Altair RISE
Nominate Yourself Now!
"Excel-Import doesn't work for Strings like '4711"
User: "swbfino"
New Altair Community Member
Updated by Jocelyn
Hi,
I try to import data via ExcelExampleSource, which works fine, but when I have a column like
'4711 RapidMiner always converts it as integer, but it should be nominal (value type).
In Excel it is a string as "value type".
Does anyone know the solution?
Cheers
Tom
1 - 5 of 51
    Hi,
    I cannot reproduce this. If I try to import an excel file with just this string, it's correctly identified as polynominal. Could you please post your process xml?
    Regards,
    Marco
    User: "swbfino"
    OP
    Here we go
    <operator name="Root" class="Process" expanded="yes">
        <operator name="ExcelExampleSource" class="ExcelExampleSource">
            <parameter key="excel_file" value="U:\rm_sampel_excel_string.xls"/>
        </operator>
    </operator>
    Again:
    If i try to import a file like
    test_var
    '4711
    '4712
    '4713
    the value type is integer
    Cheers
    Thomas
    User: "colo"
    Hi,
    I guess you two are using different versions of RapidMiner ;)
    At least it seems that Thomas is using something older since I started with version 5.0 and "ExcelExampleSource" does not sound familiar to me.
    Regards
    Matthias
    User: "swbfino"
    OP
    Hi Matthias,
    I guess you are right because I use still V4.2 instead of 5.x, bit is this the reason?
    May be I have to update, but I used a workaround already (using a prefix like STRING_* in the Exceldatasource.).
    Bye
    Thomas
    Hi,
    hm I should have noticed that ;)
    I definitely suggest updating to RapidMiner5.1, your version is extremely outdated. Of course that also means there are alot of bugs which have been fixed in the meantime.
    Regards,
    Marco
