🎉Community Raffle - Win $25
Join and Win
"Similarity Measure into Clustering"
User: "B_Miner"
New Altair Community Member
Updated by Jocelyn
Hi Guys,
Is it possible to use RM to create a distance matrix (say Jaccard Sim) and use this matrix into a cluster analysis? If so are there any examples?
Thanks!
Brian
1 - 3 of 31
    User: "land"
    Hi Brian,
    both is possible. You might create a distance matrix using the Data to Similarity operator and select Jaccard Simularity as distance function. And you might do clustering selecting the same distance function using for example kMedoids.
    Greetings,
      Sebastian
    User: "B_Miner"
    OP
    Hi Sebastian,
    I tried to hook up a Data to Similarity operator to kmeans and got an error. Is kMedoids the only clustering that can take a distance matrix as input? Example that causes error for type of input into kmeans:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.0">
      <context>
        <input>
          <location/>
        </input>
        <output>
          <location/>
          <location/>
        </output>
        <macros/>
      </context>
      <operator activated="true" class="process" expanded="true" name="Process">
        <process expanded="true" height="296" width="280">
          <operator activated="true" class="generate_nominal_data" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="165"/>
          <operator activated="true" class="data_to_similarity" expanded="true" height="76" name="Data to Similarity" width="90" x="112" y="30">
            <parameter key="measure_types" value="NominalMeasures"/>
            <parameter key="nominal_measure" value="JaccardSimilarity"/>
          </operator>
          <operator activated="true" class="k_means" expanded="true" height="76" name="Clustering" width="90" x="179" y="165"/>
          <connect from_op="Generate Nominal Data" from_port="output" to_op="Data to Similarity" to_port="example set"/>
          <connect from_op="Data to Similarity" from_port="similarity" to_op="Clustering" to_port="example set"/>
          <connect from_op="Clustering" from_port="cluster model" to_port="result 1"/>
        </process>
      </operator>
    </process>
    User: "land"
    Hi,
    K-Means does always use Euclidean distance, it's simply part of the algorithm. In Kmedoids, you might select the distance function, but you cannot forward a similarity matrix. It will calculate the similarities from the given example set as it needs them.
    Greetings,
      Sebastian
