🎉Community Raffle - Win $25
Join and Win
Add label to existing ExampleSet
radoneUser: "radone"
New Altair Community Member
Updated by Jocelyn
Hi,
I have an existing example set. How can I effectively add a label attribute to the existing example set?
ExampleSet newExampleSet = .... (an existing example set);
// ADD LABEL ATTRIBUTE
Attribute label = AttributeFactory.createAttribute("label", Ontology.NOMINAL);
newExampleSet.getAttributes().setLabel(label);
// SET NOMINAL VALUE
Example e = newExampleSet.getExample(0);
e.setLabel(label.getMapping().mapString(clsName));
throws  java.lang.ArrayIndexOutOfBoundsException: -1 on the last line.
SEVERE: Process failed: operator cannot be executed (-1). Check the log messages...
at com.rapidminer.example.table.DoubleArrayDataRow.set(DoubleArrayDataRow.java:52)
at com.rapidminer.example.table.AbstractAttribute.setValue(AbstractAttribute.java:184)
at com.rapidminer.example.table.DataRow.set(DataRow.java:85)
at com.rapidminer.example.Example.setValue(Example.java:140)
at com.rapidminer.example.Example.setLabel(Example.java:178)
at ... last code of the example above ...
Thanks in advance for any help,
radone
1 - 4 of 41
    Hi,
    this should work:
    Attribute newAtt = AttributeFactory.createAttribute("label", Ontology.NOMINAL);
    newExampleSet.getExampleTable().addAttribute(newAtt);
    newExampleSet.getAttributes().addRegular(newAtt);
    newExampleSet.getAttributes().setSpecialAttribute(newExampleSet.getAttributes().get("label"), "label");
    There are other ways, but this one should work just fine.
    Regards,
    Marco
    OP
    Thank you for your reply.
    Unfortunately, ended with exactly the same error. I got some debugging info about the just inserted label and it seems that "-1" in my outpput might have something to do with my problem?
    String clsName = "MY_NEW_NOMINAL_CLASS";
    System.out.println(newExampleSet.getAttributes().getLabel());
    the system out gives:
    #-1: label (nominal/single_value)/values=[]
    and the code:
    throws:
    at .... last code of the example above ....
    Hi,
    I forgot a line in my first reply, so I had to edit it. If you copy that codeblock, you should be fine.
    Note that to be able to use
    the label attribute must already be present in the attribute set.
    Regards,
    Marco
    OP
    Thank you Marco.
    The line:
    was exactly what I was missing.
