these errors:
run:
Oct 13, 2011 1:41:07 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: Property rapidminer.home is not set. Guessing.
INFO: Trying parent directory of 'C:\Program Files\Rapid-I\RapidMiner5\lib\rapidminer.jar'...gotcha!
Oct 13, 2011 1:41:07 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
Oct 13, 2011 1:41:09 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
Oct 13, 2011 1:41:09 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for 'ODBC Bridge (e.g. Access)'
Oct 13, 2011 1:41:09 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed.
Oct 13, 2011 1:41:11 PM com.rapidminer.io.process.XMLImporter addMessage
INFO: <em class="error">The operator class 'text:read_document' is unknown. Possibly you must install a plugin for operators of group 'text'.</em>
INFO: <em class="error">The output port <var>output</var> is unknown at operator <var>Read Document</var>.</em>
Oct 13, 2011 1:41:11 PM com.rapidminer.tools.WrapperLoggingHandler log
INFO: No filename given for result file, using stdout for logging results!
Oct 13, 2011 1:41:11 PM com.rapidminer.Process run
INFO: Process C:\Users\platanas\Desktop\diplomatiki\Rapid Miner Java\RM2 (1)\RM2\demoprocess.rmp starts
Oct 13, 2011 1:41:11 PM com.rapidminer.tools.WrapperLoggingHandler logWarning
WARNING: Example set has no nominal label: using shuffled partition instead of stratified partition!
Oct 13, 2011 1:41:11 PM NewJFrame jButton1ActionPerformed
SEVERE: null
com.rapidminer.operator.UserError: The dummy operator Read Document (replacing text:read_document) cannot be executed.
at com.rapidminer.operator.DummyOperator.doWork(DummyOperator.java:88)
at com.rapidminer.operator.Operator.execute(Operator.java:831)
at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:709)
at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:369)
at com.rapidminer.Process.run(Process.java:902)
at com.rapidminer.Process.run(Process.java:798)
at com.rapidminer.Process.run(Process.java:793)
at com.rapidminer.Process.run(Process.java:783)
at NewJFrame.jButton1ActionPerformed(NewJFrame.java:89)
at NewJFrame.access$000(NewJFrame.java:23)
at NewJFrame$1.actionPerformed(NewJFrame.java:48)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
at java.awt.Component.processMouseEvent(Component.java:6041)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3265)
at java.awt.Component.processEvent(Component.java:5806)
at java.awt.Container.processEvent(Container.java:2058)
at java.awt.Component.dispatchEventImpl(Component.java:4413)
at java.awt.Container.dispatchEventImpl(Container.java:2116)
at java.awt.Component.dispatchEvent(Component.java:4243)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4322)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3986)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3916)
at java.awt.Container.dispatchEventImpl(Container.java:2102)
at java.awt.Window.dispatchEventImpl(Window.java:2440)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:273)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:183)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:173)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:168)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:160)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:121)
When i delete the operator ''Read Document'' the project in java runs correctly.Does anuone know wheere i can find the problem??
