<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="341" width="614"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="correlation_matrix" expanded="true" height="94" name="Correlation Matrix" width="90" x="179" y="75"/> <operator activated="true" class="reporting:generate_report" expanded="true" height="76" name="Generate Report" width="90" x="313" y="30"> <parameter key="report_name" value="Excel"/> <parameter key="format" value="Excel"/> <parameter key="excel_output_file" value="C:\ExcelReport.xls"/> </operator> <operator activated="true" class="reporting:report" expanded="true" height="60" name="Report" width="90" x="447" y="30"> <parameter key="report_name" value="Excel"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Numerical Matrix"/> <parameter key="renderer_name" value="Table View"/> <list key="parameters"> <parameter key="min_row" value="1"/> <parameter key="max_row" value="2147483647"/> <parameter key="min_column" value="1"/> <parameter key="max_column" value="2147483647"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Correlation Matrix" to_port="example set"/> <connect from_op="Correlation Matrix" from_port="matrix" to_op="Generate Report" to_port="through 1"/> <connect from_op="Correlation Matrix" from_port="weights" to_port="result 2"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <connect from_op="Report" from_port="reportable out" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="180"/> <portSpacing port="sink_result 3" spacing="18"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.003" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="6.0.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_of_attributes" value="25"/> </operator> <operator activated="true" class="correlation_matrix" compatibility="6.0.003" expanded="true" height="94" name="Correlation Matrix" width="90" x="179" y="30"/> <operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="76" name="Generate Report" width="90" x="313" y="30"> <parameter key="report_name" value="report"/> <parameter key="format" value="Excel"/> <parameter key="excel_output_file" value="C:\report.xls"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report" width="90" x="447" y="30"> <parameter key="report_name" value="report"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Numerical Matrix"/> <parameter key="renderer_name" value="Table View"/> <list key="parameters"> <parameter key="min_row" value="1"/> <parameter key="max_row" value="2147483647"/> <parameter key="min_column" value="1"/> <parameter key="max_column" value="2147483647"/> </list> </operator> <operator activated="true" class="read_excel" compatibility="6.0.003" expanded="true" height="60" name="Read Excel" width="90" x="45" y="165"> <parameter key="excel_file" value="C:\report.xls"/> <parameter key="imported_cell_range" value="A3:Z28"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="Attributes.true.text.id"/> <parameter key="1" value="att1.true.real.attribute"/> <parameter key="2" value="att2.true.real.attribute"/> <parameter key="3" value="att3.true.real.attribute"/> <parameter key="4" value="att4.true.real.attribute"/> <parameter key="5" value="att5.true.real.attribute"/> <parameter key="6" value="att6.true.real.attribute"/> <parameter key="7" value="att7.true.real.attribute"/> <parameter key="8" value="att8.true.real.attribute"/> <parameter key="9" value="att9.true.real.attribute"/> <parameter key="10" value="att10.true.real.attribute"/> <parameter key="11" value="att11.true.real.attribute"/> <parameter key="12" value="att12.true.real.attribute"/> <parameter key="13" value="att13.true.real.attribute"/> <parameter key="14" value="att14.true.real.attribute"/> <parameter key="15" value="att15.true.real.attribute"/> <parameter key="16" value="att16.true.real.attribute"/> <parameter key="17" value="att17.true.real.attribute"/> <parameter key="18" value="att18.true.real.attribute"/> <parameter key="19" value="att19.true.real.attribute"/> <parameter key="20" value="att20.true.real.attribute"/> <parameter key="21" value="att21.true.real.attribute"/> <parameter key="22" value="att22.true.real.attribute"/> <parameter key="23" value="att23.true.real.attribute"/> <parameter key="24" value="att24.true.real.attribute"/> <parameter key="25" value="att25.true.real.attribute"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Correlation Matrix" to_port="example set"/> <connect from_op="Correlation Matrix" from_port="matrix" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <connect from_op="Read Excel" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="144"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Seems that this little bug is still in version 7: I have to end the process first before I can access the report file
Best regards
Hallo unvergessbar,
schön dich im Forum zu haben!
we have created a new operator called Matrix to Exampleset which is available in the Converters Extension. This makes your life easier .
See: https://marketplace.rapidminer.com/UpdateServer/faces/product_details.xhtml?productId=rmx_converters
Best,
Martin
