Pardon me?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process"> <process expanded="true" height="359" width="908"> <operator activated="true" class="retrieve" compatibility="5.0.8" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="multiply" compatibility="5.0.8" expanded="true" height="94" name="Multiply" width="90" x="246" y="30"/> <operator activated="true" class="cross_distances" compatibility="5.0.8" expanded="true" height="94" name="Cross Distances" width="90" x="380" y="30"> <parameter key="only_top_k" value="true"/> <parameter key="k" value="3"/> </operator> <operator activated="true" class="sort" compatibility="5.0.8" expanded="true" height="76" name="Sort" width="90" x="581" y="30"> <parameter key="attribute_name" value="request"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Cross Distances" to_port="request set"/> <connect from_op="Multiply" from_port="output 2" to_op="Cross Distances" to_port="reference set"/> <connect from_op="Cross Distances" from_port="result set" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
