Altair RISE
Nominate Yourself Now!
"Excel-Import doesn't work for Strings like '4711"
swbfino
I try to import data via ExcelExampleSource, which works fine, but when I have a column like
'4711 RapidMiner always converts it as integer, but it should be nominal (value type).
In Excel it is a string as "value type".
Does anyone know the solution?
Cheers
Tom
Excel
Marco_Boeck
I cannot reproduce this. If I try to import an excel file with just this string, it's correctly identified as polynominal. Could you please post your process xml?
Marco
swbfino
Here we go
<operator name="ExcelExampleSource" class="ExcelExampleSource">
<parameter key="excel_file" value="U:\rm_sampel_excel_string.xls"/>
Again:
If i try to import a file like
test_var
'4711
'4712
'4713
the value type is integer
Cheers
Thomas
colo
I guess you two are using different versions of RapidMiner
At least it seems that Thomas is using something older since I started with version 5.0 and "ExcelExampleSource" does not sound familiar to me.
Regards
Matthias
swbfino
Hi Matthias,
I guess you are right because I use still V4.2 instead of 5.x, bit is this the reason?
May be I have to update, but I used a workaround already (using a prefix like STRING_* in the Exceldatasource.).
Bye
Thomas
Marco_Boeck
hm I should have noticed that
I definitely suggest updating to RapidMiner5.1, your version is extremely outdated. Of course that also means there are alot of bugs which have been fixed in the meantime.
Marco
