Select Most Similar Items
ali_a_dehghan
ali_a_dehghan New Altair Community Member
edited November 2024 in Community Q&A
Hi Everyone,
I have constructed a similarity matrix (as mentioned in the paper you linked) for purchase items, and now I need to select K-Nearest Neighbors for them, but I don't know how can I select it. For example I have a matrix like it:
            Item1  Item2  Item3  Item 4  Item5
Item1    1        0.97    0.87    0.95    0.92
Item2    0.97  1        0.78    0.89    0.5
Item3    0.87  0.78    1        0.96    0.87
Item4    0.96  0.89    0.96    1        0.77
Item5    0.92  0.5      0.87    0.77    1
And "Active User" has purchased "Item1, Item4", and if consider K=2, I need to iterate on Item1 and Item4 and select most similar items (Top-N Algorithm), in my case "Item2,Item5" are chosen as candidate. I should add them to a queue and do this for next purchased item "Item4" => "Item3,Item2"
So my recommendation queue contains "Item2,Item5,Item3" and then I should order it by their similarity values "(0.97+0.89),0.92,0.96" and select K=2 items => Item2,Item3... so my recommendation for "Item1,Item4" is "Item2,Item3"
Please guide me which operators I should use to select Top-N items for a specific item...
Thanks all in advance
Welcome!
Answers
  • ali_a_dehghan
    No Reply?
  • haddock
    haddock New Altair Community Member
    Can you not tell?
  • ali_a_dehghan
    Pardon me?
  • haddock
    Pardon me?
    What for?
    Not quite sure about what exactly you need, but the this may help..
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.0">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process">
        <process expanded="true" height="359" width="908">
          <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
            <parameter key="repository_entry" value="//Samples/data/Iris"/>
          </operator>
          <operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="94" name="Multiply" width="90" x="246" y="30"/>
          <operator activated="true" class="cross_distances" compatibility="5.0.8" expanded="true" height="94" name="Cross Distances" width="90" x="380" y="30">
            <parameter key="only_top_k" value="true"/>
            <parameter key="k" value="3"/>
          </operator>
          <operator activated="true" class="sort" compatibility="5.0.8" expanded="true" height="76" name="Sort" width="90" x="581" y="30">
            <parameter key="attribute_name" value="request"/>
          </operator>
          <connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/>
          <connect from_op="Multiply" from_port="output 1" to_op="Cross Distances" to_port="request set"/>
          <connect from_op="Multiply" from_port="output 2" to_op="Cross Distances" to_port="reference set"/>
          <connect from_op="Cross Distances" from_port="result set" to_op="Sort" to_port="example set input"/>
          <connect from_op="Sort" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
  • ali_a_dehghan
    Thanks haddock for your guide...
    Might you please tell me how can I do so with SimilarityMatrix and input items (As I described before)
    Thanks for your help
  • haddock
    Have you considered paying RM to do some consultancy?
  • ali_a_dehghan
    I am just working on my thesis... This is an absolute academic job.
    So, please help me on it.
  • haddock
    You can work from my code to your answer by getting good at looping, macros, and collections. These operator groups require some work to understand, so the best thing is to get stuck in to the examples and the tutorials, if only to see whether you actually have the time that would be necessary.
Welcome!
Welcome!
