WinKad wrote:Beside this, where can I get a deeper information about the usage of macros?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="341" width="433"> <operator activated="true" class="generate_nominal_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="20"/> <parameter key="number_of_values" value="2"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="2010"/> </operator> <operator activated="true" class="replace" compatibility="5.0.10" expanded="true" height="76" name="Replace" width="90" x="179" y="30"> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="value"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.0.2" expanded="true" height="76" name="Windowing" width="90" x="313" y="30"> <parameter key="window_size" value="41"/> </operator> <operator activated="true" class="subprocess" compatibility="5.0.10" expanded="true" height="76" name="SetMultiLabel" width="90" x="45" y="120"> <parameter key="parallelize_nested_chain" value="true"/> <process expanded="true" height="701" width="433"> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel1" width="90" x="45" y="30"> <parameter key="name" value="att1-0"/> <parameter key="target_role" value="label01"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel2" width="90" x="179" y="30"> <parameter key="name" value="att2-0"/> <parameter key="target_role" value="label02"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel3" width="90" x="313" y="30"> <parameter key="name" value="att3-0"/> <parameter key="target_role" value="label03"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel4" width="90" x="45" y="120"> <parameter key="name" value="att4-0"/> <parameter key="target_role" value="label04"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel5" width="90" x="179" y="120"> <parameter key="name" value="att5-0"/> <parameter key="target_role" value="label05"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel6" width="90" x="313" y="120"> <parameter key="name" value="att6-0"/> <parameter key="target_role" value="label06"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel7" width="90" x="45" y="210"> <parameter key="name" value="att7-0"/> <parameter key="target_role" value="label07"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel8" width="90" x="179" y="210"> <parameter key="name" value="att8-0"/> <parameter key="target_role" value="label08"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel09" width="90" x="313" y="210"> <parameter key="name" value="att9-0"/> <parameter key="target_role" value="label9"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel10" width="90" x="45" y="300"> <parameter key="name" value="att10-0"/> <parameter key="target_role" value="label10"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel11" width="90" x="179" y="300"> <parameter key="name" value="att11-0"/> <parameter key="target_role" value="label11"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel12" width="90" x="313" y="300"> <parameter key="name" value="att12-0"/> <parameter key="target_role" value="label12"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel13" width="90" x="45" y="390"> <parameter key="name" value="att13-0"/> <parameter key="target_role" value="label13"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel14" width="90" x="179" y="390"> <parameter key="name" value="att14-0"/> <parameter key="target_role" value="label14"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel15" width="90" x="313" y="390"> <parameter key="name" value="att15-0"/> <parameter key="target_role" value="label15"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel16" width="90" x="45" y="480"> <parameter key="name" value="att16-0"/> <parameter key="target_role" value="label16"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel17" width="90" x="179" y="480"> <parameter key="name" value="att17-0"/> <parameter key="target_role" value="label17"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel18" width="90" x="313" y="480"> <parameter key="name" value="att18-0"/> <parameter key="target_role" value="label18"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel19" width="90" x="45" y="570"> <parameter key="name" value="att19-0"/> <parameter key="target_role" value="label19"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel20" width="90" x="179" y="570"> <parameter key="name" value="att20-0"/> <parameter key="target_role" value="label20"/> </operator> <connect from_port="in 1" to_op="SetLabel1" to_port="example set input"/> <connect from_op="SetLabel1" from_port="example set output" to_op="SetLabel2" to_port="example set input"/> <connect from_op="SetLabel2" from_port="example set output" to_op="SetLabel3" to_port="example set input"/> <connect from_op="SetLabel3" from_port="example set output" to_op="SetLabel4" to_port="example set input"/> <connect from_op="SetLabel4" from_port="example set output" to_op="SetLabel5" to_port="example set input"/> <connect from_op="SetLabel5" from_port="example set output" to_op="SetLabel6" to_port="example set input"/> <connect from_op="SetLabel6" from_port="example set output" to_op="SetLabel7" to_port="example set input"/> <connect from_op="SetLabel7" from_port="example set output" to_op="SetLabel8" to_port="example set input"/> <connect from_op="SetLabel8" from_port="example set output" to_op="SetLabel09" to_port="example set input"/> <connect from_op="SetLabel09" from_port="example set output" to_op="SetLabel10" to_port="example set input"/> <connect from_op="SetLabel10" from_port="example