How to export the correlation matrix results?
I made a correlation matrix, and attributes weight list, However, I found I can not export the list to a excel file, the only possible is a jpg file as current winodw? Besides, I am really eager of RM 5.0 manual, otherwise I have to start to learn german to read the german version
1 - 5 of
51
It seems that this bug also appears in version 6. If I let RM write a report it cannot be opened while running the same process again.
However, this is still a work-around. An operator which can handle matrix elements would be sooo handy
EDIT: Even more weird... I tried it a second time with exactely the same setup and now it works?!? Well, seems that the rootcause was probably something else with my computer. However, I still consider an operator to process matrix elements is still an important feature.
Best
Sachs
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="6.0.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.003" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="6.0.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
<parameter key="number_of_attributes" value="25"/>
</operator>
<operator activated="true" class="correlation_matrix" compatibility="6.0.003" expanded="true" height="94" name="Correlation Matrix" width="90" x="179" y="30"/>
<operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="76" name="Generate Report" width="90" x="313" y="30">
<parameter key="report_name" value="report"/>
<parameter key="format" value="Excel"/>
<parameter key="excel_output_file" value="C:\report.xls"/>
</operator>
<operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report" width="90" x="447" y="30">
<parameter key="specified" value="true"/>
<parameter key="reportable_type" value="Numerical Matrix"/>
<parameter key="renderer_name" value="Table View"/>
<list key="parameters">
<parameter key="min_row" value="1"/>
<parameter key="max_row" value="2147483647"/>
<parameter key="min_column" value="1"/>
<parameter key="max_column" value="2147483647"/>
</list>
</operator>
<operator activated="true" class="read_excel" compatibility="6.0.003" expanded="true" height="60" name="Read Excel" width="90" x="45" y="165">
<parameter key="excel_file" value="C:\report.xls"/>
<parameter key="imported_cell_range" value="A3:Z28"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<list key="data_set_meta_data_information">
<parameter key="0" value="Attributes.true.text.id"/>
<parameter key="1" value="att1.true.real.attribute"/>
<parameter key="2" value="att2.true.real.attribute"/>
<parameter key="3" value="att3.true.real.attribute"/>
<parameter key="4" value="att4.true.real.attribute"/>
<parameter key="5" value="att5.true.real.attribute"/>
<parameter key="6" value="att6.true.real.attribute"/>
<parameter key="7" value="att7.true.real.attribute"/>
<parameter key="8" value="att8.true.real.attribute"/>
<parameter key="9" value="att9.true.real.attribute"/>
<parameter key="10" value="att10.true.real.attribute"/>
<parameter key="11" value="att11.true.real.attribute"/>
<parameter key="12" value="att12.true.real.attribute"/>
<parameter key="13" value="att13.true.real.attribute"/>
<parameter key="14" value="att14.true.real.attribute"/>
<parameter key="15" value="att15.true.real.attribute"/>
<parameter key="16" value="att16.true.real.attribute"/>
<parameter key="17" value="att17.true.real.attribute"/>
<parameter key="18" value="att18.true.real.attribute"/>
<parameter key="19" value="att19.true.real.attribute"/>
<parameter key="20" value="att20.true.real.attribute"/>
<parameter key="21" value="att21.true.real.attribute"/>
<parameter key="22" value="att22.true.real.attribute"/>
<parameter key="23" value="att23.true.real.attribute"/>
<parameter key="24" value="att24.true.real.attribute"/>
<parameter key="25" value="att25.true.real.attribute"/>
</list>
</operator>
<connect from_op="Generate Data" from_port="output" to_op="Correlation Matrix" to_port="example set"/>
<connect from_op="Correlation Matrix" from_port="matrix" to_op="Generate Report" to_port="through 1"/>
<connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/>
<connect from_op="Read Excel" from_port="output" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="144"/>
</process>
</operator>
</process>
Best
Sachs
Hallo unvergessbar,
schön dich im Forum zu haben!
we have created a new operator called Matrix to Exampleset which is available in the Converters Extension. This makes your life easier .
See: https://marketplace.rapidminer.com/UpdateServer/faces/product_details.xhtml?productId=rmx_converters
Best,
Martin
learning German is definitely an option. However, here is some help now: you can export the correlation matrix by generating a report and write the report to an Excel file. Sounds complicated but is not. The process below shows you how to do this.
Due to your request we also found a tiny bug. Unfortunatly you'll need to close RM to open the written report Excel file without a write protection. This bug is fixed in the svn repository version now and the fix will be part of the next RM update.
Ciao Sebastian
Link to the MyExperiment.org workflow: http://www.myexperiment.org/workflows/1279 also accessible threw the RM community plugin.
