"Automatic System Construction Error"
tobyb
tobyb New Altair Community Member
edited November 2024 in Community Q&A
I am running Rapid Miner 5.1 on Windows XP.  I have the latest version of the PaREn operator.  I can load the iris dataset.  On Step 3 when I select the classifier I want to load, I proceed to click Next and I get the following error, No operator description object for 'com.rapidminer.operator.validation.ParallelXValidation'.  This is a fatal error.  When i click okay the process stops.
Has anyone else experienced this problem?
Welcome!
Answers
  • land
    land New Altair Community Member
    Hi,
    do you have installed the Parallel Processing Extension?
    Greetings,
      Sebastian
  • brett_drury
    brett_drury New Altair Community Member
    I have the same problem. I am running the latest version on Windows Vista with the parallel extension installed.
  • land
    Hi,
    yes as far as I know the Paren Extension does not specifiy it depends on the parallel extension. This might cause class loader issues if the loading order wrong.
    I will try dealing with that...
    Greetings,
    Sebastian
  • brett_drury
    Thanks. Let me know if I can help you with testing any fix.
  • land
    Hi,
    I have managed to trace down the problem: The Paren Extension includes RapidMiner operators in it's own jar and hence the class loader fails to create the correct operators. I will talk back to DFKI to solve this issue.
    Greetings,
      Sebastian
  • maroon
    maroon New Altair Community Member
    I am experiencing the same problem. Is this problem reported on the MAC or LINUX as well?
  • maroon
    YES same error on the MAC as well.
  • pathros
    pathros New Altair Community Member
    I have the same problem on computers running under Windows XP SP3.
    With Rapidminer 5.0 and its respective updates (Paren, Weka...) Paren was working well, even with the text mining extension.
    From Rapidminer 5.1 the problems with Paren started: it could no longer load the data, especially when the text mining extension was also installed.
    So, what i did was to install only Rapidminer 5.0 with all the updates available (except text mining extension) and Paren worked just fine. Now that i needed the text mining extension, the 5.1.4 version was released and i updated it.
    It looked like Paren and Text mining finally worked well together,
    However, the problem is still there:
    Paren loads the data just fine, but when you click on evaluate (the classifier(s)), there's an error immediately saying: No operator description object given for '.com.rapidminer.operator.validation.parallelXvalidation'.
    How can i get Paren to work well again?
    any ideas?
    PS. it has nothing to do with the parallel extension since it's automatically installed when installing the ParEn extension.
  • psp
    psp New Altair Community Member
    Same problem here!!
  • psp
    Hi Sebastian
    Any reply from DFKI?
    Regards
    Peter
  • land
    Hi,
    yes we have found the error. We will publish the update as early as possible.
    Greetings,
    Sebastian
  • knightsy
    knightsy New Altair Community Member
    Hi Sebastian,
    Any progress on this?
  • land
    Hi,
    is already on the update server.
    Greetings,
      Sebastian
Welcome!
Welcome!