set output" to_op="SetLabel11" to_port="example set input"/> <connect from_op="SetLabel11" from_port="example set output" to_op="SetLabel12" to_port="example set input"/> <connect from_op="SetLabel12" from_port="example set output" to_op="SetLabel13" to_port="example set input"/> <connect from_op="SetLabel13" from_port="example set output" to_op="SetLabel14" to_port="example set input"/> <connect from_op="SetLabel14" from_port="example set output" to_op="SetLabel15" to_port="example set input"/> <connect from_op="SetLabel15" from_port="example set output" to_op="SetLabel16" to_port="example set input"/> <connect from_op="SetLabel16" from_port="example set output" to_op="SetLabel17" to_port="example set input"/> <connect from_op="SetLabel17" from_port="example set output" to_op="SetLabel18" to_port="example set input"/> <connect from_op="SetLabel18" from_port="example set output" to_op="SetLabel19" to_port="example set input"/> <connect from_op="SetLabel19" from_port="example set output" to_op="SetLabel20" to_port="example set input"/> <connect from_op="SetLabel20" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="540"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_labels" compatibility="5.0.10" expanded="true" height="76" name="MultipleLabelIterator" width="90" x="179" y="120"> <parameter key="parallelize_iteration" value="true"/> <process expanded="true" height="322" width="165"> <operator activated="true" class="x_validation" compatibility="5.0.10" expanded="true" height="112" name="Validation" width="90" x="45" y="30"> <parameter key="parallelize_training" value="true"/> <process expanded="true" height="322" width="165"> <operator activated="true" class="k_nn" compatibility="5.0.10" expanded="true" height="76" name="k-NN" width="90" x="45" y="30"> <parameter key="k" value="3"/> <parameter key="weighted_vote" value="true"/> <parameter key="measure_types" value="NominalMeasures"/> </operator> <connect from_port="training" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="322" width="433"> <operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="apply_model" compatibility="5.0.11" expanded="true" height="76" name="Apply Model (2)" width="90" x="180" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="find_threshold" compatibility="5.0.10" expanded="true" height="76" name="Find Threshold" width="90" x="45" y="120"/> <operator activated="true" class="apply_threshold" compatibility="5.0.10" expanded="true" height="76" name="Apply Threshold" width="90" x="179" y="120"/> <operator activated="true" class="performance_binominal_classification" compatibility="5.0.10" expanded="true" height="76" name="Performance" width="90" x="313" y="120"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Find Threshold" to_port="example set"/> <connect from_op="Find Threshold" from_port="example set" to_op="Apply Threshold" to_port="example set"/> <connect from_op="Find Threshold" from_port="threshold" to_op="Apply Threshold" to_port="threshold"/> <connect from_op="Apply Threshold" from_port="example set" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="90"/> <portSpacing port="sink_averagable 2" spacing="36"/> </process> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="36"/> <portSpacing port="sink_out 2" spacing="90"/> </process> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Windowing" to_port="example set input"/> <connect from_op="Windowing" from_port="example set output" to_op="SetMultiLabel" to_port="in 1"/> <connect from_op="SetMultiLabel" from_port="out 1" to_op="MultipleLabelIterator" to_port="example set"/> <connect from_op="MultipleLabelIterator" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="72"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="370" width="480"> <operator activated="true" class="generate_nominal_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="20"/> <parameter key="number_of_values" value="2"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="2010"/> </operator> <operator activated="true" class="replace" compatibility="5.0.10" expanded="true" height="76" name="Replace" width="90" x="179" y="30"> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="value"/> </operator> <operator activated="true" breakpoints="after" class="series:windowing" compatibility="5.0.2" expanded="true" height="76" name="Windowing" width="90" x="313" y="30"> <parameter key="window_size" value="41"/> </operator> <operator activated="true" class="multiply" compatibility="5.0.10" expanded="true" height="94" name="Multiply" width="90" x="45" y="120"/> <operator activated="true" breakpoints="after" class="loop_attributes" compatibility="5.0.10" expanded="true" height="60" name="Loop Attributes" width="90" x="246" y="300"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="att11-0|att10-0|att1-0"/> <process expanded="true" height="453" width="674"> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="Set Role" width="90" x="112" y="30"> <parameter key="name" value="%{loop_attribute}"/> <parameter key="target_role" value="label-%{a}"/> </operator> <operator activated="false" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="Set Role (2)" width="90" x="112" y="120"> <parameter key="name" value="%{loop_attribute}"/> <parameter key="target_role" value="label-%{loop_attribute}"/> </operator> <connect from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="subprocess" compatibility="5.0.10" expanded="true" height="76" name="SetMultiLabel" width="90" x="246" y="165"> <parameter