Implementing an operator
Hello all,
How could one implement a custom operator (e.g. a fuzzy ARTMAP classifier) and further add it to the operators group in RapidMiner? I guess that it should be implemented in Java, by deriving some specific classes/implementing RM interfaces. Where could I find such an example or (better) documentation in this subject?
Thanks,
Lucian
Later edit: after digging the web, it seems that for RM 5 the white paper (http://rapid-i.com/component/page,shop.product_details/product_id,52/flypage,flypage.tpl/pop,0/option,com_virtuemart/Itemid,180/vmcchk,1/) is the authoritative resource. The RapidMiner 4.6 document contains a section dedicated to this area. Is this section deprecated/outdated? I intend to ask to my students to implement some ML-based models and integrate them into RM. At first glance, Weka seems to be more easily extended with custom models.
Thanks,
Lucian
1 - 2 of
21
Yes, the doc of 4.6 is outdated. It will be quite hard to create a plugin with only this reference and examples (for rm5.x at least). I have absolute no authority to speak on this subject, but if you contact rapid-i directly (contact@rapid-i.com), state who you are and that you need the document for academic purpose, they may give you a discount or allow the distribution of one bought document among the students for the time of the lecture.
I'd try it, but as I said, I have no authority here (i am just a regular enduser like you).
greetings,
steffen
