🎉Community Raffle - Win $25
Join and Win
ERROR: input not prepared; try: acuRun -do all
User: "James Moody"
New Altair Community Member
Updated by James Moody
Hello,
I'm getting this error when trying to run a CFD simulation
Any help would be greatly appreciated!
Thanks
1 - 4 of 41
    User: "acupro"
    Altair Employee
    Accepted Answer
    Updated by acupro
    How are you attempting to run AcuSolve?
    Are you running from HyperWorks CFD?  If so - can you add a screenshot of the job launch panel - wide enough to show all input fields - directories, path to the solver, etc?
    Are you launching from the Command Prompt?  If so - what is the exact command you typed?
    User: "James Moody"
    OP
    I'm running it from HW CFD, here is the screenshot:
    User: "acupro"
    Altair Employee
    Updated by acupro
    It's very likely related to the spaces and/or the + in the directory (in any of the directories - complete path) and problem name. As a general rule I always recommend not using spaces - use underscore instead - and not to use characters like + in directories or problem names.
    User: "James Moody"
    OP
    Yes, thank you it seems to be working now!