key="parallelize_nested_chain" value="true"/> <process expanded="true" height="701" width="433"> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel1" width="90" x="45" y="30"> <parameter key="name" value="att1-0"/> <parameter key="target_role" value="label01"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel2" width="90" x="179" y="30"> <parameter key="name" value="att2-0"/> <parameter key="target_role" value="label02"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel3" width="90" x="313" y="30"> <parameter key="name" value="att3-0"/> <parameter key="target_role" value="label03"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel4" width="90" x="45" y="120"> <parameter key="name" value="att4-0"/> <parameter key="target_role" value="label04"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel5" width="90" x="179" y="120"> <parameter key="name" value="att5-0"/> <parameter key="target_role" value="label05"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel6" width="90" x="313" y="120"> <parameter key="name" value="att6-0"/> <parameter key="target_role" value="label06"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel7" width="90" x="45" y="210"> <parameter key="name" value="att7-0"/> <parameter key="target_role" value="label07"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel8" width="90" x="179" y="210"> <parameter key="name" value="att8-0"/> <parameter key="target_role" value="label08"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel09" width="90" x="313" y="210"> <parameter key="name" value="att9-0"/> <parameter key="target_role" value="label9"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel10" width="90" x="45" y="300"> <parameter key="name" value="att10-0"/> <parameter key="target_role" value="label10"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel11" width="90" x="179" y="300"> <parameter key="name" value="att11-0"/> <parameter key="target_role" value="label11"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel12" width="90" x="313" y="300"> <parameter key="name" value="att12-0"/> <parameter key="target_role" value="label12"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel13" width="90" x="45" y="390"> <parameter key="name" value="att13-0"/> <parameter key="target_role" value="label13"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel14" width="90" x="179" y="390"> <parameter key="name" value="att14-0"/> <parameter key="target_role" value="label14"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel15" width="90" x="313" y="390"> <parameter key="name" value="att15-0"/> <parameter key="target_role" value="label15"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel16" width="90" x="45" y="480"> <parameter key="name" value="att16-0"/> <parameter key="target_role" value="label16"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel17" width="90" x="179" y="480"> <parameter key="name" value="att17-0"/> <parameter key="target_role" value="label17"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel18" width="90" x="313" y="480"> <parameter key="name" value="att18-0"/> <parameter key="target_role" value="label18"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel19" width="90" x="45" y="570"> <parameter key="name" value="att19-0"/> <parameter key="target_role" value="label19"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel20" width="90" x="179" y="570"> <parameter key="name" value="att20-0"/> <parameter key="target_role" value="label20"/> </operator> <connect from_port="in 1" to_op="SetLabel1" to_port="example set input"/> <connect from_op="SetLabel1" from_port="example set output" to_op="SetLabel2" to_port="example set input"/> <connect from_op="SetLabel2" from_port="example set output" to_op="SetLabel3" to_port="example set input"/> <connect from_op="SetLabel3" from_port="example set output" to_op="SetLabel4" to_port="example set input"/> <connect from_op="SetLabel4" from_port="example set output" to_op="SetLabel5" to_port="example set input"/> <connect from_op="SetLabel5" from_port="example set output" to_op="SetLabel6" to_port="example set input"/> <connect from_op="SetLabel6" from_port="example set output" to_op="SetLabel7" to_port="example set input"/> <connect from_op="SetLabel7" from_port="example set output" to_op="SetLabel8" to_port="example set input"/> <connect from_op="SetLabel8" from_port="example set output" to_op="SetLabel09" to_port="example set input"/> <connect from_op="SetLabel09" from_port="example set output" to_op="SetLabel10" to_port="example set input"/> <connect from_op="SetLabel10" from_port="example set output" to_op="SetLabel11" to_port="example set input"/> <connect from_op="SetLabel11" from_port="example set output" to_op="SetLabel12" to_port="example set input"/> <connect from_op="SetLabel12" from_port="example set output" to_op="SetLabel13" to_port="example set input"/> <connect from_op="SetLabel13" from_port="example set output" to_op="SetLabel14" to_port="example set input"/> <connect from_op="SetLabel14" from_port="example set output" to_op="SetLabel15" to_port="example set input"/> <connect from_op="SetLabel15" from_port="example set output" to_op="SetLabel16" to_port="example set input"/> <connect from_op="SetLabel16" from_port="example set output" to_op="SetLabel17" to_port="example set input"/> <connect from_op="SetLabel17" from_port="example set output" to_op="SetLabel18" to_port="example set input"/> <connect from_op="SetLabel18" from_port="example set output" to_op="SetLabel19" to_port="example