🎉Community Raffle - Win $25
Join and Win
"Driver for connecting to Oracle Database"
User: "Anki"
New Altair Community Member
Updated by Jocelyn
Hi Community,
I am using RapidMiner-5  64 bit,  Windows server 2003 (64 bit) as OS,  JDK 1.6 java version,  Oracle 11g for Database.
My problem is I am unable to connect to Database with RM. I tried with ojdbc14.jar and ojdbc6.jar,  but no use.
Please give me solution, which drivers I have to use.
Thank you
Yours
Anki
1 - 6 of 61
    User: "fischer"
    Hi,
    Oracle changed the name of the driver class. You can go to Tools -> Manage Database Drivers and create a new Oracle Driver with class name "oracle.jdbc.OracleDriver" (as opposed to "oracle.jdbc.driver.OracleDriver"). That will probably solve the problem.
    Best,
    Simon
    User: "Anki"
    OP
    Hi Simon,
    Thank you for your help. I did changes, but still not solved
    Tools-Manage Drivers - Add oracle - and parameters as
      port  : 1521
    Browsed for ojdbc14.jar and ojdbc6.jar
    Class: oracle.jdbc.OracleDriver
    But still not connected.
    Please correct me if I did wrong in the procedure.
    Thank you
    Yours
    Anki
    User: "Anki"
    OP
    Hi Simon and all
    YES, above method is working fine. Thank you.
    But while I am establishing, an error is coming as
    listener refused the connection with the following error ora-12505
    What could be the reason? any solution
    Thank you
    Yours
    Anki
    User: "colo"
    Hi Anki,
    since this issue is named, there should be some material about it.
    Maybe some of these will be helpful: http://lmgtfy.com/?q=oracle+ora-12505 :D;)
    Regards
    Matthias
    User: "Anki"
    OP
    Hi Matthias,
    The Problem solved. Thank you.
    Yours
    Anki
    User: "marcopo"
    Hello Community,
    I am a newbie in Rapidminer (5.2.008) and I am trying to establish a connection to an oracle database 11g. I was faced with the same error and I handled it in the way it was shown in the post. In the end I got the same ORA-12505 error. I tried to solve it in the way it was suggested but without suggest. What should I do?
    Please help me.....
    My listner.ora
    # listener.ora Netw
    ork Configuration File: C:\app\pospiech\product\11.2.0\dbhome_1\network\admin\listener.ora
    # Generated by Oracle configuration tools.
    SID_LIST_LISTENER =
      (SID_LIST =
        (SID_DESC =
          (SID_NAME = CLRExtProc)
          (ORACLE_HOME = C:\app\product\11.2.0\dbhome_1)
          (PROGRAM = extproc)
          (ENVS = "EXTPROC_DLLS=ONLY:C:\app\product\11.2.0\dbhome_1\bin\oraclr11.dll")
    LISTENER =
      (DESCRIPTION_LIST =
        (DESCRIPTION =
          (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521))
          (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521))
    ADR_BASE_LISTENER = C:\app
    Best Regards
    Marco