set input"/> <connect from_op="SetLabel19" from_port="example set output" to_op="SetLabel20" to_port="example set input"/> <connect from_op="SetLabel20" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="540"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="loop_labels" compatibility="5.0.10" expanded="true" height="76" name="MultipleLabelIterator" width="90" x="380" y="120"> <parameter key="parallelize_iteration" value="true"/> <process expanded="true" height="322" width="165"> <operator activated="true" class="x_validation" compatibility="5.0.10" expanded="true" height="112" name="Validation" width="90" x="45" y="30"> <parameter key="parallelize_training" value="true"/> <process expanded="true" height="322" width="165"> <operator activated="true" class="k_nn" compatibility="5.0.10" expanded="true" height="76" name="k-NN" width="90" x="45" y="30"> <parameter key="k" value="3"/> <parameter key="weighted_vote" value="true"/> <parameter key="measure_types" value="NominalMeasures"/> </operator> <connect from_port="training" to_op="k-NN" to_port="training set"/> <connect from_op="k-NN" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="322" width="433"> <operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="apply_model" compatibility="5.0.11" expanded="true" height="76" name="Apply Model (2)" width="90" x="180" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="find_threshold" compatibility="5.0.10" expanded="true" height="76" name="Find Threshold" width="90" x="45" y="120"/> <operator activated="true" class="apply_threshold" compatibility="5.0.10" expanded="true" height="76" name="Apply Threshold" width="90" x="179" y="120"/> <operator activated="true" class="performance_binominal_classification" compatibility="5.0.10" expanded="true" height="76" name="Performance" width="90" x="313" y="120"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Find Threshold" to_port="example set"/> <connect from_op="Find Threshold" from_port="example set" to_op="Apply Threshold" to_port="example set"/> <connect from_op="Find Threshold" from_port="threshold" to_op="Apply Threshold" to_port="threshold"/> <connect from_op="Apply Threshold" from_port="example set" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="90"/> <portSpacing port="sink_averagable 2" spacing="36"/> </process> </operator> <connect from_port="example set" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="36"/> <portSpacing port="sink_out 2" spacing="90"/> </process> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Windowing" to_port="example set input"/> <connect from_op="Windowing" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="SetMultiLabel" to_port="in 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 2"/> <connect from_op="SetMultiLabel" from_port="out 1" to_op="MultipleLabelIterator" to_port="example set"/> <connect from_op="MultipleLabelIterator" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="72"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="325" width="433"> <operator activated="true" class="generate_nominal_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="20"/> <parameter key="number_of_values" value="2"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="2010"/> </operator> <operator activated="true" class="replace" compatibility="5.0.10" expanded="true" height="76" name="Replace" width="90" x="179" y="30"> <parameter key="include_special_attributes" value="true"/> <parameter key="replace_what" value="value"/> </operator> <operator activated="true" class="series:windowing" compatibility="5.0.2" expanded="true" height="76" name="Windowing" width="90" x="313" y="30"> <parameter key="window_size" value="41"/> </operator> <operator activated="true" class="multiply" compatibility="5.0.11" expanded="true" height="94" name="Multiply" width="90" x="45" y="120"/> <operator activated="true" class="loop_attributes" compatibility="5.0.11" expanded="true" height="60" name="Loop Attributes" width="90" x="179" y="210"> <parameter key="attribute_filter_type" value="regular_expression"/> <parameter key="attributes" value="att1-0|att10-0|att11-0|att12-0|att13-0|att14-0|att15-0|att16-0|att17-0|att18-0|att19-0|att2-0|att20-0|att3-0|att4-0|att5-0|att6-0|att7-0|att8-0|att9-0"/> <parameter key="regular_expression" value="att.-0|att..-0"/> <process expanded="true" height="340" width="165"> <operator activated="true" class="set_role" compatibility="5.0.11" expanded="true" height="76" name="Set Role" width="90" x="45" y="30"> <parameter key="name" value="%{loop_attribute}"/> <parameter key="target_role" value="label%{a}"/> </operator> <connect from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="subprocess" compatibility="5.0.10" expanded="true" height="76" name="SetMultiLabel" width="90" x="179" y="120"> <parameter key="parallelize_nested_chain" value="true"/> <process expanded="true" height="701" width="433"> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel1" width="90" x="45" y="30"> <parameter key="name" value="att1-0"/> <parameter key="target_role" value="label01"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel2" width="90" x="179" y="30"> <parameter key="name" value="att2-0"/> <parameter key="target_role" value="label02"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel3" width="90" x="313" y="30"> <parameter key="name" value="att3-0"/> <parameter key="target_role" value="label03"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel4" width="90" x="45" y="120"> <parameter key="name" value="att4-0"/> <parameter key="target_role" value="label04"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel5" width="90" x="179" y="120"> <parameter key="name" value="att5-0"/> <parameter key="target_role" value="label05"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel6" width="90" x="313" y="120"> <parameter key="name" value="att6-0"/> <parameter key="target_role" value="label06"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel7" width="90" x="45" y="210"> <parameter key="name" value="att7-0"/> <parameter key="target_role" value="label07"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel8" width="90" x="179" y="210"> <parameter key="name" value="att8-0"/> <parameter key="target_role" value="label08"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel09" width="90" x="313" y="210"> <parameter key="name" value="att9-0"/> <parameter key="target_role" value="label9"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel10" width="90" x="45" y="300"> <parameter key="name" value="att10-0"/> <parameter key="target_role" value="label10"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel11" width="90" x="179" y="300"> <parameter key="name" value="att11-0"/> <parameter key="target_role" value="label11"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel12" width="90" x="313" y="300"> <parameter key="name" value="att12-0"/> <parameter key="target_role" value="label12"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel13" width="90" x="45" y="390"> <parameter key="name" value="att13-0"/> <parameter key="target_role" value="label13"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel14" width="90" x="179" y="390"> <parameter key="name" value="att14-0"/> <parameter key="target_role" value="label14"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel15" width="90" x="313" y="390"> <parameter key="name" value="att15-0"/> <parameter key="target_role" value="label15"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel16" width="90" x="45" y="480"> <parameter key="name" value="att16-0"/> <parameter key="target_role" value="label16"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel17" width="90" x="179" y="480"> <parameter key="name" value="att17-0"/> <parameter key="target_role" value="label17"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel18" width="90" x="313" y="480"> <parameter key="name" value="att18-0"/> <parameter key="target_role" value="label18"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel19" width="90" x="45" y="570"> <parameter key="name" value="att19-0"/> <parameter key="target_role" value="label19"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="SetLabel20" width="90" x="179" y="570"> <parameter key="name" value="att20-0"/> <parameter key="target_role" value="label20"/> </operator> <connect from_port="in 1" to_op="SetLabel1" to_port="example set input"/> <connect from_op="SetLabel1" from_port="example set output" to_op="SetLabel2" to_port="example set input"/> <connect from_op="SetLabel2" from_port="example set output" to_op="SetLabel3" to_port="example set input"/> <connect from_op="SetLabel3" from_port="example set output" to_op="SetLabel4" to_port="example set input"/> <connect from_op="SetLabel4" from_port="example set output" to_op="SetLabel5" to_port="example set input"/> <connect from_op="SetLabel5" from_port="example set output" to_op="SetLabel6" to_port="example set input"/> <connect from_op="SetLabel6" from_port="example set output" to_op="SetLabel7" to_port="example set input"/> <connect from_op="SetLabel7" from_port="example set output" to_op="SetLabel8" to_port="example set input"/> <connect from_op="SetLabel8" from_port="example set output" to_op="SetLabel09" to_port="example set input"/> <connect from_op="SetLabel09" from_port="example set output" to_op="SetLabel10" to_port="example set input"/> <connect from_op="SetLabel10" from_port="example set output" to_op="SetLabel11" to_port="example set input"/> <connect from_op="SetLabel11" from_port="example set output" to_op="SetLabel12" to_port="example set input"/> <connect from_op="SetLabel12" from_port="example set output" to_op="SetLabel13" to_port="example set input"/> <connect from_op="SetLabel13" from_port="example set output" to_op="SetLabel14" to_port="example set input"/> <connect from_op="SetLabel14" from_port="example set output" to_op="SetLabel15" to_port="example set input"/> <connect from_op="SetLabel15" from_port="example set output" to_op="SetLabel16" to_port="example set input"/> <connect from_op="SetLabel16" from_port="example set output" to_op="SetLabel17" to_port="example set input"/> <connect from_op="SetLabel17" from_port="example set output" to_op="SetLabel18" to_port="example set input"/> <connect from_op="SetLabel18" from_port="example set output" to_op="SetLabel19" to_port="example set input"/> <connect from_op="SetLabel19" from_port="example set output" to_op="SetLabel20" to_port="example set input"/> <connect from_op="SetLabel20" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="540"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Generate Nominal Data" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Windowing" to_port="example set input"/> <connect from_op="Windowing" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="SetMultiLabel" to_port="in 1"/> <connect from_op="Multiply" from_port="output 2" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 2"/> <connect from_op="SetMultiLabel" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
